Home » Archived » Maven Integration (M2E) » m2eclipse 0.9.2 released
m2eclipse 0.9.2 released [message #790] Mon, 14 April 2008 12:08 Go to next message
m2eclipse team is glad to announce 0.9.2 release. This release
includes several fixes for issues found in previous version as well as
additional fixes in the Maven embedder.
There is also few new features:
Support Workspace resolution for launching Maven, which allows
debugging Maven plugins and other projects without installing into local
Maven repository and works for external Maven installations.
Added integration for Maven SCM to allow checking out and
materializing Maven and Eclipse projects from CVS, SVN, Mercurial, Git,
Perforce, VSS and other SCM systems supported by Maven SCM.
Extended SCM extension point and introduced new unified "Checkout
Maven projects from SCM" wizard.
Full "New and Noteworthy" list is available on the wiki [1].
You can install new version from the project update site [2].
As before, we would like to thank everyone who tested previous
versions, submitted bug reports, test projects and patches.
regards,
Eugene
[1] http://docs.codehaus.org/display/M2ECLIPSE/New+and+Noteworth y
[2] http://m2eclipse.sonatype.org/update/
Re: m2eclipse 0.9.2 released [message #828 is a reply to message #790] Tue, 15 April 2008 06:14 Go to previous messageGo to next message
Originally posted by: morten.bilpriser.dk
When I choose:
Help -> Software Updates -> Manage Configuration ->
Maven Integration...-> Scan for updates, Eclipse says:
"No updates for the currently installed features(s) found, try again later."
If I choose:
Help -> Software Updates -> Find and Install.. ->
and choose m2eclipse site it shows the 0.9.2 version, but I'd rather not
uninstall the old one and then install the new one.
Is there a way to update the plugin easily?
Morten Knudsen
"Eugene Kuleshov" <eu@md.pp.ru> skrev i en meddelelse
news:ftvvin$ci4$1@build.eclipse.org...
> As before, we would like to thank everyone who tested previous versions,
> regards,
> Eugene
Re: scan for updates [message #858 is a reply to message #828] Tue, 15 April 2008 13:05 Go to previous messageGo to next message
Morten wrote:
> When I choose:
> If I choose:
I recommend to always use "Find and Install", because old Eclipse
Update Manager had several of bugs around checking for updates. You
don't have to uninstall anything and it is safe to always use "Find and
Install".
New update manager that been rolled in Eclipse 3.4m6 supposed to fix
those issues, but currently it has few issues of its own that should be
addressed in 3.4m7.
regards,
Eugene
Re: scan for updates [message #888 is a reply to message #858] Wed, 16 April 2008 04:27 Go to previous message
Ok, thanks
news:fu2n8j$ks$1@build.eclipse.org...
> Morten wrote:
>> When I choose:
>> later."
>> If I choose:
> I recommend to always use "Find and Install", because old Eclipse Update
> Manager had several of bugs around checking for updates. You don't have to
> uninstall anything and it is safe to always use "Find and Install".
> addressed in 3.4m7.
> regards,
> Eugene
Previous Topic:Welcome to eclipse.technology.m2e
Next Topic:Importing legacy artifacts Into M2 Repository from Eclipse
Current Time: Mon Nov 17 23:51:21 EST 2025
Powered by FUDForum. Page generated in 0.03544 seconds
