Home » Archived » BIRT » newbie question -- simple report
newbie question -- simple report [message #100258] Sun, 18 December 2005 13:55 Go to next message
Originally posted by: garry.espe.chsinc.com
I have installed BIRT 1.0.1, and have configured it to use a db2 v8.1
database. So far so good. Next, I designed a simple 2-column report.
The dataset is bound to the table. The dataset sql is a simple select
statement, selecting 2 columns from a table. The "Preview Results" option
in the dataset configuration panel yields the handful of rows I expect to
see.
When I click on the Preview tab in the report design view, this error
appears:
There are errors on the report page:
+ There are error(s) in Table:table1
The report and column headings appear, but the data columns are emtpy.
Is there a log file containing more details about the error? And what is
table1?
Re: newbie question -- simple report [message #100377 is a reply to message #100258] Mon, 19 December 2005 04:34 Go to previous messageGo to next message
when U click '+' U will see what cause the problem.
Uzytkownik "garry espe" <garry.espe@chsinc.com> napisal w wiadomosci
news:d82d5f8820c44b77b3cb426c05d23005$1@www.eclipse.org...
> see.
> appears:
> table1?
Re: newbie question -- simple report [message #100486 is a reply to message #100377] Mon, 19 December 2005 14:54 Go to previous message
Thanks for the tip. Actually I feel a bit sheepish. Its obvious, now,
that I should have clicked the '+' symbol. The detailed message reveal a
problem with the jdbc drivers. A diligent search of the faq revealed that
I needed to copy the jdbc driver jars to the report viewer folder. Voila!
The report works!
Previous Topic:comments on 2.0 m2
Next Topic:instancing a java class
Current Time: Sat Jul 19 02:07:50 EDT 2025
Powered by FUDForum. Page generated in 0.04490 seconds
