Home » Language IDEs » Java Development Tools (JDT) » CVS, Stellation, SourceSafe or ClearCase plug-ins...
CVS, Stellation, SourceSafe or ClearCase plug-ins... [message #9127] Tue, 29 April 2003 17:00 Go to next message
I need to choose which source code manager/repository for a small project.
Any ideas on which Eclipse plug-in is the mose stable? I like the concepts
behind Stellation, but I can't find much recent news on the project...
Shane
Re: CVS, Stellation, SourceSafe or ClearCase plug-ins... [message #9792 is a reply to message #9127] Wed, 30 April 2003 10:51 Go to previous messageGo to next message
Stellation is still in "pre-alpha"stage so is not probably a good candidate
for a production environment just yet.
Jonathan Gossage
"Shane J. Eaker" <eakersj@yahoo.com> wrote in message
news:b8mp51$pe6$1@rogue.oti.com...
concepts
> Shane
Re: CVS, Stellation, SourceSafe or ClearCase plug-ins... [message #10936 is a reply to message #9127] Thu, 01 May 2003 09:30 Go to previous messageGo to next message
Originally posted by: heiko.dittrich.informatik.uni-oldenburg.de
we use the ClearCase plug-in for 5 month now and can recommend it. The
current version is very stable.
Greetings,
Heiko Dittrich
> Shane
Re: CVS, Stellation, SourceSafe or ClearCase plug-ins... [message #11057 is a reply to message #10936] Thu, 01 May 2003 14:59 Go to previous messageGo to next message
Originally posted by: neil.neil.swingler.name
"Heiko Dittrich" <heiko.dittrich@informatik.uni-oldenburg.de> wrote in
message news:b8r7ig$s0h$1@rogue.oti.com...
> Hello,
Do you mean the Rational one or Matt Conway's eclipse-ccase plugin.
Personally I would recommend Matt's plugin over Rational's. It properly
supports moving directories while refactoring and works on Unix.
On the other hand Clearcase dynamic views can be problematic. See:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=16280
- Neil Swingler
Re: CVS, Stellation, SourceSafe or ClearCase plug-ins... [message #14560 is a reply to message #9127] Mon, 05 May 2003 22:04 Go to previous messageGo to next message
Originally posted by: ed.burnette.REMOVE.THIS.sas.com
The CVS integration works pretty well for me, even on some large projects.
There are a few missing features but probably nothing you can't live
without. We did have a problem with the "ext" connection method but
switching to "pserver" solved it.
Depending on your definition of a "small project" though you might not need
this. Eclipse has a handy local history feature that would work ok for one
developer's short term memory of changes. Right click on a resource and
select Compare with > Local history to see it. The length of time changes
are retained is configurable in the Preferences window. Add some backups and
you're in business.
Another option is SourceForge, if you can make it an open source project.
They provide free hosted CVS servers and disk space for you.
Ed Burnette, co-author Eclipse in Action (www.manning.com/gallardo)
concepts
Re: CVS, Stellation, SourceSafe or ClearCase plug-ins... [message #14912 is a reply to message #11057] Tue, 06 May 2003 07:02 Go to previous message
>>Hello,
> - Neil Swingler
Sorry, we use the Rational one on a very large project. We do not use
dynamic views.
Previous Topic:java editor formatting problem
Next Topic:CVS problem
Current Time: Sun Aug 31 19:41:05 EDT 2025
Powered by FUDForum. Page generated in 0.04090 seconds
