Home » Modeling » GMF (Graphical Modeling Framework) » create children automatically works in EMF editor but not using GMF editor
create children automatically works in EMF editor but not using GMF editor [message #99194] Tue, 30 January 2007 13:58 Go to next message
Originally posted by: et.email.ro
When I create a certain element of my EMF model, I want some of its
children to be automatically created.Therefore, I modified the method
collectNewChildDescriptors(...) of my XXXItemProvider.java (in the edit
plugin).
When I add the element using EMF editor, its children are created
automatically, as expected, but when I draw the element with the GMF
editor its children are not created (collectNewChildDescriptors(...) is
not invoked)
Do you have an idea why?
Thanks.
elena
Re: create children automatically works in EMF editor but not using GMF editor [message #99208 is a reply to message #99194] Tue, 30 January 2007 14:52 Go to previous message
Originally posted by: vcciubot.uwaterloo.ca
Looks like collectNewChildDescriptors does this:
* This implements {@link IEditingDomainItemProvider#getNewChildDescriptors
* IEditingDomainItemProvider.getNewChildDescriptors}, returning {@link
* org.eclipse.emf.edit.command.CommandParameter}s to describe all the possible children that can be added to the
* specified <code>object</code>.
* <p>This implementation invokes {@link #collectNewChildDescriptors collectNewChildDescriptors}, which should be
* overridden by derived classes, to build this collection.
* <p>If <code>sibling</code> is non-null, an <code>index</code> is added to each <code>CommandParameter</code> with
* a multi-valued <code>feature</code>, to ensure that the new child object gets added in the right position.
It's for showing what kind of children can be added to an element.
If you want to create children automatically, you need to override
getConfigureCommand() on the EditHelper corresponding to that element type.
There are some previous threads on this topic.
-vlad
On Tue, 30 Jan 2007 18:58:43 +0000, elena t wrote:
> plugin).
> not invoked)
> Thanks.
> elena
Previous Topic:Override a toolbar action
Next Topic:Canonical Edit Policy not being called ?
Current Time: Mon Sep 01 03:29:59 EDT 2025
Powered by FUDForum. Page generated in 0.34307 seconds
