Home » Newcomers » Newcomers » Quickdiff does not work??
Quickdiff does not work?? [message #99371] Sun, 04 September 2005 12:21 Go to next message
Originally posted by: joNOhanSPAMn.PEnospamTRpleaseAK.cheNOlSPAMlo.at
Using Eclipse 3.1 on Linux.
I am unable to get quickdiff to work (editing file with the EPIC
plugin, but this is not plugin specific, is it?)
I would love a feature that allows me to figure out the changes
between the buffer and the saved version on disk and when I read
about quickdiff I was euphoric. Unfortunately, it does not seem
to work:
- if I show line numbers, nothing whatsoever is shown
- when I disable line numbers, I sometimes see bars where something
has been changed (but not always). Hovering over the bars does
NOT show the differences though (it shows essentiall an
empty small popup window).
Re: Quickdiff does not work?? [message #99458 is a reply to message #99371] Mon, 05 September 2005 13:18 Go to previous message
Not generally - any text editor inheriting from the text editor
framework can use quick diff out of the box.
> to work:
Sounds wrong. You can easily check whether quick diff works at all by
opening the relevant file using the eclipse text editor (from the
context menu choose 'Open With>Text Editor'). You should then see the
lines you change compared to a reference (usually either disk or your
repository, see the General>Editors>Text Editors>Quick Diff preference
page to configure the reference).
If it doesn't work with the text editor, please file a bug against
platform-text. If it does, file one against the creator of your plug-in.
HTH, tom
Previous Topic:Cannot display help contents
Next Topic:user-defined code folds & list/newsgroup question
Current Time: Mon Sep 01 01:04:52 EDT 2025
Powered by FUDForum. Page generated in 0.08153 seconds
