Home » Newcomers » Newcomers » WebStart - Where are my *.jar files?
WebStart - Where are my *.jar files? [message #100348] Thu, 08 September 2005 06:52 Go to next message
I tried to learn more about JAVA WebStart, and have a question. I
successfully created a HelloWorld application using Eclipse 3.0.
I also got the JAVA WebStart running for my application. If I install now
this application via WebStart (offline allowed) on another machine (just JRE
installed) I can run it successfully.
Now I want to find the JAR file of my application on that machine. If I do a
local search for that JAR file there is no result. It seems this JAR file
does not exist on that machine, even I can execute my application using
WebStart (online AND offline).
So where is the JAR file located? Is it compressed and in hidden in another
file / another filetype?
Thanks for any help!
I found out something, but... [message #100364 is a reply to message #100348] Thu, 08 September 2005 07:52 Go to previous messageGo to next message
I found out, that one can find the JAR files after one created a Desktop
link using the WebStart Console.
Then under C:\Documents and Settings\UserNAme\Application
Data\Sun\Java\Deployment\cache\javaws\http\D192.168.1.1\P80\ DMapps appear
the files, but with different filenames.
e.g. myapp.jar will become RMmyapp.jar and a 2nd file is created
RTmyapp.jar.
So far I found out.
If you don't create a link to the desktop, one cannot find those files
separately. So my questions are:
1. Where are those files if you don't create a desktop link? Are they hidden
(compressed) in some typical WebStart file?
2. Why all JAR files appear twice and are renamed (RM* and RT*) ?
Any help would be appreciated, thanks a lot!
Re: I found out something, but... [message #100404 is a reply to message #100364] Thu, 08 September 2005 09:26 Go to previous message
Originally posted by: hcs33.egon.gyaloglo.hu
Java Web Start is a technology which enable you the following features:
- web based client application install
- automatic version checks and updates for the application
- a sandbox to run your application within
If you want to learn about more for this topic you should start on the java
web start page: http://java.sun.com/products/javawebstart/. The white paper
give you a lot of information about this technology.
I think that files in the cache with RT... prefixes contains some computed
codes which helps jws to decide if the cached version is up-to-date (you can
see its content, it is not a jar but a plain text file). Typically an
end-user who uses your application do need to know nothing about these files
(they are always cached within the ...\cache\javaws directory afaik).
HTH,
Csaba
Mr. Burns wrote:
> Hello,
> RTmyapp.jar.
> So far I found out.
> hidden (compressed) in some typical WebStart file?
Previous Topic:Getting external JARs to build into my own JAR
Next Topic:Plugins for SQL, HTML, XML etc?
Current Time: Fri Jul 18 17:54:44 EDT 2025
Powered by FUDForum. Page generated in 0.10496 seconds
