Home » Eclipse Projects » Equinox » protocol/jar/Handler?
protocol/jar/Handler? [message #99175] Tue, 02 October 2007 12:05 Go to next message
Originally posted by: deadwinterday.yahoo.com
Hi:
I am a complete noob to OSGI, and I am having a problem attempting to load
a framework which uses OSGI via Spring. What I am basically seeing is a
stack trace that begins:
11:31:24,108 WARN [ServiceController] Problem starting service
jboss.web.deployment:war=o
ps-war-5.0.war,id=-1007247630
java.lang.LinkageError:
org/eclipse/osgi/framework/internal/protocol/jar/Handler
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:164)
org.eclipse.osgi.framework.util.SecureAction.forName(SecureA ction.java:335)
org.eclipse.osgi.framework.internal.protocol.StreamHandlerFa ctory.getBuiltIn(St
reamHandlerFactory.java:70)
org.eclipse.osgi.framework.internal.protocol.StreamHandlerFa ctory.createInterna
lURLStreamHandler(StreamHandlerFactory.java:113)
org.eclipse.osgi.framework.internal.protocol.StreamHandlerFa ctory.createURLStre
amHandler(StreamHandlerFactory.java:100)
before we even get into whu this fails, can someone explain what
org/eclipse/osgi/framework/internal/protocol/jar/Handler even means? When
I look at it in the debugger, the osgi launcher tells me that it's trying
to load org.eclipse.osgi.framework.internal.protocol.jar.Handler! I KNOW
there is no such class anywhere. Is this some wrapping mechanism, and if
so, how does it work?
-carlos rodriguez
Re: protocol/jar/Handler? [message #99205 is a reply to message #99175] Tue, 02 October 2007 16:43 Go to previous messageGo to next message
Originally posted by: alex_blewitt.yahoo.com
The normal URL handlers are not dynamic aware, so OSGi installs its own URL handler that can provide the dynamic support for the URL handlers. In this case it's looking for a Jar one, possibly using a default package naming convention to find it. I'm not sure that a jar: protocol exists.
Alex.
Re: protocol/jar/Handler? [message #99267 is a reply to message #99175] Wed, 03 October 2007 10:41 Go to previous message
A LinkageError is definitely unexpected but we need more info.
Can you tell a bit more about the environment that you're running.
e.g. which version of equinox, app server and vm as well as any application
info. e.g. what are you running Spring-OSGi and the servletbridge??
I'm not sure if it's related however there was a bug that dealt with JBoss
and URLStreamHandlers here --
https://bugs.eclipse.org/bugs/show_bug.cgi?id=156877
Perhaps there is some useful info there??
-Simon
"Carlos Rodriguez" <deadwinterday@yahoo.com> wrote in message
news:83cba68b46552a07ba08c2e7111e8b5f$1@www.eclipse.org...
> Hi:
> at
> at
> at
> at
> -carlos rodriguez
Previous Topic:Does config.ini have to be in the "configuration" directory?
Next Topic:Additional task in build of OSGi bundle
Current Time: Sun Jul 27 03:01:25 EDT 2025
Powered by FUDForum. Page generated in 0.03744 seconds
