Home » Eclipse Projects » Equinox » ds in tomcat environment
ds in tomcat environment [message #101184] Tue, 06 November 2007 11:14 Go to next message
Originally posted by: benedikt.arnold.beyondsoft.de
Hi!
In my application I use ds to register the services. If I run equinox from
within eclipse or by command line everything works fine. All services are
registered and my application works.
But now I am trying to deploy my application in an tomcat and I got an
NullPointerException whenever I activate a bundle wich should register a
service via ds.
osgi> ss
Framework is launched.
id State Bundle
0 ACTIVE org.eclipse.osgi_3.3.0.v20070530
2 ACTIVE org.eclipse.osgi.services_3.1.200.v20070531
3 ACTIVE org.eclipse.equinox.util_0.1.0.200711061652
4 ACTIVE org.eclipse.equinox.ds_0.1.0.200711061652
5 ACTIVE org.eclipse.equinox.log_1.0.100.v20070226
6 ACTIVE org.eclipse.osgi.util_3.1.200.v20070605
7 ACTIVE org.eclipse.equinox.common_3.3.0.v20070426
8 ACTIVE org.eclipse.equinox.preferences_3.2.100.v20070522
9 ACTIVE org.eclipse.equinox.useradmin_1.0.0.v20070226
10 ACTIVE de.beyondsoft.voipconf.services_1.0.0
11 ACTIVE de.beyondsoft.voipconf.core.hibernate_1.0.0
osgi>
The bundle de.beyondsoft.voipconf.core.hibernate should export a service.
After starting this bundle the log output looks like this:
osgi> log
>Info [5] Log created; Log Size=100; Log Threshold=4
>initial@reference:file:plugins/org.eclipse.equinox.log_1.0.100.v200
70226.jar/
>Info [5] ServiceEvent REGISTERED {service.id=23}
>Info [5] ServiceEvent REGISTERED {service.id=24}
>Info [5] ServiceEvent REGISTERED {service.id=25}
>Info [5] BundleEvent STARTED
>initial@reference :file:plugins/org.eclipse.equinox.log_1.0.100.v20070226.jar/
>Error [4] [SCR - SCRManager] could not create instance for null
>initial@reference:file:plugins/org.eclipse.equinox.ds_0
..1.0.200711061652.jar/
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Unknown Source)
at org.eclipse.equinox.ds.SCRManager.<init>(Unknown Source)
at org.eclipse.equinox.ds.Activator.initSCR(Unknown Source)
at org.eclipse.equinox.ds.Activator.start(Unknown Source)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:999)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:993)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:974)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:350)
org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1118)
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:634)
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:508)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:282)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:468)
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:195)
org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventManager.java:297)
>Info [4] ServiceEvent REGISTERED {service.id=26}
>Info [4] BundleEvent STARTED
>initial@reference :file:plugins/org.eclipse.equinox.ds_0.1.0.200711061652.jar/
>Info [6] BundleEvent STARTED
>initial@reference:file:plugins/org.eclipse.osgi.util_3.1.200.v20070605.jar/
>Info [7] ServiceEvent REGISTERED {service.id=27}
>Info [7] ServiceEvent REGISTERED {service.id=28}
>Info [7] ServiceEvent REGISTERED {service.id=29}
>Info [7] BundleEvent STARTED
>initial@reference :file:plugins/org.eclipse.equinox.common_3.3.0.v20070426.jar /
>Info [8] ServiceEvent REGISTERED {service.id=30}
>Info [8] ServiceEvent REGISTERED {service.id=31}
>Info [8] BundleEvent STARTED
>initial@reference :file:plugins/org.eclipse.equinox.preferences_3.2.100.v20070 522.jar/
>Info [9] ServiceEvent REGISTERED {service.id=32}
>Info [9] BundleEvent STARTED
>initial@reference :file:plugins/org.eclipse.equinox.useradmin_1.0.0.v20070226. jar/
>Info [10] BundleEvent STARTED
>initial@reference:file:plugins/de.beyondsoft.voipconf.services_1.0.0.jar/
>Error [4] FrameworkEvent ERROR
at org.eclipse.equinox.ds.SCRManager.startedBundle(Unknown Source)
at org.eclipse.equinox.ds.SCRManager.bundleChanged(Unknown Source)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.d ispatchEvent(BundleContextImpl.java:1210)
org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEv entSynchronous(ListenerQueue.java:141)
org.eclipse.osgi.framework.internal.core.Framework.publishBu ndleEventPrivileged(Framework.java:1558)
org.eclipse.osgi.framework.internal.core.Framework.publishBu ndleEvent(Framework.java:1509)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:355)
>Info [11] BundleEvent STARTED
>initial@reference :file:plugins/de.beyondsoft.voipconf.core.hibernate_1.0.0.ja r/
>Info [0] FrameworkEvent STARTLEVEL CHANGED System Bundle
osgi>
Can somebody please give me a hint what could be wrong? Is there a bundle
missing? Thanks!
I've forgotten to mention that I am using the newest org.eclipse.equinox.ds
bundle from cvs equinox-incubator.
Greetings,
Ben
Re: ds in tomcat environment [message #101198 is a reply to message #101184] Wed, 07 November 2007 08:00 Go to previous message
I found out that it must be a bug in org.eclipse.equinox.ds from
equinox-incubator so I filed a bug report:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=209013
Greetings,
Ben
"Benedikt Arnold" <benedikt.arnold@beyondsoft.de> schrieb im Newsbeitrag
news:fgq3t1$q1r$1@build.eclipse.org...
> Hi!
> service via ds.
> osgi> ss
> id State Bundle
> osgi>
> osgi> log
> 70226.jar/
> java.lang.NullPointerException
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> osgi>
> missing? Thanks!
> org.eclipse.equinox.ds bundle from cvs equinox-incubator.
> Greetings,
> Ben
Previous Topic:Akwaard order of help for provided console commands
Next Topic:How to append classpath to other bundles?
Current Time: Sun Aug 31 06:21:34 EDT 2025
Powered by FUDForum. Page generated in 0.03545 seconds
