Home » Archived » M2M (model-to-model transformation) » [QVTO] transformation reuse by extension?
[QVTO] transformation reuse by extension? [message #101313] Mon, 09 March 2009 05:29 Go to next message
Hi all,
In slide 25 of [1] it says that transformations can be reused:
transformation MMaToMMbExt(in ma : MMa, out mb : MMb)
extends transformation MMaToMMb(in MMa, out MMb);
But this does not work for me:
transformation testTransf(in library : Library, out myLib : MyLib)
extends transformation testTransf_basic(in library : Library, out myLib : MyLib);
Eclipse tells me that 'Transformation module usages not supported'.
The transformation works with the extends-line.
Did I miss something or is it indeed not yet supported?
Cheers
Patrick
[1] http://www.eclipse.org/m2m/qvto/doc/M2M-QVTO.pdf
Re: [QVTO] transformation reuse by extension? [message #101347 is a reply to message #101313] Mon, 09 March 2009 06:21 Go to previous messageGo to next message
Hi Patrick,
Reuse by extension is not ready yet, the slide is about QVTO in general,
so it may happpen that something is still missing ;).
However, you can use composition of transformations.
Just use the statement for import of a compilation unit and
explicit instantiation of the aggregated transformation.
In case you declare a module usage like " access ComposedTransf(...",
you still get the problem reported,
but the import statement is enough to make things work.
We will fix this misbehaviour soon.
/Radek
On Mon, 09 Mar 2009 10:29:19 +0100, Patrick Könemann <pk@imm.dtu.dk> wrote:
> Hi all,
> myLib : MyLib);
> Cheers
> Patrick
Re: [QVTO] transformation reuse by extension? [message #101369 is a reply to message #101347] Mon, 09 March 2009 06:50 Go to previous messageGo to next message
Hi Radek,
Allright, thanks for hint! It almost works - but only almost:
Transformation testTransfA imports testTransfB, instantiates it and calls transform().
That works fine. However, I override some some mappings and this produces an exception:
----------> testTransfA <----------
import testTransfB_basic;
extends transformation testTransfB_basic(in library : Library, out myLib : MyLib);
main() {
new testTransfB_basic(library, myLib).transform();
-- this is the critical mapping which produces the exception
mapping SpecialBook::toMyBook() : MyBook inherits Book::toMyBook {
----------> testTransfB <----------
main() {
mapping Book::toMyBook() : MyBook {
If I remove 'mapping SpecialBook::toMyBook()', then the transformation works.
If I put all mappings into one single transformation, the transformation also works.
But the files as shown above produce a NPE in the error log:
at org.eclipse.m2m.internal.qvt.oml.ast.env.QvtOperationalEvalu ationEnv.createInstance(QvtOperationalEvaluationEnv.java:428 )
at org.eclipse.m2m.internal.qvt.oml.evaluator.QvtOperationalEva luationVisitorImpl.createInstance(QvtOperationalEvaluationVi sitorImpl.java:1963)
at org.eclipse.m2m.internal.qvt.oml.evaluator.QvtOperationalEva luationVisitorImpl.getOutOwner(QvtOperationalEvaluationVisit orImpl.java:1812)
Any ideas?
Patrick
On 09-03-2009 11:21, Radek Dvorak wrote:
> Hi Patrick,
> /Radek
>> Hi all,
>> myLib : MyLib);
>> Cheers
>> Patrick
Re: [QVTO] transformation reuse by extension? [message #101379 is a reply to message #101369] Mon, 09 March 2009 07:16 Go to previous message
Thanks for finding this, I will investigate the problem.
/Radek
On Mon, 09 Mar 2009 11:50:30 +0100, Patrick Könemann <pk@imm.dtu.dk> wrote:
> Hi Radek,
> calls transform().
> myLib : MyLib);
> main() {
> MyLib);
> main() {
> works.
> also works.
> java.lang.NullPointerException
> at
> at
> at
> Any ideas?
> Patrick
>> Hi Patrick,
>> Regards,
>> /Radek
>> wrote:
>>> Hi all,
>>> myLib : MyLib);
>>> Cheers
>>> Patrick
Previous Topic:[ATL] Property type/association values lost during transformation
Next Topic:[ATL] Transform between XML models
Current Time: Mon Sep 01 04:42:54 EDT 2025
Powered by FUDForum. Page generated in 0.03657 seconds
