Home » Eclipse Projects » Remote Application Platform (RAP) » Problems with war deployment on weblogic and websphere
Problems with war deployment on weblogic and websphere [message #98887] |
Fri, 18 July 2008 07:16  |
I am trying to deploy a simple test application on websphere 6.1 and
weblogic 8.1.
Using tomcat 5.5.26 everything works fine!
But on websphere I get the following message when opening the sample page:
Error 500: An entry point named 'default' does not exist.
On Weblogic I get some more Information:
Error 500--Internal Server Error
java.lang.IllegalArgumentException: An entry point named 'default' does
not exist.
org.eclipse.rwt.internal.lifecycle.EntryPointManager.createU I(EntryPointManager.java:77)
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.createUI(RWT LifeCycle.java:230)
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle$UIThreadCont roller.run(RWTLifeCycle.java:116)
at java.lang.Thread.run(Thread.java:534)
I already read lots of posting but can not find a solution.
My extensions section in plugin.xml looks like:
<extension
point="org.eclipse.rap.ui.entrypoint">
<entrypoint
class="org.eclipse.rap.helloworld.HelloWorldWorkbench"
id="org.eclipse.rap.helloworld.helloWorldWorkbench"
parameter="default">
</entrypoint>
</extension>
<extension
point="org.eclipse.ui.views">
<view
class="org.eclipse.rap.helloworld.HelloWorldView"
id="org.eclipse.rap.helloworld.helloWorldView"
name="Hello World"
restorable="true">
</view>
</extension>
<extension
point="org.eclipse.ui.perspectives">
<perspective
class="org.eclipse.rap.helloworld.Perspective"
id="org.eclipse.rap.helloworld.perspective"
name="Hello World Perspevtive">
</perspective>
</extension>
The config.ini is here:
#Eclipse Runtime Configuration File
osgi.bundles=org.eclipse.equinox.http.registry_1.0.100.200807150941.jar@start,org.eclipse.equinox.http.servlet_1.0.100.200807150941.jar@start, org.eclipse.equinox.http.servletbridge_1.0.0.200807150941.ja r @start,org.eclipse.core.commands_3.4.0.I20080509-2000.jar@start,org.eclipse.core.contenttype_3.3.0.v20080604-1400.jar@start,org.eclipse.core.jobs_3.4.0.v20080512.jar@start,org.eclipse.core.runtime_3.4.0.v20080512.jar@start,org.eclipse.equinox.common_3.4.0.v20080421-2006.jar@2:start,org.eclipse.equinox.preferences_3.2.200.v20080421-2006.jar@start,org.eclipse.equinox.registry_3.4.0.v20080516-0950.jar@start,org.eclipse.osgi.services_3.1.200.v20071203.jar@start,org.eclipse.rap.jface_1.1.0.20080613-1055.jar@start,org.eclipse.rap.rwt_1.1.0.20080613-1055.jar@start,org.eclipse.rap.ui.workbench_1.1.0.20080613-1055.jar@start,org.eclipse.core.expressions_3.4.0.v20080603-2000.jar@start,org.eclipse.equinox.app_1.1.0.v20080421-2006.jar@start,org.eclipse.rap.ui_1.1.0.20080613-1055.jar@start,org.eclipse.rap.rwt.q07_1.1.0.20080613-1055.jar,org.eclipse.rap.jface.databinding_1.1.0.20080613-1055.jar@start,org.eclipse.core.databinding_1.1.0.I20080527-2000.jar@start,com.ibm.icu_3.8.1.v20080530.jar@start,org.eclipse.rap.ui.views_1.1.0.20080613-1055.jar@start,HelloRAP_1.0.0.jar@start,org.eclipse.equinox.servletbridge.extensionbundle
osgi.bundles.defaultStartLevel=4
To create the war file I used the following plugins of the demo
application and the servlet bridge and followed
the instructions in "How to deploy a RAP application to a servlet
container?".
javax.servlet 2.4.0
javax.servlet.source
org.eclipse.equinox.servletbridge.feature
org.eclipse.rap.demo.feature
Re: Problems with war deployment on weblogic and websphere [message #98901 is a reply to message #98887] |
Fri, 18 July 2008 08:04   |
Originally posted by: fappel.innoopract.com
the missing entrypoint message usually is a following up error, if the
bundle start of the bundle that declares the entry point fails. Please
have a look at the equinox .log file entries for more information about
this. One problem may be that the the java version of the classes in the
bundle are higher than that of the server-runtime - just a wild guess.
Ciao
Frank
-----Ursprüngliche Nachricht-----
Von: Barthel Steckemetz [mailto:Barthel.Steckemetz@gmail.com]
Bereitgestellt: Freitag, 18. Juli 2008 13:17
Bereitgestellt in: eclipse.technology.rap
Unterhaltung: Problems with war deployment on weblogic and websphere
Betreff: Problems with war deployment on weblogic and websphere
weblogic 8.1.
page:
'default' does
not exist.
Manager.java:77)
va:230)
<extension
<entrypoint
</entrypoint>
</extension>
<extension
<view
name="Hello World"
restorable="true">
</view>
</extension>
<extension
<perspective
</perspective>
</extension>
osgi.bundles=org.eclipse.equinox.http.registry_1.0.100.20080 7150941.jar@
start,org.eclipse.equinox.http.servlet_1.0.100.200807150941.jar@start,or
g.eclipse.equinox.http.servletbridge_1.0.0.200807150941.jar@start,org.ec
..eclipse.rap.rwt_1.1.0.20080613-1055.jar@start,org.eclipse.rap.ui.workbe
t.q07_1.1.0.20080613-1055.jar,org.eclipse.rap.jface.databind ing_1.1.0.20
container?".
javax.servlet 2.4.0
Re: Problems with war deployment on weblogic and websphere [message #99215 is a reply to message #98901] |
Tue, 22 July 2008 04:47  |
Thanks Frank,
you guess was right. Works now on Websphere.
Just for the record:
1. I found the relevant log-file in:
/opt/IBM/Websphere61/AppServer/profiles/AppSrv01/temp/node_1 /server1/rapdemo/rapdemo.war/eclipse/workspace/.metadata/.lo g
2. The server was running with java 5, our application class files were
using java 6.
3. When exporting a plugin using the export wizard the Java-Files are once
more compiled. This time using the first (I guess) JDK listet in
plugin.xml; Overview; Execution Environment.
Current Time: Tue Jul 15 07:09:13 EDT 2025
Powered by FUDForum. Page generated in 0.26355 seconds
