Home » Modeling » GMF (Graphical Modeling Framework) » Problem with GMF editor resulting from from xsd
Problem with GMF editor resulting from from xsd [message #98958] Tue, 30 January 2007 10:07 Go to next message
Originally posted by: christian.daenekas.informatik.uni-oldenburg.de
I thought of using a xsd as the base for an editor. So I generated an
ecore and genmodel file from the xsd that we are using in our project.
Everything worked fine for me until code generation. In ecore models
derived from xsd models there is this artificial root element
Diagramroot. The generated code contains the following passage:
* @generated
private static EObject createInitialRoot(DocumentRoot model) {
DocumentRoot docRoot = EditorFactory.eINSTANCE.createDocumentRoot();
docRoot.setnull(model);
return docRoot;
The setnull method that is called does not exist and I have no idea what
is supposed to be done there. When I delete the line (thought it´s worth
a try) everything compiles fine, the editor application is able to
create a diagram but I am not able to place any nodes from the palette
onto the Canvas. The file containing the "semantic" model contains
nothing but this:
Does anyone here have an idea whats going wrong there? The xsd is valid
so this can´t be the problem I think. Thank you in advance.
Greetings,
Christian
Re: Problem with GMF editor resulting from xsd [message #98974 is a reply to message #98958] Tue, 30 January 2007 10:10 Go to previous messageGo to next message
Forgot to say that I´m using GMF 2.0 (19.01.2007 nightly).
Christian Dänekas schrieb:
> Hello,
> * @generated
> return docRoot;
> nothing but this:
> Greetings,
> Christian
Re: Problem with GMF editor resulting from xsd [message #98987 is a reply to message #98974] Tue, 30 January 2007 10:26 Go to previous messageGo to next message
Okay I just found something related to this issue, but I don´t fully
understand. Where do I have to look for a failure?
'null' means generator failed to find a feature to set domainMetaElement
into DocumentRoot. Could you please check there's a stuctural feature
inside
DocumentRoot with domainMetaElement as eReferenceType?
Artem
"Jiefei" <majiefei@xxxxxxxxxxxxxxxxx> wrote in message
news:f89f488bf13cbbcf8d32a03d5e85f3a3$1@xxxxxxxxxxxxxxxxxx
> I mapped the DocumentRoot as the doaminMetaElement of the diagram.
But in
> the generated diagram code, the createInitialRoot(DocumentRoot model)
> method (in the FooDiagramEditorUtil class) has the implementation like:
> DocumentRoot docRoot = FooFactory.eINSTANCE.createDocumentRoot();
> return docRoot;
> I dont understand why it generates "setnull". is it a bug?
> cheers,
> Jiefei
>> Hello,
>> * @generated
>> return docRoot;
>> what is supposed to be done there. When I delete the line (thought
>> it´s worth a try) everything compiles fine, the editor application is
>> able to create a diagram but I am not able to place any nodes from the
>> palette onto the Canvas. The file containing the "semantic" model
>> contains nothing but this:
>> <?xml version="1.0" encoding="UTF-8"?>
>> valid so this can´t be the problem I think. Thank you in advance.
>> Greetings,
>> Christian
Re: Problem with GMF editor resulting from xsd [message #99565 is a reply to message #98987] Wed, 31 January 2007 09:30 Go to previous messageGo to next message
Please take a look at the screenshot attached. Map is domainMetaElement of
the MindMap domain model, and DocumentRoot.map feature (highlighted) is the
feature I was referring to below. You may want to check
org.eclipse.gmf.examples.mindmap (/model/mindmap.ecore) from GMF examples,
which is xsd-based model.
There's some nasty logic detecting exact feature, perhaps, there's something
wrong with what's expected. Would be great if you provide us with copy of
..xsd file you are using (actually, definition of top xml elements only is
needed, you can wipe the rest).
To workaround the issue, just replace setnull with appropriate setter for
your root model element.
Artem
"Christian Danekas" <christian.daenekas@informatik.uni-oldenburg.de> wrote
in message news:epno3r$isa$1@utils.eclipse.org...
> Okay I just found something related to this issue, but I don?t fully
> From: "Artem Tikhomirov":
> inside
> Artem
> > Hi,
> But in
> > return docRoot;
> > cheers,
> > Jiefei
> Christian Danekas schrieb:
>> Forgot to say that I?m using GMF 2.0 (19.01.2007 nightly).
>>> Hello,
>>> * @generated
>>> return docRoot;
>>> it?s worth a try) everything compiles fine, the editor application is
>>> valid so this can?t be the problem I think. Thank you in advance.
>>> Greetings,
>>> Christian
Re: Problem with GMF editor resulting from xsd [message #100617 is a reply to message #99565] Fri, 02 February 2007 10:07 Go to previous messageGo to next message
Thank you, I managed to solve the problem by modifying the ecore model.
Mine looks exactly the same as the Mindmap model concerning the
DocumentRoot Class. Instead of Map I have a reference to differently
named class, which is also the diagram canvas. But there must be
something wrong still. When I generate all the code and launch the
application I can create a new diagram. But sometimes there is no canvas
element created at all and I can´t place my nodes on the Diagram, and
other times there is first the DocumentRoot and the canvas I defined is
below (in the semantic model file). I want my editor start the semantic
model files like in the mindmap example where the DocumentRoot element
can not be seen and the tree structure starts with <mindmap . I can´t
find a difference between my models and the mindmap example. But when I
changed the Extended metadata of my canvas element (the name started
with lower case, I altered it to upper case) the behavior changed and
the canvas plus DocumentRoot was created (before this change there was
no canvas). I fail to see the logic behind this. Could you help me out
again?
Greetings,
Christian
Artem Tikhomirov schrieb:
> <<untitled2.png>>
is the
examples,
something
copy of
only is
for
> Artem
>> inside
>> Artem
>>> Hi,
>> But in
>>> return docRoot;
>>> cheers,
>>> Jiefei
>>>> Hello,
>>>> * @generated
>>>> return docRoot;
>>>> Greetings,
>>>> Christian
Re: Problem with GMF editor resulting from xsd [message #100644 is a reply to message #100617] Fri, 02 February 2007 10:45 Go to previous messageGo to next message
> DocumentRoot Class. Instead of Map I have a reference to differently named
> class, which is also the diagram canvas. But there must be something wrong
> still.
Would be handy to get your ecore model (stripped down to DocumentRoot and
top level class) to take a look.
> I want my editor start the semantic model files like in the mindmap
> example where the DocumentRoot element can not be seen and the tree
GMF's generated code does nothing special about the way elements get
persisted. That's up to EMF code. If you see DocumentRoot, check that
appropriate ResourceFactory gets registered.
> But when I changed the Extended metadata of my canvas element (the name
> started with lower case, I altered it to upper case) the behavior changed
> and the canvas plus DocumentRoot was created (before this change there was
Me neither, though I'm not an XSD expert ;). I'm affraid, that's not GMF
question, .
in message news:epvk4f$erj$1@utils.eclipse.org...
> still. When I generate all the code and launch the application I can
> create a new diagram. But sometimes there is no canvas element created at
> all and I can?t place my nodes on the Diagram, and other times there is
> first the DocumentRoot and the canvas I defined is below (in the semantic
> model file). I want my editor start the semantic model files like in the
> mindmap example where the DocumentRoot element can not be seen and the
> tree structure starts with <mindmap . I can?t find a difference between my
> models and the mindmap example. But when I changed the Extended metadata
> of my canvas element (the name started with lower case, I altered it to
> upper case) the behavior changed and the canvas plus DocumentRoot was
> created (before this change there was no canvas). I fail to see the logic
> behind this. Could you help me out again?
> Greetings,
> Christian
> > <<untitled2.png>>
> is the
> examples,
> something
> copy of
> only is
> for
> > Artem
> >> domainMetaElement
> >> inside
> >> Artem
> >>> Hi,
> >> But in
> >>> like:
> >>> return docRoot;
> >>> cheers,
> >>> Jiefei
> >>>> Hello,
> >>>> project.
> >>>> * @generated
> >>>> return docRoot;
> >>>> the
> >>>> Greetings,
> >>>> Christian
Re: Problem with GMF editor resulting from xsd [message #100668 is a reply to message #100644] Fri, 02 February 2007 10:54 Go to previous messageGo to next message
--------------030908070409080304020504
Artem,
I'm watching this thread. I don't understand why it would be necessary
to tweak any of the Ecore model that's produced automatically from the
schema. This document shows how XML Schema annotations can be used to
affect names or other mappings:
http://www.eclipse.org/modeling/emf/docs/overviews/XMLSchema ToEcoreMapping.pdf
Your advice about ensuring that the right type of resource with the
right options (i.e., the generated XyzResourceFactoryImpl) is being used
is good.
If XSD expertise is required, I'll be happy to help out (as long as I
understand specifically what the issue is, which at this point I don't).
Artem Tikhomirov wrote:
>> still.
> question, .
>> Greetings,
>> Christian
>>> <<untitled2.png>>
>> is the
>> examples,
>> something
>> copy of
>> only is
>> for
>>> Artem
>>>> domainMetaElement
>>>> inside
>>>> Artem
>>>>> Hi,
>>>> But in
>>>>> like:
>>>>> return docRoot;
>>>>> cheers,
>>>>> Jiefei
>>>>>> Hello,
>>>>>> project.
>>>>>> * @generated
>>>>>> return docRoot;
>>>>>> the
>>>>>> Greetings,
>>>>>> Christian
<html>
<head>
</head>
Artem,<br>
<br>
I'm watching this thread.&nbsp; I don't understand why it would be necessary
affect names or other mappings:<br>
<blockquote><a
href=" http://www.eclipse.org/modeling/emf/docs/overviews/XMLSchema ToEcoreMapping.pdf"> http://www.eclipse.org/modeling/emf/docs/overviews/XMLSchema ToEcoreMapping.pdf</a><br>
</blockquote>
used is good.<br>
<br>
understand specifically what the issue is, which at this point I don't).<br>
<br>
<br>
<blockquote cite="midepvmb7$jri$1@utils.eclipse.org" type="cite">
<pre wrap="">Hi,
</pre>
<blockquote type="cite">
<pre wrap="">Mine looks exactly the same as the Mindmap model concerning the
still.
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
<pre wrap="">I want my editor start the semantic model files like in the mindmap
structure starts with &lt;mindmap .
</pre>
</blockquote>
</pre>
<pre wrap="">But when I changed the Extended metadata of my canvas element (the name
</pre>
</blockquote>
question, .
"Christian Danekas" <a class="moz-txt-link-rfc2396E" href="mailto:christian.daenekas@informatik.uni-oldenburg.de">&lt;christian.daenekas@informatik.uni-oldenburg.de&gt;</a> wrote
in message <a class="moz-txt-link-freetext" href="news:epvk4f$erj$1@utils.eclipse.org">news:epvk4f$erj$1@utils.eclipse.org</a>...
</pre>
<pre wrap="">Thank you, I managed to solve the problem by modifying the ecore model.
tree structure starts with &lt;mindmap . I can?t find a difference between my
Greetings,
Christian
</pre>
<pre wrap=""> &lt;&lt;untitled2.png&gt;&gt;
</pre>
</blockquote>
<pre wrap="">domainMetaElement of
</pre>
<pre wrap="">the MindMap domain model, and DocumentRoot.map feature (highlighted)
</pre>
</blockquote>
<pre wrap="">is the
</pre>
<pre wrap="">feature I was referring to below. You may want to check
</pre>
</blockquote>
<pre wrap="">examples,
</pre>
<pre wrap="">which is xsd-based model.
</pre>
</blockquote>
<pre wrap="">something
</pre>
<pre wrap="">wrong with what's expected. Would be great if you provide us with
</pre>
</blockquote>
<pre wrap="">copy of
</pre>
<pre wrap="">.xsd file you are using (actually, definition of top xml elements
</pre>
</blockquote>
<pre wrap="">only is
</pre>
<pre wrap="">needed, you can wipe the rest).
</pre>
</blockquote>
<pre wrap="">for
</pre>
<pre wrap="">your root model element.
Artem
</pre>
</blockquote>
<pre wrap="">wrote
</pre>
<pre wrap="">in message <a class="moz-txt-link-freetext" href="news:epno3r$isa$1@utils.eclipse.org">news:epno3r$isa$1@utils.eclipse.org</a>...
</pre>
<pre wrap="">Okay I just found something related to this issue, but I don?t fully
domainMetaElement
inside
Artem
"Jiefei" &lt;majiefei@xxxxxxxxxxxxxxxxx&gt; wrote in message
<a class="moz-txt-link-freetext" href="news:f89f488bf13cbbcf8d32a03d5e85f3a3$1@xxxxxxxxxxxxxxxxxx">news:f89f488bf13cbbcf8d32a03d5e85f3a3$1@xxxxxxxxxxxxxxxxxx</a>
</pre>
<pre wrap="">Hi,
</pre>
</blockquote>
<pre wrap="">But in
</pre>
<pre wrap="">the generated diagram code, the createInitialRoot(DocumentRoot model)
like:
return docRoot;
cheers,
Jiefei
</pre>
</blockquote>
<pre wrap="">Christian Danekas schrieb:
</pre>
<pre wrap="">Forgot to say that I?m using GMF 2.0 (19.01.2007 nightly).
</pre>
<pre wrap="">Hello,
project.
* @generated
return docRoot;
the
&lt;?xml version="1.0" encoding="UTF-8"?&gt;
/&gt;
Greetings,
Christian
</pre>
</blockquote>
</blockquote>
</blockquote>
<pre wrap="">
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
--------------030908070409080304020504--
Re: Problem with GMF editor resulting from xsd [message #101361 is a reply to message #100644] Tue, 06 February 2007 05:02 Go to previous messageGo to next message
Thank you for your help Artem and Ed. Since the news server didn´t seem
to work the last 2 days I couldn´t write earlier. It´s really strange,
but after I changed the name attribute of my canvas element extended
metadata to "Metric" instead of "metric" and altered the ecore root
package name and the model file extension to "metric" and regenerated
the whole code it works and my model file starts with <metric> and the
canvas of the diagram is also linked to this element. In my desperation
I tried to synchronize the mindmap example and my editor as far as I
could (concerning the elements properties) and it worked.
Greetings,
Christian
>> still.
> question, .
>> Greetings,
>> Christian
>>> <<untitled2.png>>
>> is the
>> examples,
>> something
>> copy of
>> only is
>> for
>>> Artem
>>>> domainMetaElement
>>>> inside
>>>> Artem
>>>>> Hi,
>>>> But in
>>>>> like:
>>>>> return docRoot;
>>>>> cheers,
>>>>> Jiefei
>>>>>> Hello,
>>>>>> project.
>>>>>> * @generated
>>>>>> return docRoot;
>>>>>> the
>>>>>> Greetings,
>>>>>> Christian
Re: Problem with GMF editor resulting from xsd [message #101528 is a reply to message #101361] Tue, 06 February 2007 10:21 Go to previous message
Christian,
This sounds likely to be related to what type of resource is being used
to save and load instances. When the option
XMLResource.OPTION_EXTENDED_META_DATA is used, the code use the original
XML names (as recorded in the extended meta data annotations) for
reading and writing; without that option, the code will use the actual
names of the classes and features as used in the Ecore model. The
handling of the root element is also different in each case. When using
extended meta data, the root element name of the instance must patch
exactly the XML name of an element-based feature in the DocumentRoot;
without extended metadata, the root element name is looked up as an
EClass in the EPackage corresponding to the element's namespace. Given
your comment about changing the file extension to metric, it's highly
likely that you are seeing behavior differences depending on which
resource factory is being used (and hence which options are being used
for load and save).
> seem to work the last 2 days I couldn´t write earlier. It´s really
> strange, but after I changed the name attribute of my canvas element
> extended metadata to "Metric" instead of "metric" and altered the
> ecore root package name and the model file extension to "metric" and
> regenerated the whole code it works and my model file starts with
> <metric> and the canvas of the diagram is also linked to this element.
> In my desperation I tried to synchronize the mindmap example and my
> editor as far as I could (concerning the elements properties) and it
> worked.
> Greetings,
> Christian
>> and top level class) to take a look.
>>> name started with lower case, I altered it to upper case) the
>>> behavior changed and the canvas plus DocumentRoot was created
>>> behind this.
>> GMF question, .
>> wrote in message news:epvk4f$erj$1@utils.eclipse.org...
>>> model. Mine looks exactly the same as the Mindmap model concerning
>>> the DocumentRoot Class. Instead of Map I have a reference to
>>> differently named class, which is also the diagram canvas. But there
>>> must be something wrong still. When I generate all the code and
>>> launch the application I can create a new diagram. But sometimes
>>> there is no canvas element created at all and I can?t place my nodes
>>> on the Diagram, and other times there is first the DocumentRoot and
>>> the canvas I defined is below (in the semantic model file). I want
>>> my editor start the semantic model files like in the mindmap example
>>> my models and the mindmap example. But when I changed the Extended
>>> metadata of my canvas element (the name started with lower case, I
>>> altered it to upper case) the behavior changed and the canvas plus
>>> DocumentRoot was created (before this change there was no canvas). I
>>> fail to see the logic behind this. Could you help me out again?
>>> Greetings,
>>> Christian
>>>> <<untitled2.png>>
>>> is the
>>> examples,
>>> something
>>> copy of
>>> only is
>>> for
>>>> Artem
>>>>> domainMetaElement
>>>>> inside
>>>>> Artem
>>>>>> Hi,
>>>>> But in
>>>>>> model)
>>>>>> like:
>>>>>> return docRoot;
>>>>>> cheers,
>>>>>> Jiefei
>>>>>>> Hello,
>>>>>>> generated an
>>>>>>> project.
>>>>>>> models
>>>>>>> * @generated
>>>>>>> return docRoot;
>>>>>>> application is
>>>>>>> from the
>>>>>>> Greetings,
>>>>>>> Christian
Previous Topic:I do not want to show PopupBar,how can I do?
Next Topic:Outline View at Runtime??
Current Time: Mon Oct 27 17:48:02 EDT 2025
Powered by FUDForum. Page generated in 0.06316 seconds
