Home » Language IDEs » C / C++ IDE (CDT) » Ext. Connection Method
Ext. Connection Method [message #98998] Tue, 06 April 2004 22:59
Originally posted by: ra2833.hotmail.com
E3.0M8
when at:
Window --> Prefrences --> Team --> CVS --> Ext Connection Method,
i have three fields to input data:
CVS_RSH: C:\Program Files0\SSH Communications Security\SSH Secure
Shell\ssh2.exe
Parameters: {host}-l{user} (left alone)
CVS_SERVER: cvs
on the Ext Connection Method window there is two sentences, the second one
is what concerns me the most... can someone tell me how to interpret the
message, what am i suppose to do with it.. it says:
These values should be the same as the 'ext' CVS command-line environment
variable settings.
my problem is that i am not able to connect successfully to the cvs
server, i also attempted to use the SSH2 Connection Method but no go
iether.
thank you in advance
Hector
Previous Topic:How to hide closed project item?
Next Topic:adding toolchain specific GDB
Current Time: Mon Jul 14 00:59:23 EDT 2025
Powered by FUDForum. Page generated in 0.03398 seconds
