Home » Eclipse Projects » Remote Application Platform (RAP) » a failture of org.eclipse.ui.part.ViewPart
a failture of org.eclipse.ui.part.ViewPart [message #99406] Tue, 22 July 2008 10:55 Go to next message
hi, I can only use IActionDelegate#selectionChanged() method to react to
selection changes in your ViewPart, but I need to react to the modify
changes in my view. the IActionDelegate should provide modifyChanged or
focusChanged or verifyChanged and so on.
I extends org.eclipse.ui.part.ViewPart as FormViewPart and add a TabFolder
that contains many controls such as Text, List, Button, CheckBox, Radio,
etc in it. But the items on view tool bar can not listen it when the
content of controls changes. I can not use selection change and also can
not use
org.eclipse.ui.part.ViewPart#getSite()#setSelectionProvider( );
cheers,
Dahai
Re: a failture of org.eclipse.ui.part.ViewPart [message #99538 is a reply to message #99406] Wed, 23 July 2008 07:02 Go to previous messageGo to next message
Originally posted by: fappel.innoopract.com
so what semantic does your action provide, this may helps to find a
solution for your problem.
Ciao
Frank
-----Ursprüngliche Nachricht-----
Von: Dahai Cao [mailto:dhcao2003@163.com]
Bereitgestellt: Dienstag, 22. Juli 2008 16:56
Bereitgestellt in: eclipse.technology.rap
Unterhaltung: a failture of org.eclipse.ui.part.ViewPart
Betreff: a failture of org.eclipse.ui.part.ViewPart
TabFolder
not use
cheers,
Dahai
Re: a failture of org.eclipse.ui.part.ViewPart [message #99563 is a reply to message #99538] Wed, 23 July 2008 09:02 Go to previous messageGo to next message
I extends org.eclipse.ui.part.ViewPart as FormViewPart. And I add a
TabFolder with two TabItems on the FormViewPart and hope to build a form
that contains various controls. Moreover, I add a "save" viewAction into a
FormViewPart's local tool bar to save the input data of the controls.
Initially, "save" viewAction is disabled. But when the input data of the
controls change, I hope to the "save" viewAction becomes enabled for
saving.
Now I only found that RAP provides
org.eclipse.ui.IActionDelegate#selectionChanged(org.eclipse. jface.action.IAction,
org.eclipse.jface.viewers.ISelection).
RAP should provide
org.eclipse.ui.IActionDelegate#modifyChanged(org.eclipse.jfa ce.action.IAction,
org.eclipse.ui.IActionDelegate#focusChanged(org.eclipse.jfac e.action.IAction,
and so on.
Dahai Cao
Re: a failture of org.eclipse.ui.part.ViewPart [message #99778 is a reply to message #99563] Thu, 24 July 2008 09:37 Go to previous messageGo to next message
did you thought of using the FormEditor, since you get dirty state
handling, save and save all for free?
Ciao
Frank
Bereitgestellt: Mittwoch, 23. Juli 2008 15:02
Betreff: Re: a failture of org.eclipse.ui.part.ViewPart
a
saving.
..IAction,
RAP should provide
ction,
tion,
and so on.
Dahai Cao
Re: a failture of org.eclipse.ui.part.ViewPart [message #99973 is a reply to message #99778] Thu, 24 July 2008 11:37 Go to previous messageGo to next message
FormEditor? which package does it exist? I can not find the FormEditor
class.
Re: a failture of org.eclipse.ui.part.ViewPart [message #100113 is a reply to message #99973] Fri, 25 July 2008 04:40 Go to previous messageGo to next message
it's part of the org.eclipse.rap.forms bundle and it's fully qualified
name is org.eclipse.ui.forms.editor.FormEditor. I was just thinking of
it as you are talking about forms with editing and save mechanism. The
FormEditor is even a MultiPageEditor so it would already provide you
tab-handling.
Hope that helps.
Ciao
Frank
Bereitgestellt: Donnerstag, 24. Juli 2008 17:38
class.
Re: a failture of org.eclipse.ui.part.ViewPart [message #100357 is a reply to message #100113] Mon, 28 July 2008 10:22 Go to previous messageGo to next message
But I can not find it in rap-sdk-1.1.0-R-site-20080613-1119.zip for
Eclipse 3.3 and 3.4. Where is the org.eclipse.ui.forms.editors.FormEditor?
Re: a failture of org.eclipse.ui.part.ViewPart [message #100600 is a reply to message #100357] Tue, 29 July 2008 05:00 Go to previous message
if you have configured the RAP target correctly (see windows/preferences
-> Plug-in Development/Target Platform) you should be able to find the
FormEditor e.g. by using open type (CNTL + SHIFT + T). Type 'FormEditor'
into the search text. The list field should be reduced to the FormEditor
entry - open it by double clicking the entry.
Ciao
Frank
Bereitgestellt: Montag, 28. Juli 2008 16:23
Previous Topic:tabitem features
Next Topic:Alternating Row-Colors in tables
Current Time: Sun Aug 31 06:10:50 EDT 2025
Powered by FUDForum. Page generated in 0.03368 seconds
