Home » Eclipse Projects » Subversive » Folder 'Compare With' feature
Folder 'Compare With' feature [message #9134] Wed, 03 October 2007 22:51 Go to next message
Is the 'Compare With' feature planned for a folder?
In eclipse CVS plugin it is very convenient to be able to compare 2
folders. I'm really missing this feature with the subversive plugin.
Francois
Re: Folder 'Compare With' feature [message #9894 is a reply to message #9134] Tue, 30 October 2007 07:45 Go to previous messageGo to next message
Originally posted by: alexander.gurov.polarion.org
The "Compare With" feature will be available in the Subversive together
with the SVN 1.5 support because only SVN 1.5 version will provide
corresponding API's.
Re: Folder 'Compare With' feature [message #10878 is a reply to message #9894] Wed, 31 October 2007 01:46 Go to previous messageGo to next message
Thanks for your reply.
Do you any schedule or planned release date for this support? I can't
find any clue on the following page:
http://www.polarion.org/index.php?page=roadmap&project=s ubversive
Francois
Re: Folder 'Compare With' feature [message #10892 is a reply to message #10878] Wed, 31 October 2007 06:49 Go to previous messageGo to next message
Hello Francois,
Schedule for SVN 1.5 features support highly depends on the date of SVN 1.5
release. According to information, which we have now, SVN 1.5 release
planned for the end of the year. So we assume that SVN 1.5 features will
appear in Subversive closely to this date too.
Igor Vinnykov
"Francois Cottet" <fct.java@gmail.com> ???????/???????? ? ????????
?????????: news:fg94oo$g7v$1@build.eclipse.org...
> Do you any schedule or planned release date for this support? I can't find
> Francois
Re: Folder 'Compare With' feature [message #21424 is a reply to message #10892] Tue, 17 June 2008 08:49 Go to previous messageGo to next message
Originally posted by: michaelpeter.weichselbaumer.ntswincash.com
Hello Igor,
Some time has passed and I'm trying to compare my head revision to a
branch revision (or the other way) without having to indicate the exact
file but only the branch it should be compared to. This seems not to work.
Is this feature going to be implemented or isn't it?
Re: Folder 'Compare With' feature [message #21430 is a reply to message #21424] Tue, 17 June 2008 14:57 Go to previous messageGo to next message
Hello Michael,
Support of folder comparision already implemented for SVN 1.5 compatible
connectors. So, in order to use it please install latest Subversive
version (Main plug-in version: 0.7.1.I20080612-1500, Connectors version:
2.0.1.I20080612-1500) then go to Window->Preferences->Team->SVN->SVN
Connector tab and select SVN 1.5-compatible connector (one of SVN Kit
1.2.0 or Native JavaHL 1.5.0).
Re: Folder 'Compare With' feature [message #21445 is a reply to message #21430] Wed, 18 June 2008 09:24 Go to previous messageGo to next message
Hello Alexander,
I already installed the versions you mentioned but it doesn't seem to
work. Comparing takes endlessly long and when done it just compares the
file I want to compare with branch-folder.
Re: Folder 'Compare With' feature [message #21461 is a reply to message #21445] Thu, 19 June 2008 04:30 Go to previous messageGo to next message
Could you please provide exact steps to reproduce the problem?
Re: Folder 'Compare With' feature [message #21624 is a reply to message #21461] Fri, 20 June 2008 03:19 Go to previous messageGo to next message
Yes of course.
Let's say I'm working on my trunk and I want to compare the changes that I
made to an older branch, probably for overtaking these changes.
So I click on the java-File in my package explorer and open the context
menu.
Compare with -> Branch. Then I click the "Browse" Button to select a
branch folder or I select one of the previouly browsedd branches from the
dropdown list.
When I click "OK" comparison takes edges ending up in a crash of my
Eclipse or a comparison to the branch-folder itself.
I'm using SVN Kit 1.2.0 and my Subversion server version is 1.5.. .
Re: Folder 'Compare With' feature [message #24289 is a reply to message #21624] Thu, 03 July 2008 10:10 Go to previous messageGo to next message
Originally posted by: michael.weichselbaumer.ntswincash.com
Michael Weichselbaumer wrote:
> Yes of course.
> menu.
> dropdown list.
Hello?
Re: Folder 'Compare With' feature [message #24371 is a reply to message #24289] Thu, 03 July 2008 11:41 Go to previous message
Hello Michael,
Sorry for skipping your message. Really your case looks similar to problem
described here:
233630: "Compare with branch" fails because of wrong URL
https://bugs.eclipse.org/bugs/show_bug.cgi?id=233630
Previous Topic:Why isn't merge finding any changes?
Next Topic:3.4 (Mac) very slow to show right-click (context) menu - SVN* present in call trace
Current Time: Mon Jul 21 21:41:58 EDT 2025
Powered by FUDForum. Page generated in 0.06931 seconds
