Home » Eclipse Projects » GEF » Re: HelloGef1 on Wiki
Re: HelloGef1 on Wiki [message #100647] Sat, 18 October 2003 23:56 Go to next message
Originally posted by: chhil.hotmail.com
[Apologies if this gets posted twice...]
I am using 2.1.2 GEF 2.1.1
I was going through the example and had a couple of questions.
These are very helpful for beginners like me...thank you.
1.In the HelloTopEditpart.createfigure method has a comment ...
// Don't know why, but if you don't setOpaque(true), you cannot move
by drag&drop!
f.setOpaque(true);
If I comment the above line I am can still drag and drop was this a bug
that has been fixed?
2. HelloGefEditor.configureGraphicalViewer has a comment
// If you don't put this line, then moving figures by drag & drop
// above the left or top limit of the editor window will lead to
// an infinite loop!
((FigureCanvas)viewer.getControl()).setScrollBarVisibility(F igureCanvas.ALWAYS);
If I comment the above line I don't see the effect of an infinite loop
as I see scrollbars scrolling and eventually stop if I drop it outside
the top of the editor.
Is this also fixed.
I also had to change the plugin.xml to add the class="" attribute for
the plugin tag.
If these changes are valid can these be updated on the wiki.
Regards Chhil
Re: HelloGef1 on Wiki [message #102185 is a reply to message #100647] Mon, 27 October 2003 08:06 Go to previous messageGo to next message
That's very interesting. I used the HelloGef examples to introduce myself
to GEF too and updated them to work with GEF 2.1+. (I still haven't
figured out how to get HelloGEF6 to work - the palette api seems to have
changed considerably).
I find that often (not always), regardless of the scrollbarVisibility
setting - an infinite loop will still occur when dragging items off ANY
edge of the canvas. This is evident in the Omondo UML plugin (which uses
GEF) too. However, the logic example seems fine.
I'm not really sure what setOpaque is really supposed to do...I think the
idea is that the FreeformLayer becomes concrete rather than letting the
layer below handle the mouse events etc...
If you can find out anymore, please post your findings.
The wiki is open, if you want to update it, you can.
I'm working simultaneously in Eclipse 2.0.2+GEF 2.1.0, 3.0M3+GEF 2.1.1,
Linux and Solaris motif.
Chris
Chhil wrote:
> Hello,
> by drag&drop!
> f.setOpaque(true);
> Is this also fixed.
> the plugin tag.
> Regards Chhil
Re: HelloGef1 on Wiki [message #102215 is a reply to message #102185] Mon, 27 October 2003 10:57 Go to previous messageGo to next message
Originally posted by: jpl.remotejava.com
Chris Heald wrote:
> (I still haven't figured out how to get HelloGEF6 to work - the
palette api
> seems to have changed considerably).
I just uploaded an updated version of HelloGEF6 that compiles and works
with 2.1.1. I did not really bother to ensure that I create a palette in
the "officially approved way", just took the smallest number of steps to
make it work. Better than the former broken link, I hope.
-JPL
Re: HelloGef1 on Wiki [message #102358 is a reply to message #102185] Mon, 27 October 2003 17:26 Go to previous messageGo to next message
Originally posted by: Lamont_Gilbert.Rigidsoftware.com
> myself to GEF too and updated them to work with GEF 2.1+. (I still
> haven't figured out how to get HelloGEF6 to work - the palette api seems
> the idea is that the FreeformLayer becomes concrete rather than letting
> the layer below handle the mouse events etc...
If you take a group figure for instance. i have a figure that has 2
children. the figure itself is transparent, but its children can be seen.
If I set the figure to be opaque, then you would see a bounding box,
covered by 2 other objects.
You wont notice opaque untill you start containing other figures.
CL
Re: HelloGef1 on Wiki [message #102379 is a reply to message #102185] Mon, 27 October 2003 20:17 Go to previous messageGo to next message
Originally posted by: chhil_._hotmail.com
I have not had much time to try the other examples yet. I will
definitely post my findings.
Chhil
> Thanks
> Chris
> Chhil wrote:
>>Hello,
>> by drag&drop!
>> f.setOpaque(true);
>> Is this also fixed.
>> the plugin tag.
>> Regards Chhil
Re: HelloGef6 2.1 on Wiki [message #102522 is a reply to message #102215] Tue, 28 October 2003 07:03 Go to previous messageGo to next message
Doesn't compile in Eclipse 2.0.2 (Solaris motif) since there's no
PaletteRoot.setChildren() in GEF 2.1.0.
In Eclipse 3.0M3 and GEF 2.1.1 (also solaris motif) it compiles and runs
fine.
Interestingly, I have noticed the same bug that I have in my own GEF
applciation. The connect tool (actually the marquee tool is the same in yr
Hello6) will not deactivate on a right-click. It's necessary to choose a
new tool. Do you know how to change this?
Chris
Jan Ploski wrote:
> palette api
> -JPL
Re: HelloGef6 2.1 on Wiki [message #102550 is a reply to message #102522] Tue, 28 October 2003 11:22 Go to previous message
> fine.
I think it is only important that those introductory examples work with
the current version of GEF. I can see no reason why someone introducing
herself or himself to GEF would want to do it using an older version.
You don't have to choose a new tool - you can also hit ESC. Or you could
click the left mouse button somewhere on the diagram background.
You can override ConnectionCreationTool.handleButtonUp and add the
following condition:
if (isInState(STATE_CONNECTION_STARTED) && button == 3)
setState(STATE_INVALID);
handleInvalidInput();
It seems that the intuitive 'right button cancels connection creation'
behavior is not an official feature, and that it works in the Logic
example only by coincidence because it has a context menu.
-JPL
Previous Topic:Why the selection doesn't change?
Next Topic:GEF not build with debug on?
Current Time: Sun Jul 13 23:26:30 EDT 2025
Powered by FUDForum. Page generated in 0.04099 seconds
