Home » Modeling » GMF (Graphical Modeling Framework) » disable _diagram file
disable _diagram file [message #100828] Fri, 02 February 2007 17:03 Go to next message
Originally posted by: mail.volker-wegert.de
as I'm keeping all the information necessary to create the diagram inside my
EMF model, I want to disable the _diagram file entirely. I've found a little
advic e in the wiki (http://tinyurl.com/2tpvdc) - is this text still valid
with GMF 2.0M4?
Volker
* Volker Wegert * http://www.volker-wegert.de/contact *
* "Auch die beunruhigendste Gegenwart wird bald Vergangenheit sein. Das
* ist immerhin tröstlich." (Thornton Wilder)
Re: disable _diagram file [message #101009 is a reply to message #100828] Mon, 05 February 2007 12:37 Go to previous message
Hello Volker,
Mentioned article should be valid for current versino of GMF. In addition
I suggest you the following (simple step..): http://wiki.eclipse.org/index.php/GMF_GenModel_Hints#GenEdit orGenerator
-> Same File For Diagram And Model
Alex Shatalin
Previous Topic:Change connection target in the model, but diagram not updated
Next Topic:Group/Ungroup support question
Current Time: Fri Jul 18 10:19:16 EDT 2025
Powered by FUDForum. Page generated in 0.03088 seconds
