Home » Archived » Visual Editor (VE) » Some problems with the VE 1.1 and Eclipse 3.1
Some problems with the VE 1.1 and Eclipse 3.1 [message #100065] Tue, 26 July 2005 02:57 Go to next message
hello,
first i have to thank you for your great work! the new VE is really good!!!
but i have got some problems with it - i hope you can help me:
1) i have a swt shell which is shown correctly - when running in eclipse.
But if i load it in the ve, the editor doesn't show the content of my
Label...
_the code:_
dlScreen = new Label (CSvisiblecrmWelcomeScr,SWT.LEFT );
dlScreen.setBounds(new org.eclipse.swt.graphics.Rectangle(0, 0,(int)
(810), (int) (24)));
dlScreen.setFont(new
Font(org.eclipse.swt.widgets.Display.getDefault(),"MS Sans
Serif",16,SWT.BOLD));
dlScreen.setText("this is just an example");
the VE shows me the border of the Label but unfortunately it does not
show the "this is just an example" text...
2) another shell which is loading in the ve even doesn't start at all.
the editor throws the message that there is a
java.lang.NullPointerException. "Error trying to set new file into
editor". - the screen is blank.
-> but some of my other files runs without any problems...
so i hope you can help me
thanks
Flik
Re: Some problems with the VE 1.1 and Eclipse 3.1 [message #100098 is a reply to message #100065] Tue, 26 July 2005 05:49 Go to previous messageGo to next message
Hi Flik,
(1) I was able to load the following code without any problems. Do you
see any exceptions/messages in the logs? Which layout is the shell in?
public class Empty1 {
private Shell sShell = null; //
@jve:decl-index=0:visual-constraint="22,30"
private Label dlScreen = null;
private void createSShell() {
sShell = new Shell();
sShell.setSize(new org.eclipse.swt.graphics.Point(172,133));
dlScreen = new Label (sShell,SWT.LEFT );
(2) Do you see any exceptions/messages in the logs? Is this in the same
project as the above file which seems to atleast load?
Sri.
Flik wrote:
> hello,
> Label...
> _the code:_
> thanks
> Flik
Re: Some problems with the VE 1.1 and Eclipse 3.1 [message #100141 is a reply to message #100098] Tue, 26 July 2005 06:51 Go to previous messageGo to next message
Sri Gunturi schrieb:
> Hi Flik,
> 0,(int) (810), (int) (24)));
(1) very strange: your code runs well.
so please try this file, where the error occures. the ve only shows the
borders of the widgets...
filename: crmLogin.java
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.TabFolder;
import org.eclipse.swt.widgets.TabItem;
import org.eclipse.swt.widgets.Text;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Label;
import org.eclipse.swt.widgets.Combo;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.SWT;
import org.eclipse.swt.graphics.Font;
import org.eclipse.swt.widgets.TableItem;
import org.eclipse.swt.graphics.Image;
import org.eclipse.swt.events.MouseEvent;
import org.eclipse.swt.events.MouseListener;
import org.eclipse.swt.events.VerifyEvent;
import org.eclipse.swt.events.VerifyListener;
import org.eclipse.ui.part.ViewPart;
import org.eclipse.jface.action.IMenuManager;
import org.eclipse.jface.action.IToolBarManager;
import java.io.FileNotFoundException;
import org.eclipse.swt.custom.ScrolledComposite;
public class crmLogin extends ViewPart {
private Shell crmLoginScr = null;
private TabFolder tabFoldercrmLoginScr = null;
private TabItem tabItemVisiblecrmLoginScr = null;
private Composite CSvisiblecrmLoginScr = null;
private TabItem tabItemHiddencrmLoginScr = null;
private Composite CShiddencrmLoginScr = null;
private ScrolledComposite CSvisiblecrmLoginScrSC = null;
private ScrolledComposite CShiddencrmLoginScrSC = null;
TableItem tabitem;
private Label F1gen = null;
private Combo clientOM = null;
private Text login = null;
private Text password = null;
private Label userid = null;
private Label clientid = null;
private Button loginPb = null;
private Label personid = null;
private Label LLogin = null;
private Label LPassword = null;
private void createcrmLoginScr() {
crmLoginScr = new Shell (); // @jve:decl-index=0:visual-constraint="10,10"
crmLoginScr.setText("Anmeldung");
crmLoginScr.setSize(new org.eclipse.swt.graphics.Point((int) (6*41.17) +
10, (int) (14*12.07) + 35));
createtabFoldercrmLoginScr(crmLoginScr);
private void createtabFoldercrmLoginScr(Composite crmLoginScr) {
tabFoldercrmLoginScr = new TabFolder(crmLoginScr,SWT.BOTTOM);
tabFoldercrmLoginScr.setBounds(new
org.eclipse.swt.graphics.Rectangle(0,0,(int) (6*41.17) + 10, (int)
(14*12.07) + 35 ));
TabItem tabItemVisiblecrmLoginScr = new TabItem
(tabFoldercrmLoginScr,SWT.NONE);
TabItem tabItemHiddencrmLoginScr = new TabItem
createCSvisiblecrmLoginScr();
createCShiddencrmLoginScr();
tabItemVisiblecrmLoginScr.setText("workplace");
tabItemHiddencrmLoginScr.setText("hidden-always");
tabItemVisiblecrmLoginScr.setControl(CSvisiblecrmLoginScrSC );
tabItemHiddencrmLoginScr.setControl(CShiddencrmLoginScrSC );
private void createCShiddencrmLoginScr() {
// Create the ScrolledComposite to scroll horizontally and vertically
CShiddencrmLoginScrSC = new
ScrolledComposite(tabFoldercrmLoginScr,SWT.H_SCROLL | SWT.V_SCROLL);
CShiddencrmLoginScrSC.setBounds(0,0,750,550);
// Create a child composite to hold the controls
CShiddencrmLoginScr = new Composite(CShiddencrmLoginScrSC,SWT.NONE);
CShiddencrmLoginScr.setBounds(tabFoldercrmLoginScr.getBounds ().x,tabFoldercrmLoginScr.getBounds().y,tabFoldercrmLoginScr .getBounds().width,tabFoldercrmLoginScr.getBounds().height);
F1gen = new Label (CShiddencrmLoginScr,SWT.LEFT );
F1gen.setBounds(new org.eclipse.swt.graphics.Rectangle(42, 36,(int)
(48), (int) (14)));
F1gen.setVisible(true);
F1gen.setFont(new
Font(org.eclipse.swt.widgets.Display.getDefault(),"Arial",8,SWT.NORMAL));
F1gen.setText("Mandant");
clientOM = new Combo (CShiddencrmLoginScr,SWT.DROP_DOWN | SWT.READ_ONLY );
clientOM.setBounds(new org.eclipse.swt.graphics.Rectangle(96, 32,(int)
(132), (int) (21)));
clientOM.setVisible(true);
clientOM.setFont(new
userid = new Label (CShiddencrmLoginScr,SWT.LEFT );
userid.setBounds(new org.eclipse.swt.graphics.Rectangle(12, 120,(int)
(54), (int) (14)));
userid.setVisible(true);
userid.setFont(new
clientid = new Label (CShiddencrmLoginScr,SWT.LEFT );
clientid.setBounds(new org.eclipse.swt.graphics.Rectangle(12, 134,(int)
(54), (int) (14)));
clientid.setVisible(true);
clientid.setFont(new
personid = new Label (CShiddencrmLoginScr,SWT.LEFT );
personid.setBounds(new org.eclipse.swt.graphics.Rectangle(12, 148,(int)
(54), (int) (14)));
personid.setVisible(true);
personid.setFont(new
CShiddencrmLoginScrSC.setContent(CShiddencrmLoginScr);
CShiddencrmLoginScrSC.setMinSize((int)(6*41.17) + 10 ,(int)(14*12.07) +
35 );
CShiddencrmLoginScrSC.setExpandHorizontal(true);
CShiddencrmLoginScrSC.setExpandVertical(true);
private void createCSvisiblecrmLoginScr() {
CSvisiblecrmLoginScrSC = new
CSvisiblecrmLoginScrSC.setBounds(0,0,750,550);
CSvisiblecrmLoginScr = new Composite(CSvisiblecrmLoginScrSC,SWT.NONE);
CSvisiblecrmLoginScr.setBounds(tabFoldercrmLoginScr.getBound s().x,tabFoldercrmLoginScr.getBounds().y,tabFoldercrmLoginSc r.getBounds().width,tabFoldercrmLoginScr.getBounds().height) ;
// END of TabDecks
// END of TabCards
// END of GridFrames
// END of GridFrameColumns
login = new Text (CSvisiblecrmLoginScr,SWT.LEFT | SWT.BORDER );
login.setBounds(new org.eclipse.swt.graphics.Rectangle(96, 59,(int)
(100), (int) (23)));
login.setFont(new
login.setText("db2admin");
password = new Text (CSvisiblecrmLoginScr,SWT.LEFT | SWT.BORDER );
password.setBounds(new org.eclipse.swt.graphics.Rectangle(96, 87,(int)
password.setFont(new
password.setEchoChar('*');
password.setText("db2admin");
loginPb = new Button (CSvisiblecrmLoginScr,SWT.CENTER );
loginPb.setBounds(new org.eclipse.swt.graphics.Rectangle(110, 129,(int)
(74), (int) (23)));
loginPb.setFont(new
dlScreen = new Label (CSvisiblecrmLoginScr,SWT.LEFT );
dlScreen.setBounds(new org.eclipse.swt.graphics.Rectangle(2, 0,(int)
(244), (int) (24)));
dlScreen.setText("Login");
LLogin = new Label (CSvisiblecrmLoginScr,SWT.LEFT );
LLogin.setBounds(new org.eclipse.swt.graphics.Rectangle(39, 64,(int)
(54), (int) (13)));
LLogin.setFont(new
LLogin.setText("Username");
LPassword = new Label (CSvisiblecrmLoginScr,SWT.LEFT );
LPassword.setBounds(new org.eclipse.swt.graphics.Rectangle(40, 92,(int)
(52), (int) (13)));
LPassword.setFont(new
LPassword.setText("Passwort");
CSvisiblecrmLoginScrSC.setContent(CSvisiblecrmLoginScr);
CSvisiblecrmLoginScrSC.setMinSize((int)(6*41.17) + 10 ,(int)(14*12.07) +
35 );
CSvisiblecrmLoginScrSC.setExpandHorizontal(true);
CSvisiblecrmLoginScrSC.setExpandVertical(true);
public void setFocus() {
// viewer.getControl().setFocus();
* This is a callback that will allow us to create the viewer and initialize
* it.
public void createPartControl(Composite scanner) {
Composite crmLoginScr = scanner;
org.eclipse.swt.widgets.Display display =
org.eclipse.swt.widgets.Display.getDefault();
crmLogin jClasscrmLogin = new crmLogin();
jClasscrmLogin.createcrmLoginScr();
jClasscrmLogin.crmLoginScr.open();
while (!jClasscrmLogin.crmLoginScr.isDisposed()) {
if (!display.readAndDispatch ()) display.sleep();
display.dispose ();
(2) extract of my log file:
I am sorry, but i do not understand the meaning of the log-extract...
.... does anybody see what the problem is?
!ENTRY org.eclipse.ve.java.core 4 0 2005-07-26 12:44:27.906
!MESSAGE Exception thrown.
!STACK 0
org.eclipse.ve.internal.swt.CompositeGraphicalEditPart.setup Control(CompositeGraphicalEditPart.java:96)
org.eclipse.ve.internal.swt.CompositeGraphicalEditPart.creat eChild(CompositeGraphicalEditPart.java:84)
org.eclipse.gef.editparts.AbstractEditPart.refreshChildren(A bstractEditPart.java:733)
org.eclipse.gef.editparts.AbstractEditPart.refresh(AbstractE ditPart.java:684)
org.eclipse.gef.editparts.AbstractGraphicalEditPart.refresh( AbstractGraphicalEditPart.java:554)
org.eclipse.gef.editparts.AbstractEditPart.addNotify(Abstrac tEditPart.java:232)
org.eclipse.gef.editparts.AbstractGraphicalEditPart.addNotif y(AbstractGraphicalEditPart.java:212)
org.eclipse.gef.editparts.AbstractEditPart.addChild(Abstract EditPart.java:195)
org.eclipse.ve.internal.swt.TabFolderGraphicalEditPart.addCh ild(TabFolderGraphicalEditPart.java:86)
org.eclipse.gef.editparts.AbstractEditPart.refreshChildren(A bstractEditPart.java:734)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.setRootModel(JavaVisualEditorPart.java:506)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.initializeViewers(JavaVisualEditorPart.java:987)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$12.run(JavaVisualEditorPart.java:1977)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3057)
at org.eclipse.swt.widgets.Display.msgFilterProc(Display.java:2 505)
at org.eclipse.swt.internal.win32.OS.DefWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.DefWindowProc(OS.java:1651 )
at org.eclipse.swt.widgets.Scrollable.callWindowProc(Scrollable .java:77)
at org.eclipse.swt.widgets.Composite.WM_SYSCOMMAND(Composite.ja va:1315)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3110 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:3706 )
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3123 )
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:16 56)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2711)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
!ENTRY org.eclipse.jem.proxy 2 0 2005-07-26 12:44:28.265
!MESSAGE
+++ Warning +++: Tue Jul 26 12:44:28 CEST 2005 Project
(proCrmAntlrE31)-VM for proCrmAntlrE31:err>
org.eclipse.jem.internal.proxy.common.remote.CommandErrorExc eption--
Error code:7 Value data:"java.lang.NullPointerException:null"
org.eclipse.jem.internal.proxy.common.remote.Commands.readBa ckValue(Commands.java:1254)
org.eclipse.jem.internal.proxy.vm.remote.ConnectionHandler.r un(ConnectionHandler.java:454)
org.eclipse.jem.internal.proxy.vm.remote.CallbackHandler.cal lbackWithParms(CallbackHandler.java:150)
org.eclipse.ve.internal.swt.targetvm.ControlManager$5.run(Co ntrolManager.java:637)
org.eclipse.jem.internal.proxy.vm.remote.RemoteVMServerThrea d.doCallback(RemoteVMServerThread.java:541)
org.eclipse.ve.internal.swt.targetvm.ControlManager$ControlM anagerFeedbackController.run(ControlManager.java:634)
org.eclipse.ve.internal.swt.targetvm.ControlManager$1.run(Co ntrolManager.java:480)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2716)
org.eclipse.ve.internal.swt.targetvm.Environment$3.run(Envir onment.java:68)
!ENTRY org.eclipse.ui 4 4 2005-07-26 12:44:30.140
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2005-07-26 12:44:30.218
!MESSAGE Failed to execute runnable (java.lang.NullPointerException)
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable
at org.eclipse.swt.SWT.error(SWT.java:2942)
at org.eclipse.swt.SWT.error(SWT.java:2865)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:126)
Caused by: java.lang.NullPointerException
... 32 more
Re: Some problems with the VE 1.1 and Eclipse 3.1 [message #100291 is a reply to message #100141] Tue, 26 July 2005 11:37 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
I was able to produce the first problem with labels not showing up.
Please open a bugzilla against VE component SWT and attach the source
crmLogin to it.
I don't know what caused the trace exception you first showed because
you didn't include the code for the shell that wouldn't start at all.
Please append the shell that failed so we can see it too.
Rich Kulp
Re: Some problems with the VE 1.1 and Eclipse 3.1 [message #100303 is a reply to message #100141] Tue, 26 July 2005 13:05 Go to previous messageGo to next message
Hi Flik,
It turns out that the code was in a pattern not supported by VE 1.1.
1) For example a Composite (crmLoginScr) was defined as a local variable
and codegen in VE 1.1 doesnt understand passing of arguments between
methods - it only understands fields and local variables.
2) the name of the Shell and a composite to be the same.
3) You dont need the main() class and a shell in your source, to see how
the view's contents look at runtime simply run the view as a 'Java Bean'.
I have refactored the source so that VE can show the visuals correctly.
Please make sure this works for you.
Sri.
public class CopyOfcrmLogin3 extends ViewPart {
TableItem tabitem;
private Composite crmLoginScr2;
//private void createcrmLoginScr() {
//crmLoginScr = new Shell (); // @jve:decl-index=0:visual-constraint="10,10"
//crmLoginScr.setText("Anmeldung");
//crmLoginScr.setSize(new org.eclipse.swt.graphics.Point((int) (6*41.17)
+ 10, (int) (14*12.07) + 35));
//createtabFoldercrmLoginScr();
private void createtabFoldercrmLoginScr() {
tabFoldercrmLoginScr = new TabFolder(crmLoginScr2,SWT.BOTTOM);
(14*12.07) + 35 ));
(48), (int) (14)));
F1gen.setFont(new
(54), (int) (14)));
userid.setFont(new
(54), (int) (14)));
(54), (int) (14)));
35 );
// END of TabDecks
// END of TabCards
login.setFont(new
(74), (int) (23)));
loginPb.setFont(new
(54), (int) (13)));
LLogin.setFont(new
(52), (int) (13)));
35 );
* it.
crmLoginScr2 = scanner;
CopyOfcrmLogin3 jClasscrmLogin = new CopyOfcrmLogin3();
//jClasscrmLogin.createcrmLoginScr();
display.dispose ();
>> Hi Flik,
> import org.eclipse.swt.widgets.Display;
> TableItem tabitem;
> (14*12.07) + 35 ));
> (48), (int) (14)));
> F1gen.setFont(new
> (54), (int) (14)));
> userid.setFont(new
> (54), (int) (14)));
> (54), (int) (14)));
> 35 );
> // END of TabDecks
> // END of TabCards
> login.setFont(new
> (74), (int) (23)));
> loginPb.setFont(new
> (54), (int) (13)));
> LLogin.setFont(new
> (52), (int) (13)));
> 35 );
> * it.
> public static void main(String[] args) {
> display.dispose ();
>> same project as the above file which seems to atleast load?
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !MESSAGE
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 32 more
new bugzilla entry [message #100419 is a reply to message #100291] Wed, 27 July 2005 03:20 Go to previous messageGo to next message
hello rich,
i have just added a new bugzilla entry:
-> https://bugs.eclipse.org/bugs/show_bug.cgi?id=105274
thanks for your help
Flik
> crmLogin to it.
Re: second problem -> NullPointerException [message #100433 is a reply to message #100291] Wed, 27 July 2005 03:25 Go to previous messageGo to next message
hello rich,
my second problem was the issue with the 'NullPointerException' when
loading my file in the visual editor.
I only get the message and the screen is blank!
thanks
Flik
see file crmCompany2.java
import org.eclipse.swt.widgets.Link;
import org.eclipse.swt.widgets.Table;
import org.eclipse.swt.widgets.TableColumn;
public class crmCompany2 extends ViewPart {
private Shell crmCompany2Scr = null;
private TabFolder tabFoldercrmCompany2Scr = null;
String[][] gridContentB1gen = new String[6][0];
private TabItem tabItemVisiblecrmCompany2Scr = null;
private Composite CSvisiblecrmCompany2Scr = null;
private TabItem tabItemHiddencrmCompany2Scr = null;
private Composite CShiddencrmCompany2Scr = null;
private ScrolledComposite CSvisiblecrmCompany2ScrSC = null;
private ScrolledComposite CShiddencrmCompany2ScrSC = null;
TableItem tabitem;
private Label id = null;
private Label branchId = null;
private Label version = null;
private Label modDate = null;
private Label createDate = null;
private Link K3employee = null;
private Link K6employee = null;
private Text name1 = null;
private Text name2 = null;
private TableColumn lbPerson = null;
private TableColumn perId = null;
private TableColumn name5 = null;
private TableColumn firstname = null;
private TableColumn sex = null;
private Label LName1 = null;
private Label LName2 = null;
private Composite B1gencs = null;
private Table B1gen = null;
private Button pbSelect = null;
private void createcrmCompany2Scr() {
crmCompany2Scr = new Shell (); //
crmCompany2Scr.setText("");
crmCompany2Scr.setSize(new org.eclipse.swt.graphics.Point((int)
(6*143.50) + 10, (int) (14*30.36) + 35));
createtabFoldercrmCompany2Scr(crmCompany2Scr);
private void createtabFoldercrmCompany2Scr(Composite crmCompany2Scr) {
tabFoldercrmCompany2Scr = new TabFolder(crmCompany2Scr,SWT.BOTTOM);
tabFoldercrmCompany2Scr.setBounds(new
org.eclipse.swt.graphics.Rectangle(0,0,(int) (6*143.50) + 10, (int)
(14*30.36) + 35 ));
TabItem tabItemVisiblecrmCompany2Scr = new TabItem
(tabFoldercrmCompany2Scr,SWT.NONE);
TabItem tabItemHiddencrmCompany2Scr = new TabItem
createCSvisiblecrmCompany2Scr();
createCShiddencrmCompany2Scr();
tabItemVisiblecrmCompany2Scr.setText("workplace");
tabItemHiddencrmCompany2Scr.setText("hidden-always");
tabItemVisiblecrmCompany2Scr.setControl(CSvisiblecrmCompany2 ScrSC );
tabItemHiddencrmCompany2Scr.setControl(CShiddencrmCompany2Sc rSC );
private void createCShiddencrmCompany2Scr() {
CShiddencrmCompany2ScrSC = new
ScrolledComposite(tabFoldercrmCompany2Scr,SWT.H_SCROLL | SWT.V_SCROLL);
CShiddencrmCompany2ScrSC.setBounds(0,0,750,550);
CShiddencrmCompany2Scr = new Composite(CShiddencrmCompany2ScrSC,SWT.NONE);
CShiddencrmCompany2Scr.setBounds(tabFoldercrmCompany2Scr.get Bounds().x,tabFoldercrmCompany2Scr.getBounds().y,tabFoldercr mCompany2Scr.getBounds().width,tabFoldercrmCompany2Scr.getBo unds().height);
id = new Label (CShiddencrmCompany2Scr,SWT.LEFT );
id.setBounds(new org.eclipse.swt.graphics.Rectangle(40, 31,(int) (66),
(int) (14)));
id.setFont(new
branchId = new Label (CShiddencrmCompany2Scr,SWT.LEFT );
branchId.setBounds(new org.eclipse.swt.graphics.Rectangle(115, 31,(int)
(66), (int) (14)));
branchId.setFont(new
branchId.setVisible(true);
version = new Label (CShiddencrmCompany2Scr,SWT.LEFT );
version.setBounds(new org.eclipse.swt.graphics.Rectangle(189, 31,(int)
(66), (int) (14)));
version.setFont(new
version.setVisible(true);
modDate = new Label (CShiddencrmCompany2Scr,SWT.LEFT );
modDate.setBounds(new org.eclipse.swt.graphics.Rectangle(435, 31,(int)
(60), (int) (14)));
modDate.setFont(new
modDate.setVisible(true);
createDate = new Label (CShiddencrmCompany2Scr,SWT.LEFT );
createDate.setBounds(new org.eclipse.swt.graphics.Rectangle(503,
31,(int) (60), (int) (14)));
createDate.setFont(new
createDate.setVisible(true);
perId = new TableColumn (B1gen,SWT.LEFT);
perId.setWidth((int)(6 *11) + 15 );
perId.setWidth(0);
perId.setResizable(false);
perId.setText("Per_id");
name5 = new TableColumn (B1gen,SWT.LEFT);
name5.setWidth((int)(6 *33) + 15 );
name5.setWidth(0);
name5.setResizable(false);
name5.setText("Name");
firstname = new TableColumn (B1gen,SWT.LEFT);
firstname.setWidth((int)(6 *33) + 15 );
firstname.setWidth(0);
firstname.setResizable(false);
firstname.setText("Firstname");
sex = new TableColumn (B1gen,SWT.LEFT);
sex.setWidth((int)(6 *1) + 15 );
sex.setWidth(0);
sex.setResizable(false);
sex.setText("Sex");
CShiddencrmCompany2ScrSC.setContent(CShiddencrmCompany2Scr);
CShiddencrmCompany2ScrSC.setMinSize((int)(6*143.50) + 10
,(int)(14*30.36) + 35 );
CShiddencrmCompany2ScrSC.setExpandHorizontal(true);
CShiddencrmCompany2ScrSC.setExpandVertical(true);
private void createCSvisiblecrmCompany2Scr() {
CSvisiblecrmCompany2ScrSC = new
CSvisiblecrmCompany2ScrSC.setBounds(0,0,750,550);
CSvisiblecrmCompany2Scr = new Composite(CSvisiblecrmCompany2ScrSC,SWT.NONE);
CSvisiblecrmCompany2Scr.setBounds(tabFoldercrmCompany2Scr.ge tBounds().x,tabFoldercrmCompany2Scr.getBounds().y,tabFolderc rmCompany2Scr.getBounds().width,tabFoldercrmCompany2Scr.getB ounds().height);
// END of TabDecks
// END of TabCards
B1gencs = new Composite (CSvisiblecrmCompany2Scr,SWT.NONE);
B1gencs.setBounds(new org.eclipse.swt.graphics.Rectangle(6, 134,(int)
(471), (int) (188)));
B1gen = new Table (B1gencs,SWT.SINGLE | SWT.BORDER | SWT.H_SCROLL |
SWT.V_SCROLL | SWT.FULL_SELECTION | SWT.HIDE_SELECTION);
B1gen.setBounds(new org.eclipse.swt.graphics.Rectangle(0, 0,(int) (471),
(int) (188)));
B1gen.setLinesVisible(true);
B1gen.setHeaderVisible(true);
lbPerson = new TableColumn (B1gen,SWT.LEFT);
lbPerson.setWidth((int)(6 *60) + 15 );
dlScreen = new Label (CSvisiblecrmCompany2Scr,SWT.LEFT );
(858), (int) (25)));
Font(org.eclipse.swt.widgets.Display.getDefault(),"Arial",16,SWT.BOLD));
dlScreen.setText("Company");
K3employee = new Link (CSvisiblecrmCompany2Scr,SWT.NULL );
K3employee.setBounds(new org.eclipse.swt.graphics.Rectangle(275,
36,(int) (96), (int) (14)));
K3employee.setVisible(false);
K3employee.setFont(new
K3employee.setText("company employee");
K6employee = new Link (CSvisiblecrmCompany2Scr,SWT.NULL );
K6employee.setBounds(new org.eclipse.swt.graphics.Rectangle(275,
50,(int) (90), (int) (14)));
K6employee.setFont(new
K6employee.setVisible(false);
K6employee.setText("employee person");
name1 = new Text (CSvisiblecrmCompany2Scr,SWT.LEFT | SWT.BORDER );
name1.setBounds(new org.eclipse.swt.graphics.Rectangle(46, 73,(int)
(255), (int) (26)));
name1.setFont(new
Font(org.eclipse.swt.widgets.Display.getDefault(),"Arial",10,SWT.NORMAL));
name2 = new Text (CSvisiblecrmCompany2Scr,SWT.LEFT | SWT.BORDER );
name2.setBounds(new org.eclipse.swt.graphics.Rectangle(46, 101,(int)
name2.setFont(new
LName1 = new Label (CSvisiblecrmCompany2Scr,SWT.LEFT );
LName1.setBounds(new org.eclipse.swt.graphics.Rectangle(6, 78,(int)
(34), (int) (13)));
LName1.setFont(new
LName1.setText("Name1");
LName2 = new Label (CSvisiblecrmCompany2Scr,SWT.LEFT );
LName2.setBounds(new org.eclipse.swt.graphics.Rectangle(6, 106,(int)
(34), (int) (13)));
LName2.setFont(new
LName2.setText("Name2");
pbSelect = new Button(CSvisiblecrmCompany2Scr,SWT.BORDER);
pbSelect.setBounds(new org.eclipse.swt.graphics.Rectangle(6, 400,(int)
(200), (int) (20)));
pbSelect.setText("method: select()");
pbSelect.setFont(new
pbSelect.addMouseListener(new MouseListener() {
public void mouseDown(MouseEvent e) {
public void mouseUp(MouseEvent e) {}
public void mouseDoubleClick(MouseEvent e) {}
CSvisiblecrmCompany2ScrSC.setContent(CSvisiblecrmCompany2Scr );
CSvisiblecrmCompany2ScrSC.setMinSize((int)(6*143.50) + 10
CSvisiblecrmCompany2ScrSC.setExpandHorizontal(true);
CSvisiblecrmCompany2ScrSC.setExpandVertical(true);
* it.
Composite crmCompany2Scr = scanner;
crmCompany2 jClasscrmCompany2 = new crmCompany2();
jClasscrmCompany2.createcrmCompany2Scr();
jClasscrmCompany2.crmCompany2Scr.open();
while (!jClasscrmCompany2.crmCompany2Scr.isDisposed()) {
if (!display.readAndDispatch ()) {display.sleep();}
display.dispose ();
> crmLogin to it.
Re: Some problems with the VE 1.1 and Eclipse 3.1 [message #100462 is a reply to message #100303] Wed, 27 July 2005 03:53 Go to previous messageGo to next message
hey Sri,
thanks for your code!
I have compare it with my own one and copy the changes to it.
Now I can see the fields and their contents - BUT I cannot edit them
with drag&drop.
All I can do is to click on the java-beans-window to select a specific
widget. But I cannot click on the widget itself in the drawn ve-area.
Another thing is that all widgets are displayed within a viewpart. This
is exactly what i want: that's why i had uses swt shell and viewpart
within one file.... (swt shell -> editing with VE && viewpart -> working
with Eclipse Runtime)
(In the past the ve had shown me an empty view part and an SWT-area for
editing the widgets.)
So, this is now pretty cool, but unfortunatly i cannot edit this
viewpart directly within the editor (see above)
Can you please try my attached file?
thanks
Flik
TableItem tabitem;
/*private void createcrmLoginScr() {
(14*12.07) + 35 ));
(48), (int) (14)));
F1gen.setFont(new
(54), (int) (14)));
userid.setFont(new
(54), (int) (14)));
(54), (int) (14)));
35 );
// END of TabDecks
// END of TabCards
login.setFont(new
(74), (int) (23)));
loginPb.setFont(new
(54), (int) (13)));
LLogin.setFont(new
(52), (int) (13)));
35 );
* it.
display.dispose ();
} // @jve:decl-index=0:visual-constraint="30,11"
> Hi Flik,
> Sri.
Re: second problem -> NullPointerException [message #100477 is a reply to message #100433] Wed, 27 July 2005 06:33 Go to previous messageGo to next message
hello together,
i just have tried to use Sri's solution for my second problem!
I rewrite the code and ... the error is gone!
Everything is shown correclty now - except one thing:
all of the widgets are displayed within a view-part area that does not
'understand' drag&drop... i cannot click on a single widget and move it.
It is like the view-part area is disabled or so!
The only thing i can do is to click the entry in the java beans listbox.
thanks in advance
flik
p.s.: the table columns are also displayed incorrectly (little icons
under the view-part-area), but i have learned some time ago that this is
a known problem...
see code for example:
crmCompany2.java
TableItem tabitem;
private Composite crmCompany2ScrCS;
//private void createcrmCompany2Scr() {
//crmCompany2Scr = new Shell (); //
//crmCompany2Scr.setText("");
//crmCompany2Scr.setSize(new org.eclipse.swt.graphics.Point((int)
//createtabFoldercrmCompany2Scr(crmCompany2Scr);
private void createtabFoldercrmCompany2Scr() {
tabFoldercrmCompany2Scr = new TabFolder(crmCompany2ScrCS,SWT.BOTTOM);
(14*30.36) + 35 ));
(int) (14)));
id.setFont(new
Font(org.eclipse.swt.widgets.Display.getDefault(),JPSourceAc tion.returnFont( "text"),8,SWT.NORMAL));
(66), (int) (14)));
(66), (int) (14)));
version.setFont(new
(60), (int) (14)));
modDate.setFont(new
perId.setWidth(0);
name5.setWidth(0);
sex.setWidth(0);
sex.setText("Sex");
// END of TabDecks
// END of TabCards
(int) (188)));
Font(org.eclipse.swt.widgets.Display.getDefault(),JPSourceAc tion.returnFont( "text"),16,SWT.BOLD));
name1.setFont(new
Font(org.eclipse.swt.widgets.Display.getDefault(),JPSourceAc tion.returnFont( "text"),10,SWT.NORMAL));
name2.setFont(new
(34), (int) (13)));
LName1.setFont(new
(34), (int) (13)));
LName2.setFont(new
* it.
crmCompany2ScrCS = scanner;
createtabFoldercrmCompany2Scr();
//jClasscrmCompany2.createcrmCompany2Scr();
display.dispose ();
Flik schrieb:
> hello rich,
> thanks
> Flik
> TableItem tabitem;
> (14*30.36) + 35 ));
> (int) (14)));
> id.setFont(new
> (66), (int) (14)));
> (66), (int) (14)));
> version.setFont(new
> (60), (int) (14)));
> modDate.setFont(new
> perId.setWidth(0);
> name5.setWidth(0);
> sex.setWidth(0);
> sex.setText("Sex");
> // END of TabDecks
> // END of TabCards
> (int) (188)));
> name1.setFont(new
> name2.setFont(new
> (34), (int) (13)));
> LName1.setFont(new
> (34), (int) (13)));
> LName2.setFont(new
> * it.
> display.dispose ();
>> crmLogin to it.
problem solved *fixed* [message #100493 is a reply to message #100477] Wed, 27 July 2005 07:50 Go to previous message
hey,
i am sooo happy !!!! :-))))
all of my problems are solved!
-> the npe was 'killed' with SRI's code
-> the problem that VE could not edit the viewpart was the following:
i used: crmCompany2ScrCS = new Composite(scanner,SWT.NONE);
in stead of : crmCompany2ScrCS = scanner;
+ i have added : // @jve:decl-index=0:visual-constraint="10,10"
in the last line of my code..
thank you very much for your help
Flik
P.S.: i will close the bugzilla entry!
just for your interest: the file that works...
TableItem tabitem;
(14*30.36) + 35 ));
(int) (14)));
id.setFont(new
(66), (int) (14)));
(66), (int) (14)));
version.setFont(new
(60), (int) (14)));
modDate.setFont(new
perId.setWidth(0);
name5.setWidth(0);
sex.setWidth(0);
sex.setText("Sex");
// END of TabDecks
// END of TabCards
(int) (188)));
name1.setFont(new
name2.setFont(new
(34), (int) (13)));
LName1.setFont(new
(34), (int) (13)));
LName2.setFont(new
* it.
} // @jve:decl-index=0:visual-constraint="10,10"
Re: Some problems with the VE 1.1 and Eclipse 3.1 [message #609242 is a reply to message #100065] Tue, 26 July 2005 05:49 Go to previous message
Hi Flik,
Sri.
Flik wrote:
> hello,
> Label...
> _the code:_
> thanks
> Flik
Re: Some problems with the VE 1.1 and Eclipse 3.1 [message #609245 is a reply to message #100098] Tue, 26 July 2005 06:51 Go to previous message
> Hi Flik,
TableItem tabitem;
(14*12.07) + 35 ));
(48), (int) (14)));
F1gen.setFont(new
(54), (int) (14)));
userid.setFont(new
(54), (int) (14)));
(54), (int) (14)));
35 );
// END of TabDecks
// END of TabCards
login.setFont(new
(74), (int) (23)));
loginPb.setFont(new
(54), (int) (13)));
LLogin.setFont(new
(52), (int) (13)));
35 );
* it.
display.dispose ();
!STACK 0
!MESSAGE
!STACK 0
... 32 more
Re: Some problems with the VE 1.1 and Eclipse 3.1 [message #610011 is a reply to message #100141] Tue, 26 July 2005 11:37 Go to previous message
crmLogin to it.
Rich Kulp
Re: Some problems with the VE 1.1 and Eclipse 3.1 [message #610012 is a reply to message #100141] Tue, 26 July 2005 13:05 Go to previous message
Hi Flik,
Sri.
TableItem tabitem;
(14*12.07) + 35 ));
(48), (int) (14)));
F1gen.setFont(new
(54), (int) (14)));
userid.setFont(new
(54), (int) (14)));
(54), (int) (14)));
35 );
// END of TabDecks
// END of TabCards
login.setFont(new
(74), (int) (23)));
loginPb.setFont(new
(54), (int) (13)));
LLogin.setFont(new
(52), (int) (13)));
35 );
* it.
display.dispose ();
>> Hi Flik,
> TableItem tabitem;
> (14*12.07) + 35 ));
> (48), (int) (14)));
> F1gen.setFont(new
> (54), (int) (14)));
> userid.setFont(new
> (54), (int) (14)));
> (54), (int) (14)));
> 35 );
> // END of TabDecks
> // END of TabCards
> login.setFont(new
> (74), (int) (23)));
> loginPb.setFont(new
> (54), (int) (13)));
> LLogin.setFont(new
> (52), (int) (13)));
> 35 );
> * it.
> display.dispose ();
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !MESSAGE
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 32 more
new bugzilla entry [message #610027 is a reply to message #100291] Wed, 27 July 2005 03:20 Go to previous message
hello rich,
Flik
> crmLogin to it.
Re: second problem -> NullPointerException [message #610028 is a reply to message #100291] Wed, 27 July 2005 03:25 Go to previous message
hello rich,
thanks
Flik
TableItem tabitem;
(14*30.36) + 35 ));
(int) (14)));
id.setFont(new
(66), (int) (14)));
(66), (int) (14)));
version.setFont(new
(60), (int) (14)));
modDate.setFont(new
perId.setWidth(0);
name5.setWidth(0);
sex.setWidth(0);
sex.setText("Sex");
// END of TabDecks
// END of TabCards
(int) (188)));
name1.setFont(new
name2.setFont(new
(34), (int) (13)));
LName1.setFont(new
(34), (int) (13)));
LName2.setFont(new
* it.
display.dispose ();
> crmLogin to it.
Re: Some problems with the VE 1.1 and Eclipse 3.1 [message #610033 is a reply to message #100303] Wed, 27 July 2005 03:53 Go to previous message
hey Sri,
with drag&drop.
thanks
Flik
TableItem tabitem;
(14*12.07) + 35 ));
(48), (int) (14)));
F1gen.setFont(new
(54), (int) (14)));
userid.setFont(new
(54), (int) (14)));
(54), (int) (14)));
35 );
// END of TabDecks
// END of TabCards
login.setFont(new
(74), (int) (23)));
loginPb.setFont(new
(54), (int) (13)));
LLogin.setFont(new
(52), (int) (13)));
35 );
* it.
display.dispose ();
> Hi Flik,
> Sri.
Re: second problem -> NullPointerException [message #610034 is a reply to message #100433] Wed, 27 July 2005 06:33 Go to previous message
hello together,
thanks in advance
flik
a known problem...
crmCompany2.java
TableItem tabitem;
(14*30.36) + 35 ));
(int) (14)));
id.setFont(new
(66), (int) (14)));
(66), (int) (14)));
version.setFont(new
(60), (int) (14)));
modDate.setFont(new
perId.setWidth(0);
name5.setWidth(0);
sex.setWidth(0);
sex.setText("Sex");
// END of TabDecks
// END of TabCards
(int) (188)));
name1.setFont(new
name2.setFont(new
(34), (int) (13)));
LName1.setFont(new
(34), (int) (13)));
LName2.setFont(new
* it.
display.dispose ();
Flik schrieb:
> hello rich,
> thanks
> Flik
> TableItem tabitem;
> (14*30.36) + 35 ));
> (int) (14)));
> id.setFont(new
> (66), (int) (14)));
> (66), (int) (14)));
> version.setFont(new
> (60), (int) (14)));
> modDate.setFont(new
> perId.setWidth(0);
> name5.setWidth(0);
> sex.setWidth(0);
> sex.setText("Sex");
> // END of TabDecks
> // END of TabCards
> (int) (188)));
> name1.setFont(new
> name2.setFont(new
> (34), (int) (13)));
> LName1.setFont(new
> (34), (int) (13)));
> LName2.setFont(new
> * it.
> display.dispose ();
>> crmLogin to it.
problem solved *fixed* [message #610035 is a reply to message #100477] Wed, 27 July 2005 07:50 Go to previous message
hey,
Flik
TableItem tabitem;
(14*30.36) + 35 ));
(int) (14)));
id.setFont(new
(66), (int) (14)));
(66), (int) (14)));
version.setFont(new
(60), (int) (14)));
modDate.setFont(new
perId.setWidth(0);
name5.setWidth(0);
sex.setWidth(0);
sex.setText("Sex");
// END of TabDecks
// END of TabCards
(int) (188)));
name1.setFont(new
name2.setFont(new
(34), (int) (13)));
LName1.setFont(new
(34), (int) (13)));
LName2.setFont(new
* it.
Previous Topic:Also Problems to get Ve to work
Next Topic:Embedding VE questions
Current Time: Fri Jul 18 02:09:52 EDT 2025
Powered by FUDForum. Page generated in 2.78705 seconds
