Home » Language IDEs » PHP Development Tools (PDT) » PDT Code Assist
PDT Code Assist [message #99021] Thu, 25 June 2009 10:13 Go to next message
I'm a complete newbie to PHP and PDT, so please forgive my ignorance in
advance.
I installed Galileo and PDT yesterday, and started working through a
couple of the beginner tutorials in PDT Help. A couple of minor things
occurred.
1) I noticed that when I created a new PHP Page (file>new>PHP file)the
code page that was created lacked the closing ?> markup. Is that normal?
2) Code assist only works when I press CTL-space. I followed the help
instructions, and verified that window>preferences>PHP>editor>Code Assist
had the Enable auto activation box was checked. Actually, I still had
Ganymede files installed, so I fired it up, and it has the same behavior,
although it did add the closing ?> that I mentioned in #!.
These are minor issues, but obviously I'd like to have all the
functionality operable. Thanks, in advance, for your help, and also if
you know of any good beginner resources, I'd be happy to hear about them.
ftc
Re: PDT Code Assist [message #99052 is a reply to message #99021] Thu, 25 June 2009 10:32 Go to previous messageGo to next message
Yep, not closing a file with ?> is actually recommended.
> Assist had the Enable auto activation box was checked. Actually, I
> still had Ganymede files installed, so I fired it up, and it has the
> same behavior, although it did add the closing ?> that I mentioned in #!.
You are right that autocompletion is a bit Spartan.
In comparison to Visual Studio you need to hit the keyboard very often
to trigger autocompletion. Eclipse/pdt does litte to follow you with
advise.
You can see in window>preferences>PHP>editor>Code Assist that there are
autocompletion trigger characters. Only when you enter these characters,
autocompletion pops up. Code assist will also be there if you type "new "
Code assist is thus very limited. To improve this situation I would
suggest heading over to this bug report and add your vote:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=204768
Re: PDT Code Assist [message #99066 is a reply to message #99021] Thu, 25 June 2009 10:51 Go to previous messageGo to next message
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
> advance.
> occurred.
> ftc
Frank,
1) PHP does not require a closing "?>" on scripts. Execution will end
without a problem upon the end of a file. In fact, the Zend Framework
coding guidelines recommend leaving-off the closing "?>" if you do not
intend anything after the PHP portion of a script, as that will also
ensure there aren't any erroneous whitespace characters, which can wreak
havoc with scripts that output arbitrary data, such as a download
script. Unintended trailing whitespace is a culprit in many a broken
script.
PDT, therefore, does this intentionally.
Hopefully someone with more than just trivial knowledge can answer #2
for you. ;)
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (GNU/Linux)
Comment: Using GnuPG with Fedora - http://enigmail.mozdev.org/
iEYEARECAAYFAkpDju4ACgkQaVgOCFr0s2I8lgCdE58+v/dEAEPTu11B34Ky 5D4z
j54An0lNfAf/jXWd8jVMihrouDjy6a8S
=uVey
-----END PGP SIGNATURE-----
Re: PDT Code Assist [message #99081 is a reply to message #99052] Thu, 25 June 2009 10:56 Go to previous messageGo to next message
Hash: SHA1
Code assist is painfully slow on my Fedora system. Having it enabled
automatically, even for non-variables, seems like an impending nightmare
unless that speed is fixed.
iEYEARECAAYFAkpDkC0ACgkQaVgOCFr0s2Kr2wCfbP5iADD9pKXg5MZ33bI9 Miwb
YU4AnRyKA0Z9hwdcHPoaFT7riSqzB1ma
=CJk8
Re: PDT Code Assist [message #99127 is a reply to message #99066] Thu, 25 June 2009 16:20 Go to previous messageGo to next message
Thanks for all for your insight.
ftc
Re: PDT Code Assist [message #99192 is a reply to message #99052] Sat, 27 June 2009 07:49 Go to previous messageGo to next message
On 25.6.2009 17:32, Exception e wrote:
Thanks for this, eclipse 2.1 hangs every time when typing $ char.
So i removed it from autocompletion trigger characters and now i can "use" PDT again.
> advise.
Re: PDT Code Assist [message #99281 is a reply to message #99052] Mon, 29 June 2009 16:10 Go to previous messageGo to next message
Where do you see this recommended?
-michael
Re: PDT Code Assist [message #99293 is a reply to message #99066] Mon, 29 June 2009 16:15 Go to previous messageGo to next message
This is a thing only to be considered when using the Zend Framework! The
arguments for not closing a php tag is just an expression of bad coding
style, no matter who ever, Zend or PHP says otherwise. Clean Code or
Pragmatic Programmer or some such book is a good start for experienced
programmers to sharpen up your talents.
-michael
Re: PDT Code Assist [message #99308 is a reply to message #99293] Mon, 29 June 2009 17:08 Go to previous messageGo to next message
What does make you think that this is only to be considered for zf?
Not closing php scope helps prevent accidents like additional whitespace
which will cause session initialization to fail ("headers already sent").
So this applies to quite a lot of situations.
It's nice you've seen or read the books you mentioned, but it has
nothing to do with this practice.
Re: PDT Code Assist [message #99337 is a reply to message #99281] Tue, 30 June 2009 06:05 Go to previous messageGo to next message
Michael Madsen napsal(a):
e.g. here:
http://framework.zend.com/manual/en/coding-standard.php-file -formatting.html#coding-standard.php-file-formatting.general
Re: PDT Code Assist [message #99396 is a reply to message #99337] Tue, 30 June 2009 10:19 Go to previous messageGo to next message
Originally posted by: ernst.cron-it.de
sNop wrote: on 30.06.2009 12:05:
> e.g. here:
To me that is a nonesense recommendation.
You could as well define in your coding guidelines that "no empty lines
are permitted after the closing ?>". How should that "inject trailing
white space into the response"???
Ernesto
Re: PDT Code Assist [message #99425 is a reply to message #99396] Tue, 30 June 2009 11:17 Go to previous messageGo to next message
Hash: SHA1
>> e.g. here:
> Cheers,
> Ernesto
One advantage would be that, as a recommendation, it would work in all
editors. Some (poorly-designed) editors don't give the coder complete
control over their editing, and thus, sometimes add whitespace
characters when they try to "help" him. By leaving-out the closing tag
at the end of the file, even this is worked around.
I cannot speak for the framers of the Zend Framework coding
recommendations, but I like this particular recommendation, and follow
it myself, and I am sure there are other reasons to do so as well.
The fact that it's perfectly valid PHP markup should really make it a
non-issue. It's just the default PHP template in PDT, which was written
with the Zend Framework in mind.
iEYEARECAAYFAkpKLIQACgkQaVgOCFr0s2JtqgCgmhZsOcQqbiWwBF/VwezG L0gg
VRgAoKKwc//Rfg5L5Cr4DPIUGaqKJe0/
=OXWR
Re: PDT Code Assist [message #99451 is a reply to message #99425] Wed, 01 July 2009 05:24 Go to previous messageGo to next message
That is not an advantage but a quickfix for a problem elsewhere. Look at
IE, a poorly designed browser for which we have to make hacks and what
not. The problem is IE, not that hacks aer hard to implement and
timeconsuming. As I stated in another reply here, this recommendation is
only for when the zend framework is used and NOT for normal php
development. Making quickfixes to cover up bad coding style and/or
discipline does not justify them.
> non-issue.
Good programming experience tells us not to relay too heavily on
language defaults as they can change over time or introduce issues. Just
because we can, doesn't mean we should.
-michael
Re: PDT Code Assist [message #99463 is a reply to message #99308] Wed, 01 July 2009 05:32 Go to previous messageGo to next message
If you read me post closely you will find the answer. But to help you
this is it:
The arguments for not closing a php tag is just an expression of bad
coding style, no matter who ever, Zend or PHP says otherwise.
If you have problems with whitespaces either enable pdt's removal of
trailing whitespace or remove manually. I would suspect the cause of
this problem is to much copy&paste. I don't have this problem and when
it happens from time to time, I am noticed by php when the page is run.
If this is a problem it sounds like you are doing development on live
sites which in any case is a big mistake and still does not make your
arguments valid.
-michael
Re: PDT Code Assist [message #99477 is a reply to message #99451] Wed, 01 July 2009 07:02 Go to previous messageGo to next message
Hash: SHA1
>> non-issue.
It's also documented within the PHP manual here:
http://www.php.net/manual/en/language.basic-syntax.instructi on-separation.php
I don't want to drive the point, but you are equating it with bad
programming style, whereas I disagree and see it as fine. I think part
of the advantage for me is that I do *not* mix PHP & non-PHP (e.g.,
HTML) code output. I do everything from within PHP, so my PHP files are
all PHP code, and do not enter and escape from HTML. I do this for
consistency purposes, and therefore, I have no need to use the closing
PHP tags. So, it fits in well with my style.
iEYEARECAAYFAkpLQlMACgkQaVgOCFr0s2LSMACgsBhZRvuo50s2B2Bqr8px mLaX
34IAnitDHUmFh4JQlmn6KdP7TY4u2INB
=AJja
Re: PDT Code Assist [message #99491 is a reply to message #99192] Thu, 02 July 2009 10:07 Go to previous messageGo to next message
Hello.
I have the exact same problem. I'm a bit new to bugzilla & stuff so I
don't know how to post this and where...
It used to work well in 2.1 RC but on the final release, typing a $ will
make Eclipse hangs and use a lot of memory...
I removed autocompletion for a while but it is NOT a solution.
Best.
PDT again.
Re: PDT Code Assist [message #99505 is a reply to message #99491] Fri, 03 July 2009 22:44 Go to previous messageGo to next message
Originally posted by: dcarver.starstandard.org
Report bugs at:
http://bugs.eclipse.org/bugs
Dave
Bruce Heller wrote:
> Hello.
> Best.
>> "use"
> PDT again.
Re: PDT Code Assist [message #99702 is a reply to message #99021] Mon, 06 July 2009 15:27 Go to previous message
I experience something strange with code assist in 2.1.
It is working fine at root level in a php file,
but if start a function, inside the function it does not work
for global variables ($GLOBALS, $_REQUEST, etc.).
It works only for variables defined inside the function.
Is this intentional, or is there a preferences setting for it?
Andras J.
Previous Topic:Line indentation, different from project to project
Next Topic:Build path contains duplicate entry
Current Time: Mon Sep 01 01:22:58 EDT 2025
Powered by FUDForum. Page generated in 0.12197 seconds
