Home » Archived » Visual Editor (VE) » Missing SWT from Pallet
Missing SWT from Pallet [message #99571] Sat, 23 July 2005 12:24 Go to next message
Originally posted by: hoffmans.mtstech.com
That's pretty much it. I can see AWT and SWING (buttons etc) but I don't see
any for SWT.
I'm using Eclipse3.1
swt-3.1-win32-win32-x86.zip
emf-sdo-runtime-2.1.0.zip
GEF-runtime-3.1.zip
VE-runtime-1.1.zip
Re: Missing SWT from Pallet [message #99672 is a reply to message #99571] Sat, 23 July 2005 20:37 Go to previous message
Originally posted by: myersj.nospam.gmail.com
Stuart,
Did you manually add the SWT jar to your project? If so, the VE does not
recognize this. Please remove the jar and add the SWT library via the
Add Library... button in the Java Build Path for the project. Or for a
simpler method, create a new Visual Class with one of the SWT classes as
the base.
Hope this helps,
- Jeff
> any for SWT.
> GEF-runtime-3.1.zip
> VE-runtime-1.1.zip
Re: Missing SWT from Pallet [message #609205 is a reply to message #99571] Sat, 23 July 2005 20:37 Go to previous message
Stuart,
the base.
Hope this helps,
- Jeff
> any for SWT.
> GEF-runtime-3.1.zip
> VE-runtime-1.1.zip
Previous Topic:how to install ve 1.1?
Next Topic:Congratulations
Current Time: Sat Jul 12 17:10:11 EDT 2025
Powered by FUDForum. Page generated in 0.04605 seconds
