Multiple graphical elements representing the same semantic element [message #100211] |
Thu, 01 February 2007 12:35 |
Originally posted by: christian.daenekas.informatik.uni-oldenburg.de
this is possibly a very simple question, but I didn´t find any solution
yet. I´ve got elements in my semantic model that are used several times
in my editor (multiple creation tools and graphical nodes). The semantic
elements have multiple properties. What I want to achieve is that the
properties view only shows the relevant properties when clicking on a
special graphical representation of it. The rest of the properties
should not show up in the properties view so the user cannot alter them.
Do I have to modify the diagram code to get this behaviour? Further I
want to know if its possible to get properties with an "empty" property
value out of the stored xml file (example: I want to get <element
property1="test" /> instead of <element property1="test" property2=""
/>). The unwanted behavior (property2="") results of deleting a
previously set property value. Thank you for your help.
Greetings,
Christian
FUDForum. Page generated in 0.06925 seconds
