a failture of org.eclipse.ui.part.ViewPart [message #99406] |
Tue, 22 July 2008 10:55  |
hi, I can only use IActionDelegate#selectionChanged() method to react to
selection changes in your ViewPart, but I need to react to the modify
changes in my view. the IActionDelegate should provide modifyChanged or
focusChanged or verifyChanged and so on.
I extends org.eclipse.ui.part.ViewPart as FormViewPart and add a TabFolder
that contains many controls such as Text, List, Button, CheckBox, Radio,
etc in it. But the items on view tool bar can not listen it when the
content of controls changes. I can not use selection change and also can
not use
org.eclipse.ui.part.ViewPart#getSite()#setSelectionProvider( );
cheers,
Dahai
Re: a failture of org.eclipse.ui.part.ViewPart [message #99538 is a reply to message #99406] |
Wed, 23 July 2008 07:02   |
Originally posted by: fappel.innoopract.com
so what semantic does your action provide, this may helps to find a
solution for your problem.
Ciao
Frank
-----Ursprüngliche Nachricht-----
Von: Dahai Cao [mailto:dhcao2003@163.com]
Bereitgestellt: Dienstag, 22. Juli 2008 16:56
Bereitgestellt in: eclipse.technology.rap
Unterhaltung: a failture of org.eclipse.ui.part.ViewPart
Betreff: a failture of org.eclipse.ui.part.ViewPart
TabFolder
not use
cheers,
Dahai
Re: a failture of org.eclipse.ui.part.ViewPart [message #99778 is a reply to message #99563] |
Thu, 24 July 2008 09:37   |
did you thought of using the FormEditor, since you get dirty state
handling, save and save all for free?
Ciao
Frank
Bereitgestellt: Mittwoch, 23. Juli 2008 15:02
Betreff: Re: a failture of org.eclipse.ui.part.ViewPart
I extends org.eclipse.ui.part.ViewPart as FormViewPart. And I add a
TabFolder with two TabItems on the FormViewPart and hope to build a form
that contains various controls. Moreover, I add a "save" viewAction into
a
FormViewPart's local tool bar to save the input data of the controls.
Initially, "save" viewAction is disabled. But when the input data of the
controls change, I hope to the "save" viewAction becomes enabled for
saving.
Now I only found that RAP provides
org.eclipse.ui.IActionDelegate#selectionChanged(org.eclipse. jface.action
..IAction,
org.eclipse.jface.viewers.ISelection).
RAP should provide
org.eclipse.ui.IActionDelegate#modifyChanged(org.eclipse.jfa ce.action.IA
ction,
org.eclipse.ui.IActionDelegate#focusChanged(org.eclipse.jfac e.action.IAc
tion,
and so on.
Dahai Cao
Re: a failture of org.eclipse.ui.part.ViewPart [message #100600 is a reply to message #100357] |
Tue, 29 July 2008 05:00  |
if you have configured the RAP target correctly (see windows/preferences
-> Plug-in Development/Target Platform) you should be able to find the
FormEditor e.g. by using open type (CNTL + SHIFT + T). Type 'FormEditor'
into the search text. The list field should be reduced to the FormEditor
entry - open it by double clicking the entry.
Ciao
Frank
Bereitgestellt: Montag, 28. Juli 2008 16:23
But I can not find it in rap-sdk-1.1.0-R-site-20080613-1119.zip for
Eclipse 3.3 and 3.4. Where is the
org.eclipse.ui.forms.editors.FormEditor?
FUDForum. Page generated in 0.07683 seconds
