Home » Archived » Visual Editor (VE) » An internal error occurred during: "Create Remote VM for Visual Editor for Java".
An internal error occurred during: "Create Remote VM for Visual Editor for Java". [message #98608] Wed, 20 July 2005 07:34 Go to next message
Originally posted by: daniel.tradertools.com
the error message is: tried to access method
org.eclipse.pde.internal.core.WorkspaceModelManage.getWorksp acePluginModel(L
org/eclipse/resources/IProject;)Lorg/eclipse/pde/core/plugin /IPluginModelBas
e; from class org.eclipse.jem.internal.proxy.core.PDEProcessForPlugin
Re: An internal error occurred during: "Create Remote VM for Visual Editor for Java". [message #98623 is a reply to message #98608] Wed, 20 July 2005 08:24 Go to previous messageGo to next message
Originally posted by: onkarshinde.rediffmail.com
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
I am facing same problem.
Eclipse version: 3.1
VE version: 1.0.2.1 (Installed through Eclipse Software Update)
Onkar
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.2rc2 (MingW32)
iD4DBQFC3kJiEdJataruO48RAuyCAJiw10wuvWII9KMVOeMAjUqQwlViAKCR AFYr
CNXbmQIgbShvKwSbczqDdw==
=CG/D
-----END PGP SIGNATURE-----
Re: An internal error occurred during: "Create Remote VM for Visual Editor for Java". [message #98639 is a reply to message #98623] Wed, 20 July 2005 09:18 Go to previous messageGo to next message
Originally posted by: myersj.gmail.com
VE 1.0.2.1 is not compatible with Eclipse 3.1. Please try the latest
Integration build of VE 1.1 and it's required plug-ins from
http://www.eclipse.org/ve/
- Jeff
> Hash: SHA1
> Onkar
Re: An internal error occurred during: "Create Remote VM for Visual Editor for Java". [message #98653 is a reply to message #98623] Wed, 20 July 2005 09:28 Go to previous messageGo to next message
Originally posted by: jdstinto.us.ibm.com
VE 1.0.2.1 doesn't work with eclipse 3.1, lots of changes made since then.
Try stepping up to our latest integration build I20050719. On this page
will be a link to the other prereqs... Eclipse 3.1, GEF 3.1, EMF 2.1.
Within the next week we should have VE 1.1 final and that will show up
in the update manager. Until then you've got to to the download by hand.
-Jon
> Hash: SHA1
> Onkar
> =CG/D
Re: An internal error occurred during: "Create Remote VM for Visual Editor for J [message #98697 is a reply to message #98653] Wed, 20 July 2005 09:46 Go to previous messageGo to next message
Hi Jon,
I've tried using the latest integration build (with prereqs) on WinXP and
I also get a similar error.
I have these installed:
VE-runtime-I20050719.zip
GEF-runtime-3.1.zip
emf-sdo-runtime-2.1.0.zip
eclipse-SDK-3.1-win32.zip
and Sun's 1.5.0_01 SDK
When creating a new Visual Class from File->New->Other I eventually get a
Visual Editor with only three tools: Selection, Marquee and Choose Bean.
The Eclipse log contains (and no, I can't explain the 1.5.0_02 vs.
1.5.0_01 jvm discrepancy either...):
!SESSION 2005-07-20 14:38:44.282
eclipse.buildId=I20050627-1435
java.version=1.5.0_02
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_GB
Framework arguments: --clean vm \java\jdk1.5.0_01\jre\bin\javaw.exe
Command-line arguments: -os win32 -ws win32 -arch x86 --clean vm
!ENTRY org.eclipse.ve.java.core 4 0 2005-07-20 14:40:02.223
!MESSAGE Exception thrown.
!STACK 0
org.eclipse.ve.internal.java.codegen.java.rules.DefaultVisit orFactoryRule.retrieveFromCache(DefaultVisitorFactoryRule.ja va:83)
org.eclipse.ve.internal.java.codegen.java.rules.DefaultVisit orFactoryRule.getTypeVisitor(DefaultVisitorFactoryRule.java: 109)
org.eclipse.ve.internal.java.codegen.java.JavaBeanModelBuild er.visitType(JavaBeanModelBuilder.java:508)
org.eclipse.ve.internal.java.codegen.java.JavaBeanModelBuild er.build(JavaBeanModelBuilder.java:417)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.reverseParse(JavaSourceTranslator.java:830)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.decodeDocument(JavaSourceTranslator.java:910)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.loadModel(JavaSourceTranslator.java:576)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisualEditorPart.java:1984)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:76)
!ENTRY org.eclipse.ui 4 4 2005-07-20 14:40:07.04
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2005-07-20 14:40:07.20
!MESSAGE Failed to execute runnable (java.lang.IndexOutOfBoundsException:
Index: 1, Size: 1)
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable
(java.lang.IndexOutOfBoundsException: Index: 1, Size: 1)
at org.eclipse.swt.SWT.error(SWT.java:2942)
at org.eclipse.swt.SWT.error(SWT.java:2865)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:126)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3057)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2716)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Caused by: java.lang.IndexOutOfBoundsException: Index: 1, Size: 1
at java.util.ArrayList.RangeCheck(Unknown Source)
at java.util.ArrayList.get(Unknown Source)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$38.activeToolChanged(JavaVisualEditorPart.java:928)
org.eclipse.gef.ui.palette.PaletteViewer.fireModeChanged(Pal etteViewer.java:175)
org.eclipse.gef.ui.palette.PaletteViewer.setActiveTool(Palet teViewer.java:383)
at org.eclipse.gef.EditDomain.loadDefaultTool(EditDomain.java:1 88)
at org.eclipse.gef.EditDomain.setPaletteRoot(EditDomain.java:33 9)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.rebuildPalette(JavaVisualEditorPart.java:968)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$16.run(JavaVisualEditorPart.java:2090)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
... 18 more
Re: An internal error occurred during: "Create Remote VM for Visual Editor for J [message #98726 is a reply to message #98697] Wed, 20 July 2005 10:08 Go to previous messageGo to next message
Tried with the latest I build I20050720, no joy :(
VE-runtime-I20050720.zip (latest)
GEF-runtime-3.1.zip
Identical faulty behaviour and almost identical stack trace:
!SESSION 2005-07-20 15:00:52.629
!ENTRY org.eclipse.ve.java.core 4 0 2005-07-20 15:02:07.879
!STACK 0
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.reverseParse(JavaSourceTranslator.java:831)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.decodeDocument(JavaSourceTranslator.java:911)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.loadModel(JavaSourceTranslator.java:577)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisualEditorPart.java:1856)
!ENTRY org.eclipse.ui 4 4 2005-07-20 15:02:10.926
!ENTRY org.eclipse.ui 4 0 2005-07-20 15:02:10.926
Index: 1, Size: 1)
!STACK 0
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$32.activeToolChanged(JavaVisualEditorPart.java:799)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.rebuildPalette(JavaVisualEditorPart.java:839)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$14.run(JavaVisualEditorPart.java:1962)
... 18 more
Re: An internal error occurred during: "Create Remote VM for Visual Editor for J [message #98769 is a reply to message #98726] Wed, 20 July 2005 10:55 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
Actually this is a different problem then the original append.
This is an older workspace right? If so, please do the following:
1) Try to open a VE once, and close it.
2) Do Projects->Clean...->Clean All projects
3) Then try the VE again. It looks like introspection didn't work
correctly and it may be due to an old cache.
Rich Kulp
Re: An internal error occurred during: "Create Remote VM for Visual Editor for J [message #98797 is a reply to message #98769] Wed, 20 July 2005 11:45 Go to previous messageGo to next message
Hi Rich,
Thanks for the walkthrough, it didn't work after a clean but I believe
I've tracked down the problem...
I created a fresh workspace and imported my existing projects. VE worked
only on certain projects and not others - so my problem was at least
partly due to the old cache you referred to.
The only difference between the ones that worked and the ones that didn't
was that some of our project don't use the default JRE container (this is
replaced by a vendor specific one) and I believe VE sources its core
classes from that.
Looks like I may have to go through some project gymnastics to use VE with
these projects :(
Steph
Re: An internal error occurred during: "Create Remote VM for Visual Editor for J [message #98827 is a reply to message #98797] Wed, 20 July 2005 13:38 Go to previous message
Yes, you must use a JRE Container. I'm surprised that even JDT worked,
it too requires a JRE Container or a JRE_LIB variable. Without those
things get hairy.
What is different about the vendor specific JRE Container, may I ask?
Rich Kulp
Re: An internal error occurred during: "Create Remote VM for Visual Editor for Java". [message #609119 is a reply to message #98608] Wed, 20 July 2005 08:24 Go to previous message
Hash: SHA1
Onkar
=CG/D
Re: An internal error occurred during: "Create Remote VM for Visual Editor for Java". [message #609120 is a reply to message #98623] Wed, 20 July 2005 09:18 Go to previous message
- Jeff
> Hash: SHA1
> Onkar
Re: An internal error occurred during: "Create Remote VM for Visual Editor for Java". [message #609121 is a reply to message #98623] Wed, 20 July 2005 09:28 Go to previous message
-Jon
> Hash: SHA1
> Onkar
> =CG/D
Re: An internal error occurred during: "Create Remote VM for Visual Editor for J [message #609124 is a reply to message #98653] Wed, 20 July 2005 09:46 Go to previous message
Hi Jon,
GEF-runtime-3.1.zip
!STACK 0
Index: 1, Size: 1)
!STACK 0
... 18 more
Re: An internal error occurred during: "Create Remote VM for Visual Editor for J [message #609126 is a reply to message #98697] Wed, 20 July 2005 10:08 Go to previous message
GEF-runtime-3.1.zip
!STACK 0
Index: 1, Size: 1)
!STACK 0
... 18 more
Re: An internal error occurred during: "Create Remote VM for Visual Editor for J [message #609131 is a reply to message #98726] Wed, 20 July 2005 10:55 Go to previous message
Rich Kulp
Re: An internal error occurred during: "Create Remote VM for Visual Editor for J [message #609134 is a reply to message #98769] Wed, 20 July 2005 11:45 Go to previous message
Hi Rich,
classes from that.
these projects :(
Steph
Re: An internal error occurred during: "Create Remote VM for Visual Editor for J [message #609138 is a reply to message #98797] Wed, 20 July 2005 13:38 Go to previous message
things get hairy.
Rich Kulp
Previous Topic:Integration driver I20050720 available
Next Topic:Properties sheet
Current Time: Tue Jul 22 01:53:33 EDT 2025
Powered by FUDForum. Page generated in 0.10883 seconds
