Home » Modeling » GMF (Graphical Modeling Framework) » ecore properties
ecore properties [message #100747] Fri, 02 February 2007 12:44 Go to next message
Originally posted by: mikemike54.hotmail.com
Here is the situation. In my ecore file, I have a type <foo> that has a
member of 0..* EString. In the GMF property viewer, all I see is a drop
box with an empty list of items to insert. Without changing the ecore,
is there a way to allow me to edit this property? Ideally, a user
should just be able to type in Strings they want to add to this list.
Can anyone help me with this?
-Michael
Re: ecore properties [message #100770 is a reply to message #100747] Fri, 02 February 2007 12:47 Go to previous messageGo to next message
What do you see in the ecore generated editor?
> a member of 0..* EString. In the GMF property viewer, all I see is a
> drop box with an empty list of items to insert. Without changing the
> ecore, is there a way to allow me to edit this property? Ideally, a
> user should just be able to type in Strings they want to add to this
> list.
> Thanks
> -Michael
Re: ecore properties [message #100780 is a reply to message #100770] Fri, 02 February 2007 12:52 Go to previous messageGo to next message
I don't understand what you mean. I am kind of new at this GMF thing
and inherited this project from someone else who basically hacked it
together himself...
So, what is it I am looking for here? I recall reading something about
adding a properties dialog. Would that solve this problem? Where would
such a thing need to go?
>> list.
>> Thanks
>> -Michael
Re: ecore properties [message #100790 is a reply to message #100780] Fri, 02 February 2007 14:43 Go to previous messageGo to next message
Boy, I hate to say this, but it took me months to figure a lot of this
stuff out. But then I'm kind of slow. :)
I think my general suggestion is that you will probably need to take a
step or two back and look at the EMF/ecore stuff and be prepared for
some rather deep reading -- I just don't think that GMF will make sense
to you until you have a handle on that. The issue at hand here is
wether the ecore model and generated code even supports what you want
to do. In this case I was suggesting that you take a look at the EMF
generate .editor code and see wehter _iot_ works as expected first.
YMMV, of course.
> together himself...
> would such a thing need to go?
>>> list.
>>> Thanks
>>> -Michael
Re: ecore properties [message #100802 is a reply to message #100790] Fri, 02 February 2007 15:47 Go to previous messageGo to next message
Miles,
Yes, this should be properly supported in the generated EMF editor to
produce a dialog that lets you enter a series of string...
> sense to you until you have a handle on that. The issue at hand here
> is wether the ecore model and generated code even supports what you
> want to do. In this case I was suggesting that you take a look at the
> EMF generate .editor code and see wehter _iot_ works as expected first.
> YMMV, of course.
>> together himself...
>> about adding a properties dialog. Would that solve this problem?
>> Where would such a thing need to go?
>>>> has a member of 0..* EString. In the GMF property viewer, all I
>>>> see is a drop box with an empty list of items to insert. Without
>>>> changing the ecore, is there a way to allow me to edit this
>>>> property? Ideally, a user should just be able to type in Strings
>>>> Thanks
>>>> -Michael
Re: ecore properties [message #100815 is a reply to message #100802] Fri, 02 February 2007 16:30 Go to previous messageGo to next message
Right..to be clear I meant there is probably something up w/ the
..ecore, .genmodel, or gen'd code in question as this should
work..sorry, Mike, bottom line is that your expectation is correct but
that the develi is in the details..
On 2007-02-02 15:47:12 -0500, Ed Merks <merks@ca.ibm.com> said:
> Miles,
>> YMMV, of course.
>>> together himself...
>>>>> list.
>>>>> Thanks
>>>>> -Michael
Re: ecore properties [message #100871 is a reply to message #100802] Fri, 02 February 2007 18:08 Go to previous messageGo to next message
So, is there a quick place you can point me to so I can make a dialog
box for this? Or should I dredge through the EMF book and google?
Ed Merks wrote:
> Miles,
>> YMMV, of course.
>>> together himself...
>>>>> Thanks
>>>>> -Michael
Re: ecore properties [message #100899 is a reply to message #100871] Sat, 03 February 2007 07:40 Go to previous message
Michael,
You can look in
org.eclipse.emf.edit.ui.provider.PropertyDescriptor.createPr opertyEditor
to see how it uses ExtendedDialogCellEditor in combination with
FeatureEditorDialog.
> Ed Merks wrote:
>> Miles,
>>> this stuff out. But then I'm kind of slow. :)
>>> a step or two back and look at the EMF/ecore stuff and be prepared
>>> for some rather deep reading -- I just don't think that GMF will
>>> make sense to you until you have a handle on that. The issue at hand
>>> here is wether the ecore model and generated code even supports what
>>> you want to do. In this case I was suggesting that you take a look
>>> at the EMF generate .editor code and see wehter _iot_ works as
>>> expected first.
>>> YMMV, of course.
>>>> thing and inherited this project from someone else who basically
>>>> hacked it together himself...
>>>>>> that has a member of 0..* EString. In the GMF property viewer,
>>>>>> all I see is a drop box with an empty list of items to insert.
>>>>>> Without changing the ecore, is there a way to allow me to edit
>>>>>> this property? Ideally, a user should just be able to type in
>>>>>> Thanks
>>>>>> -Michael
Previous Topic:Multiple diagrams and generated xxxDocumentProvider synchronization code
Next Topic:large E(G)MF models
Current Time: Sun Aug 31 06:10:50 EDT 2025
Powered by FUDForum. Page generated in 0.26561 seconds
