Re: An internal error occurred during: "Create Remote VM for Visual Editor for J [message #98697 is a reply to message #98653] |
Wed, 20 July 2005 09:46   |
Hi Jon,
I've tried using the latest integration build (with prereqs) on WinXP and
I also get a similar error.
I have these installed:
VE-runtime-I20050719.zip
GEF-runtime-3.1.zip
emf-sdo-runtime-2.1.0.zip
eclipse-SDK-3.1-win32.zip
and Sun's 1.5.0_01 SDK
When creating a new Visual Class from File->New->Other I eventually get a
Visual Editor with only three tools: Selection, Marquee and Choose Bean.
The Eclipse log contains (and no, I can't explain the 1.5.0_02 vs.
1.5.0_01 jvm discrepancy either...):
!SESSION 2005-07-20 14:38:44.282
eclipse.buildId=I20050627-1435
java.version=1.5.0_02
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_GB
Framework arguments: --clean vm \java\jdk1.5.0_01\jre\bin\javaw.exe
Command-line arguments: -os win32 -ws win32 -arch x86 --clean vm
!ENTRY org.eclipse.ve.java.core 4 0 2005-07-20 14:40:02.223
!MESSAGE Exception thrown.
!STACK 0
org.eclipse.ve.internal.java.codegen.java.rules.DefaultVisit orFactoryRule.retrieveFromCache(DefaultVisitorFactoryRule.ja va:83)
org.eclipse.ve.internal.java.codegen.java.rules.DefaultVisit orFactoryRule.getTypeVisitor(DefaultVisitorFactoryRule.java: 109)
org.eclipse.ve.internal.java.codegen.java.JavaBeanModelBuild er.visitType(JavaBeanModelBuilder.java:508)
org.eclipse.ve.internal.java.codegen.java.JavaBeanModelBuild er.build(JavaBeanModelBuilder.java:417)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.reverseParse(JavaSourceTranslator.java:830)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.decodeDocument(JavaSourceTranslator.java:910)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.loadModel(JavaSourceTranslator.java:576)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisualEditorPart.java:1984)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:76)
!ENTRY org.eclipse.ui 4 4 2005-07-20 14:40:07.04
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2005-07-20 14:40:07.20
!MESSAGE Failed to execute runnable (java.lang.IndexOutOfBoundsException:
Index: 1, Size: 1)
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable
(java.lang.IndexOutOfBoundsException: Index: 1, Size: 1)
at org.eclipse.swt.SWT.error(SWT.java:2942)
at org.eclipse.swt.SWT.error(SWT.java:2865)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:126)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3057)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2716)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Caused by: java.lang.IndexOutOfBoundsException: Index: 1, Size: 1
at java.util.ArrayList.RangeCheck(Unknown Source)
at java.util.ArrayList.get(Unknown Source)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$38.activeToolChanged(JavaVisualEditorPart.java:928)
org.eclipse.gef.ui.palette.PaletteViewer.fireModeChanged(Pal etteViewer.java:175)
org.eclipse.gef.ui.palette.PaletteViewer.setActiveTool(Palet teViewer.java:383)
at org.eclipse.gef.EditDomain.loadDefaultTool(EditDomain.java:1 88)
at org.eclipse.gef.EditDomain.setPaletteRoot(EditDomain.java:33 9)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.rebuildPalette(JavaVisualEditorPart.java:968)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$16.run(JavaVisualEditorPart.java:2090)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
... 18 more
Re: An internal error occurred during: "Create Remote VM for Visual Editor for Java". [message #609119 is a reply to message #98608] |
Wed, 20 July 2005 08:24  |
Originally posted by: onkarshinde.rediffmail.com
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
daniel wrote:
> the error message is: tried to access method
> org.eclipse.pde.internal.core.WorkspaceModelManage.getWorksp acePluginModel(L
> org/eclipse/resources/IProject;)Lorg/eclipse/pde/core/plugin /IPluginModelBas
> e; from class org.eclipse.jem.internal.proxy.core.PDEProcessForPlugin
I am facing same problem.
Eclipse version: 3.1
VE version: 1.0.2.1 (Installed through Eclipse Software Update)
Onkar
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.2rc2 (MingW32)
iD4DBQFC3kJiEdJataruO48RAuyCAJiw10wuvWII9KMVOeMAjUqQwlViAKCR AFYr
CNXbmQIgbShvKwSbczqDdw==
=CG/D
-----END PGP SIGNATURE-----
Re: An internal error occurred during: "Create Remote VM for Visual Editor for Java". [message #609120 is a reply to message #98623] |
Wed, 20 July 2005 09:18  |
VE 1.0.2.1 is not compatible with Eclipse 3.1. Please try the latest
Integration build of VE 1.1 and it's required plug-ins from
http://www.eclipse.org/ve/
- Jeff
> Hash: SHA1
> Onkar
Re: An internal error occurred during: "Create Remote VM for Visual Editor for Java". [message #609121 is a reply to message #98623] |
Wed, 20 July 2005 09:28  |
VE 1.0.2.1 doesn't work with eclipse 3.1, lots of changes made since then.
Try stepping up to our latest integration build I20050719. On this page
will be a link to the other prereqs... Eclipse 3.1, GEF 3.1, EMF 2.1.
Within the next week we should have VE 1.1 final and that will show up
in the update manager. Until then you've got to to the download by hand.
-Jon
> Hash: SHA1
> Onkar
> =CG/D
Re: An internal error occurred during: "Create Remote VM for Visual Editor for J [message #609124 is a reply to message #98653] |
Hi Jon,
GEF-runtime-3.1.zip
!STACK 0
Index: 1, Size: 1)
!STACK 0
... 18 more
Re: An internal error occurred during: "Create Remote VM for Visual Editor for J [message #609126 is a reply to message #98697] |
Wed, 20 July 2005 10:08  |
Tried with the latest I build I20050720, no joy :(
VE-runtime-I20050720.zip (latest)
GEF-runtime-3.1.zip
Identical faulty behaviour and almost identical stack trace:
!SESSION 2005-07-20 15:00:52.629
!ENTRY org.eclipse.ve.java.core 4 0 2005-07-20 15:02:07.879
!STACK 0
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.reverseParse(JavaSourceTranslator.java:831)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.decodeDocument(JavaSourceTranslator.java:911)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.loadModel(JavaSourceTranslator.java:577)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisualEditorPart.java:1856)
!ENTRY org.eclipse.ui 4 4 2005-07-20 15:02:10.926
!ENTRY org.eclipse.ui 4 0 2005-07-20 15:02:10.926
Index: 1, Size: 1)
!STACK 0
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$32.activeToolChanged(JavaVisualEditorPart.java:799)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.rebuildPalette(JavaVisualEditorPart.java:839)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$14.run(JavaVisualEditorPart.java:1962)
... 18 more
Re: An internal error occurred during: "Create Remote VM for Visual Editor for J [message #609131 is a reply to message #98726] |
Wed, 20 July 2005 10:55  |
Originally posted by: richkulp.us.NO_SPAM.ibm.com
Actually this is a different problem then the original append.
This is an older workspace right? If so, please do the following:
1) Try to open a VE once, and close it.
2) Do Projects->Clean...->Clean All projects
3) Then try the VE again. It looks like introspection didn't work
correctly and it may be due to an old cache.
Rich Kulp
Re: An internal error occurred during: "Create Remote VM for Visual Editor for J [message #609134 is a reply to message #98769] |
Wed, 20 July 2005 11:45  |
Hi Rich,
Thanks for the walkthrough, it didn't work after a clean but I believe
I've tracked down the problem...
I created a fresh workspace and imported my existing projects. VE worked
only on certain projects and not others - so my problem was at least
partly due to the old cache you referred to.
The only difference between the ones that worked and the ones that didn't
was that some of our project don't use the default JRE container (this is
replaced by a vendor specific one) and I believe VE sources its core
classes from that.
Looks like I may have to go through some project gymnastics to use VE with
these projects :(
Steph
FUDForum. Page generated in 0.27264 seconds
