How to retrieve log infos. [message #9179] |
Tue, 09 October 2007 05:39  |
Originally posted by: firstname.name.gmail.com
I would like to fetch history information of a sub-versioned resource. Its
intended to be used for a plugin, so I don't want get related views: only log
information.
I looked at the org.tigris.subversion.subclipse.ui.history, and how the
FetchAllLogEntriesJob deals with it.
I am wondering what is the simplest way to make a call of such methods. Is there
any "simple" api to retrieve the logs information.
entries = getLogEntries(myURIResource);
thanks in advance.
F. Lagarde
Re: How to retrieve log infos. [message #9735 is a reply to message #9219] |
Fri, 12 October 2007 09:57  |
François,
This newsgroup is associated with the Subversive Eclipse SVN client.
From a previous post, it looks like you are using the Subclipse Eclipse
SVN client. You should probably try and find the appropriate forum/list
to post your question on the Tigris site since they provide and support
Subclipse.
Michael
François Lagarde wrote:
> In the last post, on 10/09 about 01h, "François" (François Lagarde) wrote:
> François> I was a little bit lazy. I think that I have a piece of a
> François> solution with:
> hello,
> I am still lost. I read again source of the plugins. I think that I was
> wrong, and think that the better is to use SVNClientManager. So far, I have:
> SVNProviderPlugin plugin = SVNProviderPlugin.getPlugin();
> SVNClientManager svnClientManager = plugin.getSVNClientManager();
> ISVNClientAdapter svnClient = svnClientManager.createSVNClient();
> but, eclipse rises as error that the method createSVNClient doesn't exist. This
> is odd, because both sources/classes of the subversion plugin have this method.
> any idea...
FUDForum. Page generated in 0.06021 seconds
