Consistent paths...HOW!? [message #820996] |
Wed, 14 March 2012 16:39 |
I am using Eclipse 3.7.2 and Cygwin 1.7.11 under Windows 7. My question is simple, but after spending hours searching, I don't believe the answer will be. I simply want to find a way to use consistent paths with this setup. By this, I either want to always use the Unix style or the Windows/DOS style. It seems throughout this setup, it is potluck as to which one needs to be used.
In the build settings, I have to use the Unix style for things like include paths so gcc can find the includes, but then the IDE cannot find the includes and constantly underlines them with the yellow squiggly line.
If I try to link a folder, Eclipse seems to only use the Windows/DOS style absolute paths, but when the make files are generated, they contain the Windows/DOS style absolute paths which causes make to blow up. I have updated to make 3.82.90 which does not fix the problem.
Any help would be greatly appreciated!
Chance
FUDForum. Page generated in 0.24563 seconds
