Home » Archived » Test and Performance Tools Platform (TPTP) » [tptp-4.3.1] IWAT4039E connection refused... / InactiveProcessException
[tptp-4.3.1] IWAT4039E connection refused... / InactiveProcessException [message #100227] Tue, 05 June 2007 15:28 Go to next message
Originally posted by: bmf1972.fastmail.fm
Hi all,
I am trying TPTP 4.3.1 with the new RAC and getting this error IWAT4039E
The Test Execution Harness reported the following problems:Connection
refused on host localhost.
I have tried the following:
1) The sampleclient.exe works as expected on my WinXP machine.
2) The Profiling and Logging > Hosts "Test Connection" returns
"Connection success" on the localhost:10002 connection.
3) Used a tcp monitor and it seems that the two processes (javaw.exe
spawned by eclipse.exe and ACServer.exe) actually are establishing a
connection.
Also tried to use the IAC:
1) Turned off the RAC
2) Restarted Eclipse
3) Tested the "Local Direct Connection"
4) Launched the test and got this error:
IWAT4039E The Test Execution Harness reported the following
problems:org.eclipse.hyades.internal.execution.local.control .InactiveProcessException
Any suggestion(s)?
Adrian.
Re: [tptp-4.3.1] IWAT4039E connection refused... / InactiveProcessException [message #100338 is a reply to message #100227] Wed, 06 June 2007 05:27 Go to previous messageGo to next message
Hi Adrian,
You can try a last stable build of TPTP 4.4 version - runtime and Agent
Controller.
Igor
Re: [tptp-4.3.1] IWAT4039E connection refused... / InactiveProcessException [message #100351 is a reply to message #100338] Wed, 06 June 2007 05:40 Go to previous messageGo to next message
I need it to run under Eclipse SDK 3.2.0 :-(
Igor Alelekov wrote:
> Hi Adrian,
> Controller.
> Igor
Re: [tptp-4.3.1] IWAT4039E connection refused... / InactiveProcessException [message #100362 is a reply to message #100338] Wed, 06 June 2007 08:06 Go to previous messageGo to next message
Its an option on the monitor tab for execution statistcs. Eclipse 3.2
something. TPTP 4.2.1
Re: [tptp-4.3.1] IWAT4039E connection refused... / InactiveProcessException [message #100378 is a reply to message #100362] Wed, 06 June 2007 08:07 Go to previous message
my bad...responded to the wrong entry
Previous Topic:[tptp-4.3.1] IWAT4039E connection refused... / InactiveProcessException
Next Topic:collect method cpu time option
Current Time: Sun Aug 31 21:01:48 EDT 2025
Powered by FUDForum. Page generated in 0.04516 seconds
