Home » Archived » Test and Performance Tools Platform (TPTP) » TPTP AGR problem on PVCS plug-in
TPTP AGR problem on PVCS plug-in [message #100987] Fri, 15 June 2007 00:45 Go to next message
Originally posted by: Enwei.Shi.cognizant.com
HI,
Now, we are using the TPTP AGR to recorde the action on PVCS plug-in.
The action is select a project from a project list which is automaticlly got
from the version control sever so the position of the project is dynamic.
We have record the position of the
Re: TPTP AGR problem on PVCS plug-in [message #101066 is a reply to message #100987] Sun, 17 June 2007 19:48 Go to previous message
Thanks for your interest in TPTP. The problem is very likely due to the
changing location of the item in the list. If there is a way to make this
static (i.e. always at the bottom or top) then you could use position-based
recording to get a consistent result. If you attach your entire test case
and object mine I may be able to give you a better recording workaround to
accomplish the same goal.
Sincerely,
Liz Dancy
"Wayne" <Enwei.Shi@cognizant.com> wrote in message
news:f4t5db$gum$1@build.eclipse.org...
> HI,
> Now, we are using the TPTP AGR to recorde the action on PVCS plug-in. The
Previous Topic:Launching process and not stopping them
Next Topic:TPTP testing and plugin
Current Time: Sun Aug 31 13:33:48 EDT 2025
Powered by FUDForum. Page generated in 0.04144 seconds
