Home » Archived » M2M (model-to-model transformation) » Empty Stack Exception
Empty Stack Exception [message #9003] Thu, 18 January 2007 02:12 Go to next message
Originally posted by: irbull.cs.uvic.ca
I have a very simple transformation (that does nothing at all):
-- @atlcompiler atl2006
module TestTransform; -- Module Template
create output : metamodel from My : ecore;
rule Example {
from s : ecore!EObject
to t : metamodel!Node (
name <- s.toString()
do {
t.edges <- thisModule.getCross(s);
rule getCross (s : ecore!EObject) {
to rel: metamodel!Relationship (
but when I use the called rule I get an empty stack exception.
Is this the proper way to use a called rule?
Do lazy rules still exist (I didn't see them in the ATL User Manual)?
What is the difference between a lazy rule and a called rule?
cheers,
ian
Re: Empty Stack Exception [message #9092 is a reply to message #9003] Thu, 18 January 2007 05:12 Go to previous messageGo to next message
Originally posted by: mikael.barbero.gmail.com
Hi Ian,
Here are answers to your questions:
> rule Example {
> do {
Called rule doesn't return anything, then when you are doing t.edges <-
thisModule.getCross(s), something goes wrong.
I suggest you to change getCross to:
do {
rel;
to return a value.
Yes lazy rules still exist.
The main difference between a called rule and a lazy rule is that a lazy
rule is a matched rule that is matched when it is called. This seems to
be tricky, but much more useful and powerful than called rules.
First, lazy rules allow defining multiple rules for input model elements
(whereas matched does'nt). Second, they allow filtering as a classical
matched rule. Finally, as declarative programming style is the preferred
one for ATL transformation, lazy rules best fit this recommendation.
> cheers,
> ian
Hope this helps.
Mikaël
Mikaël Barbero - PhD Candidate
ATLAS Group (INRIA & LINA) - University of Nantes
2, rue de la Houssinière
44322 Nantes Cedex 3 - France
tel. +33 2 51 12 58 08 /\ cell.+33 6 07 63 19 00
email: Mikael.Barbero@{gmail.com, univ-nantes.fr}
http://www.sciences.univ-nantes.fr/lina/atl/
Re: Empty Stack Exception [message #9239 is a reply to message #9092] Thu, 18 January 2007 16:52 Go to previous messageGo to next message
Thank you so much Mikael!
Works like a charm.
ian
Mikaël Barbero wrote:
> Hi Ian,
> > rule Example {
> > do {
> do {
> rel;
> to return a value.
>> cheers,
>> ian
> Hope this helps.
> Best regards,
> Mikaël
Re: Empty Stack Exception PLUS question about lazy rules [message #10530 is a reply to message #9092] Fri, 19 January 2007 05:38 Go to previous messageGo to next message
Originally posted by: jairson.gmail.com
Hi Mikaël,
You said "> The main difference between a called rule and a lazy rule is
that a lazy rule is a matched rule that is matched when it is called. "
So in the case of Ian example
do {
{ to rel: metamodel!Relationship (
do {
rel;
How could that be done using a lazy rule? I cannot see in the case of
lazy rules how the matching works. How does ATL know which object is to
be matched? Can you give us a very short example?
Does version of 1.0.7 of the ATL engine and version 1.0.5 of the ATL
builder understand lazy rules?
Thank you
Jairson Vitorino
> Hi Ian,
> > rule Example {
> > do {
> do {
> rel;
> to return a value.
>> cheers,
>> ian
> Hope this helps.
> Best regards,
> Mikaël
Re: Empty Stack Exception PLUS question about lazy rules [message #10562 is a reply to message #9092] Fri, 19 January 2007 05:41 Go to previous messageGo to next message
Hi Mikaël,
do {
do {
rel;
Thank you
Jairson Vitorino
> Hi Ian,
> > rule Example {
> > do {
> do {
> rel;
> to return a value.
>> cheers,
>> ian
> Hope this helps.
> Best regards,
> Mikaël
Re: Empty Stack Exception PLUS question about lazy rules [message #10595 is a reply to message #9092] Fri, 19 January 2007 05:47 Go to previous message
Hi Mikaël,
do {
do {
rel;
Thank you
Jairson Vitorino
> Hi Ian,
> > rule Example {
> > do {
> do {
> rel;
> to return a value.
>> cheers,
>> ian
> Hope this helps.
> Best regards,
> Mikaël
Re: [ATL] Empty Stack Exception PLUS question about lazy rules [message #10627 is a reply to message #10562] Fri, 19 January 2007 05:32 Go to previous message
Hi Jairson,
I wrote a piece of doc in the wiki:
http://wiki.eclipse.org/index.php/ATL_Language_Troubleshoote r
Mikael
Jairson wrote:
> Hi Mikaël,
> do {
> do {
> rel;
> Thank you
> Jairson Vitorino
>> Hi Ian,
>> > rule Example {
>> > do {
>> <- thisModule.getCross(s), something goes wrong.
>> do {
>> rel;
>> to return a value.
>> lazy rule is a matched rule that is matched when it is called. This
>> seems to be tricky, but much more useful and powerful than called rules.
>> elements (whereas matched does'nt). Second, they allow filtering as a
>> classical matched rule. Finally, as declarative programming style is
>> the preferred one for ATL transformation, lazy rules best fit this
>> recommendation.
>>> cheers,
>>> ian
>> Hope this helps.
>> Best regards,
>> Mikaël
Previous Topic:[ATL] Problems with Contexts and ATL 2006
Next Topic:[ATL] Does ATL handle long number type ?
Current Time: Thu May 08 15:13:22 EDT 2025
Powered by FUDForum. Page generated in 0.08765 seconds
