Re: TCP monitor SOAP requests [message #172799 is a reply to message #172700] |
Fri, 30 June 2006 10:28  |
I'm not sure I understand how you create the Web service and Web service
client. If you are using the Web Service wizard in WTP to create the Web
service and Web service client, you can select the "Monitor Web service"
checkbox on the first page of the wizard to bring up the TCP/IP monitor
automatically. Then if you had move the client scale to "Test", sample JSPs
would be generated to test your Web service. When you invoke the Web
service in the sample JSP, the TCP/IP monitor view would come up
automatically and you can see your SOAP request.
If I have misunderstood your set up, please elaborate on what you did to
create the Web service and Web service client and what kind of problem you
ran into.
Kathy Chan
"Michael Boeni" <mbo@shift-think.net> wrote in message
news:44A3F6E4.70102@shift-think.net...
> Hi there
> have you had any success in on this? I am having the same issues
> currently...
> Cheers,
> Michael
> plork123 schrieb:
> > Hello all
> > I've created a web service and a web service client that calls a method
from
> > the web service
> > To test my web service client i right click the file select Run and
> > Argumenst tab - type in some parameters and click apply
> > I then debug my java
> > What i want t happen is to see the SOAP request/response from my client
> > java - can someone tell me how i see this
> > I'm following an example from here
http://www.developertutorials.com/tutorials/xml/better-soap- interfaces/page5.html
> > Thanks for any help
FUDForum. Page generated in 0.03258 seconds
