Home » Language IDEs » C / C++ IDE (CDT) » Configuration Problem
Configuration Problem [message #100006] Sun, 18 April 2004 06:55 Go to next message
Originally posted by: j.geering.btinternet.com
Dear All
I am having problems getting the debug congiguration. When I create a new
"managed make c++ project" only the release configuration is available.
So an compilations do not work with gdb, how can I get the debug
configuration to show up in the "project/navigation" window. If you don't
tick release in the initial wizard then it shows up but clearly I want to
be able to choose between configurations.
Hopefull someone can put me out of my misery as this is driving me round
the bend.
Many thanks
James
Re: Configuration Problem [message #100022 is a reply to message #100006] Sun, 18 April 2004 07:18 Go to previous messageGo to next message
I found it, its on the property page of the project.
So my new quesion is without looking at this page is there any quick
indication of what mode you are in?
James wrote:
> Dear All
> the bend.
> Many thanks
> James
Re: Configuration Problem [message #100034 is a reply to message #100022] Sun, 18 April 2004 08:31 Go to previous message
Originally posted by: simon_walther.hotmail.com
Hi James
If I create a new project, I can choose both the release and the debug
configuration. Later, when the project is set up, I have got a folder
within the project-name folder named debug or release containing all the
object code files and binaries. If you would like to change the
configuration later or add one you can do that on the property page as you
already mentioned.
I hope this helps or otherwise I missunderstood you.
Greetings Simon
> James wrote:
>> Dear All
>> new "managed make c++ project" only the release configuration is
>> available. So an compilations do not work with gdb, how can I get the
>> debug configuration to show up in the "project/navigation" window. If you
>> don't tick release in the initial wizard then it shows up but clearly I
>> want to be able to choose between configurations.
>> the bend.
>> Many thanks
>> James
Previous Topic:Content Assist Slowdown
Next Topic:Problem in creating a managed make file
Current Time: Sat Jul 12 22:44:41 EDT 2025
Powered by FUDForum. Page generated in 0.49218 seconds
