Get position within action [message #98742] |
Sat, 11 October 2003 17:28  |
Originally posted by: felix.mayer.comcast.net
I have an EditorPartAction that is used from within a context menu on my
diagram. To check if the action should be enabled, I would like to know if
the mouse was right-clicked on a node or somewhere else within the diagram.
When the action is executed, I would like to have the coordinates where the
right-click happened. Can anybody give me a hint as to how I could achieve
that? I looked around in the action classes and couldn't find anything.
Thanks, Felix
Re: Get position within action [message #99370 is a reply to message #98877] |
Mon, 13 October 2003 10:35   |
You can't rely on the mouse location when bringing up the context menu,
because the user could open the context menu with the keyboard
(Shift+F10) and the mouse could be somewhere off the editor. I would
suggest your action look at selection, not mouse location, to determine
enablement. If the selected edit parts are all nodes, the action is
enabled. Otherwise, the action is disabled. The logic editor does this
with LEDs and the increment/decrement actions (see
IncrementDecrementAction.canPerformAction()).
Felix Mayer wrote:
> Actually, I think what I really need to know is where the mouse was
> right-clicked.
> "Felix Mayer" <felix.mayer@comcast.net> wrote in message
> news:bm9smg$ilv$1@eclipse.org...
> diagram.
> the
>>Thanks, Felix
Re: Get position within action [message #99764 is a reply to message #99370] |
Tue, 14 October 2003 15:54  |
Since I had to whole weekend, I was able to figure something out:
Within the action, I am able to get the IWorkbenchPart, from that the
DefaultEditDomain, from that the SelectionTool and from that the
AbstractTool.Input, which gives me a mouse location. But I had to extend
SelectionTool in order to make AbstractTool.getCurrentInput() public and
then tell the DefaultEditDomain about it.
Is there a better way to do that?
The issue you mention is not a problem because I do IFigure.findFigureAt()
on the mouse location, which covers the special cases you mention: I only
proceed if a particular figure is at the mouse position.
"Eric Bordeau" <ebordeau@us.ibm.com> wrote in message
news:bmed6s$b6$1@eclipse.org...
> > right-clicked.
if
> > diagram.
> > the
achieve
> >>Thanks, Felix
FUDForum. Page generated in 0.04313 seconds
