Problem solved... [message #100105] |
Mon, 19 April 2004 01:51  |
I did a blunder ,compiled C++ program with gcc...
After compiling with g++ the problem was rectified.
But I need some help to create " C/C++....Managed Make " project.
Kindly help me in this regard.
Thanks.
Ragav
Re: Problem solved... [message #100242 is a reply to message #100105] |
Mon, 19 April 2004 13:56  |
Ragav,
The information you have provided us is not sufficient to help you.
There are a number of previous threads that have dealt with project
creation and "I am a new user, please help me" type questions. Why not
do a quick search to see if anyone else has had a similar problem. There
is an FAQ that lists the supported platforms. Maybe you could start
there and see if the platform you are hosting Eclipse on will work. If
all that fails, try to think of the kind of information you might need
to solve a problem like this and provide it along with your question
(like you did with the compiler output). A good starting point is the
telling us the OS, a dump of the environment variables, and the last
entries in the <workspace>/.metadata/.log file.
Sean
Ragav wrote:
> Hello,
> Thanks.
> Ragav
FUDForum. Page generated in 0.06892 seconds
