Home » Archived » M2M (model-to-model transformation) » [ATL] unique lazy rule
[ATL] unique lazy rule [message #100628] Tue, 24 February 2009 21:08 Go to next message
I'm trying to convert UML!Class generalizations to properties with
following simple transformation:
module GeneralizationTest;
create output : UML from input : UML;
rule p2p
from iP:UML!Package
to oP:UML!Package
name <- iP.name,
packagedElement <- iP.packagedElement->collect(c|thisModule.c2c(c))
unique lazy rule c2c
from iC:UML!Class
to oC:UML!Class
name <- iC.name
do
('iC.name = '+iC.name).println();
oC.ownedAttribute <- iC.superClass->collect(sc|thisModule.sc2p(sc));
unique lazy rule sc2p
from c:UML!Class
to p:UML!Property
name <- 'base',
type <- thisModule.c2c(c)
But for a model input with one Base and one Derived class i get following
output:
<uml:Package xmi:id="_2TkbgALdEd6Xf7QB_xMJXw" name="input">
<packagedElement xmi:type="uml:Class" xmi:id="_2TkbgQLdEd6Xf7QB_xMJXw"
name="Base"/>
<packagedElement xmi:type="uml:Class" xmi:id="_2TkbggLdEd6Xf7QB_xMJXw"
name="Derived">
<ownedAttribute xmi:id="_2TkbgwLdEd6Xf7QB_xMJXw" name="base"
type="_2TkbhALdEd6Xf7QB_xMJXw"/>
</packagedElement>
</uml:Package>
<uml:Class xmi:id="_2TkbhALdEd6Xf7QB_xMJXw" name="Base"/>
(Base class is dubled, one is where it should be, and one outside package,
type od 'base' property of 'Derived' class is set to the one outside of
package)
Also executing transformation gives following console output:
iC.name = Base
iC.name = Derived
iC.name = Base
isn't 'unique lazy rule c2c' supposed to be executed only once for a given
input model element?
Am I missing something?
Matt
Re: [ATL] unique lazy rule [message #100657 is a reply to message #100628] Wed, 25 February 2009 03:07 Go to previous messageGo to next message
Hi Matt
why do you use call rule in your rule c2c ?
you cand o do :
from iC:UML!Class
to oC:UML!Class
name <- iC.name,
ownedAttribute <-
do
maybe this is the cause of your problem. we never know when do section
are performed it's not very recommended to use it
Matt Fomr a écrit :
> Hi
> rule p2p
> from iP:UML!Package
> to oP:UML!Package
> name <- iP.name,
> from iC:UML!Class
> to oC:UML!Class
> name <- iC.name
> do
> from c:UML!Class
> to p:UML!Property
> name <- 'base',
> following output:
> xmi:id="_2TkbgQLdEd6Xf7QB_xMJXw" name="Base"/>
> xmi:id="_2TkbggLdEd6Xf7QB_xMJXw" name="Derived">
> </packagedElement>
> </uml:Package>
> package, type od 'base' property of 'Derived' class is set to the one
> outside of package)
> iC.name = Base
> iC.name = Derived
> iC.name = Base
> given input model element?
> Regards
> Matt
Re: [ATL] unique lazy rule [message #100671 is a reply to message #100657] Wed, 25 February 2009 05:30 Go to previous messageGo to next message
sorry i didn't want to say "call rule" but
why do you use a do section in your rule c2c ?
Tristan FAURE a écrit :
> Hi Matt
> you cand o do :
> from iC:UML!Class
> to oC:UML!Class
> name <- iC.name,
> ownedAttribute <-
> do
> Matt Fomr a écrit :
>> Hi
>> rule p2p
>> from iP:UML!Package
>> to oP:UML!Package
>> name <- iP.name,
>> packagedElement <-
>> from iC:UML!Class
>> to oC:UML!Class
>> name <- iC.name
>> do
>> from c:UML!Class
>> to p:UML!Property
>> name <- 'base',
>> following output:
>> </packagedElement>
>> </uml:Package>
>> outside of package)
>> iC.name = Base
>> iC.name = Derived
>> iC.name = Base
>> Regards
>> Matt
Re: [ATL] unique lazy rule [message #100685 is a reply to message #100657] Wed, 25 February 2009 05:33 Go to previous message
I use call rule in c2c because i want result of sc2p to stay accesible for
later use (not part of sample transformation), so sc2p has to be 'unique
lazy'.
Moving assignment to ownedAttribute from 'do' section to 'bindings'
section chanches only console output:
iC.name = Base
iC.name = Base
iC.name = Derived
Output model is the same..
Previous Topic:MtATL2009 CfP
Next Topic:[ATL] Progress monitor
Current Time: Sat Jul 26 18:01:35 EDT 2025
Powered by FUDForum. Page generated in 0.03447 seconds
