debug with stl code freezes [message #99365] |
Sun, 11 April 2004 22:22  |
I am trying to debug a code which uses STL classes, however, when current
scope contains objects derived from STL classes and the variables view is
being displayed, debugger freezes. I am using CDT M8 with eclipse M8 and I
also tried with M7 builds of CDT and eclipse. I can succesfully debug the
same code with eclipse 2.1.2 with CDT 1.2.1. Does anybody have a similar
problem?
Koray
Re: debug with stl code freezes [message #99412 is a reply to message #99397] |
Mon, 12 April 2004 11:05  |
I have found out that the below is not exactly true, although it may be
the case for some. There is a bug entry 56500 where you can find more
detailed info.
Koray
Koray Kavukcuoglu wrote:
> If I select Cygwin GDB debugger in debug configuration, everything works
> fine.
> Koray
> > Hi,
> > problem?
> > Thanks,
> > Koray
FUDForum. Page generated in 0.04054 seconds
