Home » Newcomers » Newcomers » HELP!! Can't install Eclipse 3.1!!!
HELP!! Can't install Eclipse 3.1!!! [message #101419] Mon, 12 September 2005 17:17
Originally posted by: dfamarty.aol.com
What is the reason for this error? Is it permissions related?
!SESSION 2005-09-02 12:33:16.270
eclipse.buildId=I20050627-1435
java.version=1.4.2_07
java.vendor=Apple Computer, Inc.
BootLoader constants: OS=macosx, ARCH=ppc, WS=carbon, NL=en_US
Framework arguments: -keyring /Users/martinsoyka/.eclipse_keyring
-showlocation
Command-line arguments: -os macosx -ws carbon -arch ppc -keyring
/Users/martinsoyka/.eclipse_keyring -consoleLog -showlocation
!ENTRY org.eclipse.core.runtime 2 1 2005-09-02 12:33:18.13
!MESSAGE Problems parsing plug-in manifest for:
"initial@reference:file:plugins/org.eclipse.core.runtime_3.1.0.jar/".
!SUBENTRY 1 org.eclipse.core.runtime 2 1 2005-09-02 12:33:18.15
!MESSAGE Parsing error in "plugin.xml" [line 1, column 0]: "URI was not
reported to parser for entity [document]".
!STACK 0
org.xml.sax.SAXParseException: URI was not reported to parser for entity
[document]
at gnu.xml.aelfred2.SAXDriver.warn(SAXDriver.java:934)
at gnu.xml.aelfred2.SAXDriver.startExternalEntity(SAXDriver.jav a:631)
at gnu.xml.aelfred2.XmlParser.pushURL(XmlParser.java:3358)
at gnu.xml.aelfred2.XmlParser.doParse(XmlParser.java:159)
at gnu.xml.aelfred2.SAXDriver.parse(SAXDriver.java:320)
at gnu.xml.aelfred2.XmlReader.parse(XmlReader.java:294)
at javax.xml.parsers.SAXParser.parse(SAXParser.java:345)
org.eclipse.core.internal.registry.ExtensionsParser.parseMan ifest(ExtensionsParser.java:375)
org.eclipse.core.internal.registry.EclipseBundleListener.get BundleModel(EclipseBundleListener.java:197)
org.eclipse.core.internal.registry.EclipseBundleListener.add Bundle(EclipseBundleListener.java:101)
org.eclipse.core.internal.registry.EclipseBundleListener.pro cessBundles(EclipseBundleListener.java:82)
org.eclipse.core.internal.registry.ExtensionRegistry.<init>(ExtensionRegistry.java:687)
org.eclipse.core.internal.runtime.PlatformActivator.startReg istry(PlatformActivator.java:84)
org.eclipse.core.internal.runtime.PlatformActivator.start(Pl atformActivator.java:58)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:994)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:988)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:969)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:321)
org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:339)
org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1024)
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:576)
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:498)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:275)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:458)
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:189)
org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventManager.java:291)
!ENTRY org.eclipse.core.runtime 2 1 2005-09-02 12:33:18.69
"initial@reference:file:plugins/org.eclipse.update.configurator_3.1.0.jar/".
!SUBENTRY 1 org.eclipse.core.runtime 2 1 2005-09-02 12:33:18.72
!STACK 0
[document]
!ENTRY
0 0 2005-09-02 12:33:18.264
!MESSAGE FrameworkEvent.ERROR
!STACK 0
org.osgi.framework.BundleException: Exception in
org.eclipse.update.internal.configurator.ConfigurationActiva tor.start() of
bundle org.eclipse.update.configurator.
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1013)
Caused by: org.eclipse.core.runtime.CoreException: Cannot create
configuration in file:/Downloads/eclipse/configuration/
org.eclipse.update.internal.configurator.Utils.newCoreExcept ion(Utils.java:71)
org.eclipse.update.internal.configurator.ConfigurationActiva tor.initialize(ConfigurationActivator.java:106)
org.eclipse.update.internal.configurator.ConfigurationActiva tor.start(ConfigurationActivator.java:67)
... 10 more
Root exception:
org.eclipse.core.runtime.CoreException: Cannot create configuration in
!ENTRY org.eclipse.osgi 2005-09-02 12:33:18.308
!MESSAGE Startup error
!STACK 1
java.lang.IllegalStateException: Bundle
[2] is not active.
org.eclipse.core.runtime.adaptor.EclipseStarter.ensureBundle sActive(EclipseStarter.java:410)
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:297)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:159)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Previous Topic:Building C++ projects
Next Topic:Windows X64
Current Time: Fri Jul 18 06:01:00 EDT 2025
Powered by FUDForum. Page generated in 0.08075 seconds
