Home » Eclipse Projects » Remote Application Platform (RAP) » Close RAP Application
Close RAP Application [message #100343] Mon, 28 July 2008 10:10 Go to next message
Am facing couble problem when i try to close RAP application.
1: when I close the application using file -> exit , the browser throw an
exeption:
HTTP ERROR: 500
Internal Server Error
RequestURI=/rap
**notes: no exception thrown in the console or workspace log.
2: Same exception is also thrown when refresh the browser , although that
the confirmation dialog is asking if i want to leave the session.
3: In my application I have a login shell before creating the application
workbench, is it possible when i close the application to return back to
the login shell.
any help
Salwa
Re: Close RAP Application [message #100611 is a reply to message #100343] Tue, 29 July 2008 05:04 Go to previous messageGo to next message
Originally posted by: fappel.innoopract.com
what are you doing in the exit code?
Ciao
Frank
-----Ursprüngliche Nachricht-----
Von: Salwa [mailto:salwa.moh@gmail.com]
Bereitgestellt: Montag, 28. Juli 2008 16:10
Bereitgestellt in: eclipse.technology.rap
Unterhaltung: Close RAP Application
Betreff: Close RAP Application
an
exeption:
HTTP ERROR: 500
RequestURI=/rap
that
application
the login shell.
any help
Salwa
Re: Close RAP Application [message #100705 is a reply to message #100611] Tue, 29 July 2008 07:37 Go to previous messageGo to next message
I just registered the Exit action in the Actionbaradvisor:
exitAction = ActionFactory.QUIT.create(window);
register(exitAction);
and in the ApplicationWorkbenchWindowAdvisor i override the
preWindowShellClose method:
IWorkbenchWindowConfigurer configurer = getWindowConfigurer();
boolean
answer=MessageDialog.openConfirm(configurer.getWindow().getS hell(),
"Confirm Platform Exit", "Are you sure you want to exit?");
if (answer == true) {
return true;
return false
However, when I debug it, I found that this method is never called.
Salwa
Re: Close RAP Application [message #100719 is a reply to message #100705] Tue, 29 July 2008 08:42 Go to previous messageGo to next message
the overridden WorkbenchWindowAdvisor#preWindowShellClose method is
indeed never called, which from my current point of view I would
consider to be a bug. But nevertheless I could not reproduce the problem
using the ActionFactory#QUIT action.
With the RAP version in my workspace (== CVS-Head) the workbench window
closes and only the blue-white background is visible. After pressing F5
the session restarts with a new workbench window.
So it's difficult to say what's happening. As you report an Internal
Server Error you may try to set an Java Exception Breakpoint to nail
down the problem in debug mode.
Ciao
Frank
Bereitgestellt: Dienstag, 29. Juli 2008 13:38
Betreff: Re: Close RAP Application
boolean
return true;
return false
Salwa
Re: Close RAP Application [message #101389 is a reply to message #100719] Wed, 06 August 2008 13:33 Go to previous messageGo to next message
Hi Frank,
I debug my application , and when I refresh the browser I capture these
info:
this org.eclipse.rwt.internal.service.ServiceContext@ad8f2b
disposed true
request null
response null
sessionStore null
stateInfo null
UIThread(Thread).dispatchUncaughtException(Throwable) line: not available
this Thread[UIThread [1xt7wh81cykbx],6,main]
arg0 java.lang.IllegalStateException: The context has been disposed.
cause java.lang.IllegalStateException: The context has been disposed.
detailMessage The context has been disposed.
stackTrace null
I got this Exceptin in My console:
Exception in thread "UIThread [1xt7wh81cykbx]"
java.lang.IllegalStateException:The context has been disposed.
org.eclipse.rwt.internal.service.ServiceContext.checkState(S erviceContext.java:154)
org.eclipse.rwt.internal.service.ServiceContext.getStateInfo (ServiceContext.java:104)
org.eclipse.rwt.internal.service.ContextProvider.getStateInf o(ContextProvider.java:165)
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle$UIThreadCont roller.run(RWTLifeCycle.java:133)
at java.lang.Thread.run(Unknown Source)
ANy help to fibure of what is missing ,, and why am geting this exception
Salwa
Re: Close RAP Application [message #101504 is a reply to message #101389] Thu, 07 August 2008 04:57 Go to previous message
I'm really sorry, but as I can't reproduce the problem on my machine I
have no clue what's going on. Maybe you're able to strip the problem
down to a little demo project that you can attach to a post so that I
can have a look at it?
Ciao
Frank
Bereitgestellt: Mittwoch, 6. August 2008 19:33
Hi Frank,
info:
disposed true
request null
response null
sessionStore null
stateInfo null
available
disposed.
stackTrace null
t.java:154)
ext.java:104)
vider.java:165)
exception
Salwa
Previous Topic:RAP 1.2 ???
Next Topic:Browser Memory Usage
Current Time: Sat Jul 19 20:24:00 EDT 2025
Powered by FUDForum. Page generated in 0.04471 seconds
