how to use logic sample ,thanks!! [message #99707] |
Tue, 14 October 2003 04:42  |
Originally posted by: mm.hotmail.com
i can Run the Logic Example in eclipse but when i build a gef logic sample
project,i meet some problem.
i build a plugin project name logic and copy logic-src and plugin.xml to my
project,when i run as run-time-workbench and double click the *test.logic
file,there
are a error message box :
"can't open default edit on test.logic,unable to instatiate editor :logic
Graphical editor
java.lang.NoClassDefFoundErro"
what's wrong with that?
thanks very much!
Re: how to use logic sample ,thanks!! [message #100376 is a reply to message #99707] |
Thu, 16 October 2003 16:35  |
Originally posted by: ThisisFake.Fakeness.xyz
> sample project,i meet some problem.
> my project,when i run as run-time-workbench and double click the
> *test.logic file,there
> Graphical editor
> thanks very much!
Were you able to successfully compile the GEF sample?
CL
FUDForum. Page generated in 0.03621 seconds
