Home » Language IDEs » ServerTools (WTP) » key and keyref not validated via xsd?
key and keyref not validated via xsd? [message #99007] Wed, 04 May 2005 21:28 Go to next message
Originally posted by: news.ronald.vankuijk.net
I've taken an example xsd from the internet (http://www.xml.com/2002/09/04/examples/Workflow.xsd.txt) with a key and
keyref in it. It seems however that WTP1.0M4 (with eclipse 3.1m6 jdk1.4.2_05 on linux) does not validate against these
key/keyrefs. ID and IDREF do work.
If someone can confirm this I'll file a bug report.
Ronald
Re: key and keyref not validated via xsd? [message #99064 is a reply to message #99007] Thu, 05 May 2005 04:23 Go to previous messageGo to next message
Originally posted by: george.oxygenxml.com
Hi Ronald,
There is a known and already solved in CVS bug in Xerces 2.6.2, it does not
work correctly if the constraint contains multiple fields, see:
http://issues.apache.org/jira/browse/XERCESJ-1000
Best Regards,
George
George Cristian Bina
<oXygen/> XML Editor, Schema Editor and XSLT Editor/Debugger
http://www.oxygenxml.com
"Ronald van Kuijk" <news@ronald.vankuijk.net> wrote in message
news:d5bt7e$q2u$1@news.eclipse.org...
> Ronald
Re: key and keyref not validated via xsd? [message #99553 is a reply to message #99064] Thu, 05 May 2005 14:12 Go to previous messageGo to next message
George,
Thanks for your response. The examples I've run do not contain multiple fields, but I tried other examples anyway (one
from http://www.oxygenxml.com/forum/ftopic679.html) That one works, so I focussed on using/adapting that one.
There is one major difference between the working example and the functionality that I want. It has to do with nesting
and so probably my xpath in either the selector or the field are wrong. I'll look further into that but post it here
anyway in case someone (you? ;-) ) see the mistake I make (the xpath should eventually contain an or since a transition
can go to any kinde of node including the one it is in)
xml document: ---------------------------------------
<p:process-definition xmlns:p="http://www.example.org/process"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://www.example.org/process process.xsd ">
<p:state name="S1">
<p:transition to="S2" />
</p:state>
<p:state name="S2">
<p:transition to="D1" />
</p:state>
<p:decision name="D1">
<p:transition to="E1" />
</p:decision>
<p:end-state name="E1">
</p:end-state>
</p:process-definition>
xsd snippet (is on top-level element) -----------------------------------------------
<xsd:key name="nameKey">
<xsd:selector xpath="./state" />
<xsd:field xpath="@name" />
</xsd:key>
<xsd:keyref name="toRef" refer="nameKey">
<xsd:selector xpath="state/transition" />
<xsd:field xpath="@to" />
</xsd:keyref>
George Bina wrote:
> Hi Ronald,
> Best Regards,
> George
>>Hi,
>>Ronald
George
Re: key and keyref not validated via xsd? [message #100066 is a reply to message #99553] Fri, 06 May 2005 09:31 Go to previous message
Hi Ronald,
At a first glance the problems seems to be that you are referring in the
identity constraints to elements from no namespace:
while in your document the state and transition elements are from
http://www.example.org/process namespace.
You should declare a proxy for http://www.example.org/process in your schema
(for instance xmlns:p="http://www.example.org/process") then use that to
prefix state and transition elements in the xs:selector/@xpath value, for
instance
<xsd:selector xpath="./p:state" />
<xsd:selector xpath="p:state/p:transition" />
The XPath expressions do not know the default namespace, elements without a
proxy are in no namespace.
Best Regards,
George
news:427A621F.6090207@ronald.vankuijk.net...
> George,
> <p:state name="S1">
> </p:state>
> <p:state name="S2">
> </p:state>
> </p:decision>
> </p:end-state>
> </xsd:key>
> </xsd:keyref>
> George Bina wrote:
> > Hi Ronald,
not
> > Best Regards,
> > George
> >>Hi,
> >>Ronald
> George
Previous Topic:java code completion
Next Topic:Change context root
Current Time: Mon Sep 01 01:22:22 EDT 2025
Powered by FUDForum. Page generated in 0.04561 seconds
