| [QVTO] Getting Started. [message #100265] |
Wed, 18 February 2009 11:21  |
I'm new to vqt. I'm trying to run a (very) simple transformation of an
ecore model to another ecore model. I'm sorry to bother with that newbe
issue, but i already spent some time on it and have no clue how to resolve
it.
Here are my models:
input model:
<ecore:EPackage xmi:version="2.0"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="input"
nsURI="http://dot.com/input/1.0" nsPrefix="input">
<eClassifiers xsi:type="ecore:EClass" name="InputModel">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="name"
eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="element"
upperBound="-1"
eType="#//Element" containment="true"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Element"/>
</ecore:EPackage>
output model:
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="output"
nsURI="http://dot.com/output/1.0" nsPrefix="output">
<eClassifiers xsi:type="ecore:EClass" name="OutputModel">
<eStructuralFeatures xsi:type="ecore:EReference" name="box"
upperBound="-1" eType="#//Box"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Box"/>
</ecore:EPackage>
And the transformation looks like that:
modeltype IN uses 'platform:/resource/input/model/input.ecore';
modeltype OUT uses 'platform:/resource/output/model/output.ecore';
transformation TransformationSample(in imodel : IN, out OUT);
main() {
imodel.rootObjects()[IN::InputModel] ->map model2model();
mapping IN::InputModel::model2model() : OUT::OutputModel {
name := self.name;
box := self.getElements()->map simple2annotated()->asOrderedSet();
mapping IN::Element::simple2annotated () : OUT::Box {
query IN::InputModel::getElements() : OrderedSet(IN::Element) {
return self.element[IN::Element]->asOrderedSet()
I'm not sure my model2model() mapping is correct, but even if I comment
it's code, my transformation should at least produce an instance of the
output.ecore meta-model with at least a OutputModel EClass in it. And this
is not the case:
Input instance:
<input:InputModel xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:input="http://dot.com/input/1.0" name="Names">
<element/>
<element/>
</input:InputModel>
output result instance:
<xmi:XMI xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"/>
The result is even not an instance of the output meta-model.
If you have an idea on what i'm doing wrong, i'd be very much appreciate.
Thank you in advance.
| Re: [QVTO] Getting Started. [message #100308 is a reply to message #100265] |
Thu, 19 February 2009 05:53  |
Hi Alexei,
There is no guarantee that your output will always contain an object which
is
instance of a class of your out metamodel, unless you create it.
Your mapping looks fine, but I suspect the input selection query to give
no input objects,
as the transf refers to a type which is not identical to the one in your
input model.
Your input and output seem to contain instances of the java generated
metamodels
while your transf refers to metamodels by location of the corresponding
ecore files.
I suggest you refer to metamodels by identity, using the nsURI attribute
value
modeltype IN uses 'http://dot.com/input/1.0';
modeltype OUT uses 'http://dot.com/output/1.0';
and add mapping of nsURI to location URI at the following property page of
your
QVT project - 'QVT Settings/Metamodel mappings'.
By doing so, you will have your transf resolve to ecore files in
development time,
while in deployment time the generated metamodels will used.
/Radek
On Wed, 18 Feb 2009 17:21:29 +0100, Alexei
<alexei.klioutchnikov@gmail.com> wrote:
> Hello,
> resolve it.
> Here are my models:
> input model:
> upperBound="-1"
> </eClassifiers>
> </ecore:EPackage>
> output model:
> </eClassifiers>
> </ecore:EPackage>
> transformation TransformationSample(in imodel : IN, out omodel : OUT);
> main() {
> name := self.name;
> this is not the case:
> Input instance:
> <element/>
> <element/>
> </input:InputModel>
FUDForum. Page generated in 0.03046 seconds
