Home » Eclipse Projects » Eclipse Platform » How do i Import a java project into Workspace by programming
How do i Import a java project into Workspace by programming [message #99599] Thu, 24 July 2003 23:45 Go to next message
Originally posted by: hoalq.fsoft.com.vn
Hi all
I am an user of eclipse. I 've just learning about eclipse2.1.1 in a week.
I want to programmatically import a java project into workspace. Who have
resources or path resource can send to me.
* How I can import a project into workspace through programmatically?
* Why my code following don't give myWork. this return myWork=null?
My code is :
//my code
import org.eclipse.core.resources.*;
import org.eclipse.core.runtime.*;
import org.eclipse.jdt.core.*;
public class ImportSample {
private IWorkspace myWork=null;
private IProject myProject=null;
public static void main(String[] agr){
myWork=ResourcePlugin.getWorksapce();
myProject=myWork.getProject();
thanks very much
pls answer as soon as you can
Le Quang Hoa
Re: How do i Import a java project into Workspace by programming [message #100508 is a reply to message #99599] Sat, 26 July 2003 12:40 Go to previous message
Originally posted by: luis_benitez.nospam.us.ibm.com
Is it because you are running the code from main() and you are supposed to
run it from somewhere else ? Like createPartControl() ?
You might want to create the sample Hello World plugin and then edit
appropiately.
-Luis
"Le Quang Hoa" <hoalq@fsoft.com.vn> wrote in message
news:bfq953$j8g$1@eclipse.org...
> Hi all
> My code is :
> //my code
> thanks very much
> Le Quang Hoa
Previous Topic:Suggestion for a plugin "commons" e.g. JDBC
Next Topic:Adding a plugin from the wizard problem
Current Time: Sun Nov 09 00:10:14 EST 2025
Powered by FUDForum. Page generated in 0.44560 seconds
