Home » Eclipse Projects » GEF » how to create a pop window in gef ?
how to create a pop window in gef ? [message #99415] Mon, 13 October 2003 11:34 Go to next message
Originally posted by: nemo_fc.sina.com
Is it possible to create a pop sub-window in gef? For example,I click
mouse' right button in editor,chose the context "setting" of right button
menu,then show a window which could be fill with settinng information.How
could I implement the pop window?How could I get the parent shell or
parent window for this pop window?
Re: how to create a pop window in gef ? [message #99601 is a reply to message #99415] Tue, 14 October 2003 03:02 Go to previous messageGo to next message
I have implemented that pop sub-window but how can I modify the model I
selected by fill some information in this dialog(pop sub-window)?
my right button action code:
public class nemoPropertyAction extends SelectionAction {
public static final String
PROPERTY = "Property";
public nemoPropertyAction(IWorkbenchPart part) {
super(part);
System.out.println("call getId " +getId());
this.setText("Property");
this.setToolTipText("set property");
protected boolean calculateEnabled() {
return canPerformAction();
private boolean canPerformAction() {
if(getSelectedObjects().isEmpty())
return false;
List parts = getSelectedObjects();
for (int i=0; i<parts.size(); i++){
Object o = parts.get(i);
if (!(o instanceof EditPart))
return false;
EditPart part = (EditPart)o;
if (!(part.getModel() instanceof HelloNodeModel))
return false;
return true;
public String getId() {
return this.PROPERTY;
public void run() {
Shell shell = new Shell();
nemoPropertyDialog npd = new nemoPropertyDialog(shell);
npd.open();
this my dialog code:
public class nemoPropertyDialog extends Dialog{
private Button tile, fitPage, fitWidth, fitHeight;
private Text input;
protected nemoPropertyDialog(Shell parentShell) {
super(parentShell);
protected void cancelPressed() {
super.cancelPressed();
close();
protected void configureShell(Shell newShell) {
super.configureShell(newShell);
protected Control createDialogArea(Composite parent) {
Composite composite = (Composite)super.createDialogArea(parent);
tile = new Button(composite, SWT.RADIO);
tile.setText("Tile");
tile.setSelection(true);
new Label(composite, SWT.NONE).setText("ID:");
input = new Text(composite, SWT.SINGLE | SWT.BORDER);
input.setLayoutData(new GridData(GridData.FILL_HORIZONTAL));
return composite;
protected void okPressed() {
super.okPressed();
close();
Re: how to create a pop window in gef ? [message #99847 is a reply to message #99601] Wed, 15 October 2003 06:00 Go to previous message
I find the way to implement it .thanks
"nemo" <nemo_fc@sina.com> д
Previous Topic:How can create right button menu like logic example?
Next Topic:Label left alignment
Current Time: Sun Aug 31 23:28:10 EDT 2025
Powered by FUDForum. Page generated in 0.05577 seconds
