Home » Eclipse Projects » Equinox » How to reference Bundle Service in web resource like JSP, Servlet?
How to reference Bundle Service in web resource like JSP, Servlet? [message #100497] Mon, 29 October 2007 02:03 Go to next message
Originally posted by: lifesting.gmail.com
I created a bundle and bound a service *SmsService* on it's context,
below is the class body:
public class Activator implements BundleActivator {
private ServiceRegistration serviceReg;
public void start(BundleContext context) throws Exception {
SmsService service = xxx;
serviceReg = context.registerService(SmsService.class.getName(),
service,new Hashtable());
public void stop(BundleContext context) throws Exception {
serviceReg.unregister();
I also created a Servlet in this bundle, in which there's a method
invocation on the registered service above:
public class SendMessageServlet extends HttpServlet {
protected void doPost(HttpServletRequest req,
HttpServletResponse resp)
throws ServletException, IOException {
SmsService sms = ....//Get the registered service
sms.sendMessage(XXX);
The only valid method after try is to add a field references
BundleContext and set it's value in Servlet constructor:
private BundleContext context;
public SendMessageServlet(BundleContext context)
this.context =context;
As you see, this way need every Servlet import Bundle explicitly, is
there a more elegant method?
Thanks a lot!
Re: How to reference Bundle Service in web resource like JSP, Servlet? [message #100632 is a reply to message #100497] Tue, 30 October 2007 08:54 Go to previous messageGo to next message
> Thanks a lot!
David,
There a no *special elegant* way to do that.
Of course you can supress importing Bundle explicitly by setting the
service directly. Then only the Activator holds the BundleContext and
calls bind/unbind on the servlet (if your service is dynamic).
I prefer this approach.
public class MyServlet ...... {
private IFooService fooService;
bindFooService(IFooService fooService) {
unbindFooService(IFooService fooService) {
if(fooService == null {
// some strategy to handle this situation
// do something with fooService
Re: How to reference Bundle Service in web resource like JSP, Servlet? [message #101262 is a reply to message #100497] Wed, 07 November 2007 20:59 Go to previous message
Originally posted by: bob.yang.unison.net.cn
Hello David,
I have the similar issue, because I want to use the
'org.eclipse.equinox.http.registry' bundle to registry servlet by using
eclipse extension point mechanism. But I can not find a way to supply
BundleContext object to my servlet when using
'org.eclipse.equinox.http.registry' bundle.
any idea?
> req, HttpServletResponse resp)
> Thanks a lot!
Previous Topic:How to append classpath to other bundles?
Next Topic:Adding/replacing classloader
Current Time: Mon Jul 21 22:22:44 EDT 2025
Powered by FUDForum. Page generated in 0.04760 seconds
