Error Message in Log file [message #98574] |
Wed, 04 May 2005 09:06 |
Originally posted by: Rao.Pankaj.gmail.com
Hi All,
I am using Eclipse 31M6 and WTP M4. While trying to create to create a
J2EE project, I get following exception in my log file.
Any help would be highly appreciated.
!SESSION 2005-05-04 11:35:37.999
eclipse.buildId=I20050401-1645
java.version=1.4.2_07
Command-line arguments: -os win32 -ws win32 -arch x86 -clean
!ENTRY org.eclipse.ui 4 4 2005-05-04 11:35:37.999
!MESSAGE Error adapting
org.eclipse.jst.j2ee.navigator.internal.workingsets.Componen tWorkingSet to
org.eclipse.core.resources.mapping.ResourceMapping. Contribution
org.eclipse.compare.MenuGroups is being ignored
!ENTRY org.eclipse.ui 4 4 2005-05-04 11:35:38.79
org.eclipse.team.ccvs.ui.ResourceMapperContributions is being ignored
!ENTRY org.eclipse.ui 4 4 2005-05-04 11:35:38.89
org.eclipse.team.ui.ResourceContributions is being ignored
!ENTRY org.eclipse.ui 4 4 2005-05-04 11:35:38.139
!MESSAGE Error adapting selection to
!ENTRY org.eclipse.jface 4 2 2005-05-04 12:32:42.433
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.jface".
!STACK 0
org.eclipse.jface.viewers.CustomHashtable.hashCode(CustomHas htable.java:245)
at org.eclipse.jface.viewers.CustomHashtable.get(CustomHashtabl e.java:219)
org.eclipse.jface.viewers.StructuredViewer.findItem(Structur edViewer.java:617)
org.eclipse.jst.common.navigator.internal.workingset.views.C ommonWorkingSetViewer.mapElement(CommonWorkingSetViewer.java :145)
org.eclipse.jface.viewers.StructuredViewer.associate(Structu redViewer.java:486)
org.eclipse.jface.viewers.AbstractTreeViewer.associate(Abstr actTreeViewer.java:347)
org.eclipse.jface.viewers.AbstractTreeViewer.doUpdateItem(Ab stractTreeViewer.java:517)
org.eclipse.jface.viewers.StructuredViewer$UpdateItemSafeRun nable.run(StructuredViewer.java:351)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1021)
at org.eclipse.core.runtime.Platform.run(Platform.java:757)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:40)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:14 8)
org.eclipse.jface.viewers.StructuredViewer.updateItem(Struct uredViewer.java:1670)
org.eclipse.jface.viewers.AbstractTreeViewer.createTreeItem( AbstractTreeViewer.java:438)
org.eclipse.wst.common.navigator.internal.provisional.views. CommonViewer.createTreeItem(CommonViewer.java:201)
org.eclipse.jface.viewers.AbstractTreeViewer.updateChildren( AbstractTreeViewer.java:1684)
org.eclipse.jface.viewers.AbstractTreeViewer.internalRefresh Struct(AbstractTreeViewer.java:1164)
org.eclipse.jface.viewers.AbstractTreeViewer.internalRefresh (AbstractTreeViewer.java:1141)
org.eclipse.wst.common.navigator.internal.provisional.views. CommonViewer.internalAdd(CommonViewer.java:145)
org.eclipse.jface.viewers.AbstractTreeViewer.add(AbstractTre eViewer.java:124)
org.eclipse.jst.common.navigator.internal.workingset.views.C ommonWorkingSetViewer.add(CommonWorkingSetViewer.java:67)
org.eclipse.ui.model.WorkbenchContentProvider$3.run(Workbenc hContentProvider.java:279)
org.eclipse.ui.model.WorkbenchContentProvider.runUpdates(Wor kbenchContentProvider.java:156)
org.eclipse.ui.model.WorkbenchContentProvider.processDelta(W orkbenchContentProvider.java:130)
org.eclipse.ui.model.WorkbenchContentProvider.resourceChange d(WorkbenchContentProvider.java:106)
org.eclipse.core.internal.events.NotificationManager$2.run(N otificationManager.java:276)
org.eclipse.core.internal.events.NotificationManager.notify( NotificationManager.java:270)
org.eclipse.core.internal.events.NotificationManager.broadca stChanges(NotificationManager.java:144)
org.eclipse.core.internal.resources.Workspace.broadcastPostC hange(Workspace.java:180)
org.eclipse.core.internal.resources.Workspace.endOperation(W orkspace.java:912)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1723)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1734)
org.eclipse.wst.common.frameworks.internal.operations.WTPOpe ration.run(WTPOperation.java:248)
org.eclipse.wst.common.frameworks.internal.ui.RunnableWithPr ogressWrapper.run(RunnableWithProgressWrapper.java:64)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:346)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:291)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 830)
org.eclipse.wst.common.frameworks.internal.ui.WTPWizard.perf ormFinish(WTPWizard.java:242)
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:676)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:349)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:556)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:89)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:842)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2894)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2527)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:803 )
at org.eclipse.jface.window.Window.open(Window.java:781)
org.eclipse.wst.common.navigator.internal.actions.WizardShor tcutAction.run(WizardShortcutAction.java:114)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:996 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1570)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1534)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:306)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:228)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:344)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:156)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:315 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:268)
at org.eclipse.core.launcher.Main.run(Main.java:942)
at org.eclipse.core.launcher.Main.main(Main.java:926)
!ENTRY org.eclipse.ui 4 4 2005-05-04 12:32:42.563
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2005-05-04 12:32:42.583
!MESSAGE Failed to execute runnable (java.lang.NullPointerException)
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable
at org.eclipse.swt.SWT.error(SWT.java:2860)
at org.eclipse.swt.SWT.error(SWT.java:2783)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:121)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:2871)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2530)
org.eclipse.jface.dialogs.MessageDialog.openError(MessageDia log.java:319)
org.eclipse.jface.util.SafeRunnable.handleException(SafeRunn able.java:59)
org.eclipse.core.internal.runtime.InternalPlatform.handleExc eption(InternalPlatform.java:703)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1023)
Caused by: java.lang.NullPointerException
org.eclipse.jface.viewers.AbstractTreeViewer.updateChildren( AbstractTreeViewer.java:1662)
org.eclipse.jface.viewers.AbstractTreeViewer.internalRefresh (AbstractTreeViewer.java:1097)
org.eclipse.jst.common.navigator.internal.workingset.views.C ommonWorkingSetViewer.internalRefresh(CommonWorkingSetViewer .java:215)
org.eclipse.jface.viewers.StructuredViewer$8.run(StructuredV iewer.java:1198)
org.eclipse.jface.viewers.StructuredViewer.preservingSelecti on(StructuredViewer.java:1108)
org.eclipse.jst.common.navigator.internal.workingset.views.C ommonWorkingSetViewer.preservingSelection(CommonWorkingSetVi ewer.java:326)
org.eclipse.jface.viewers.StructuredViewer.refresh(Structure dViewer.java:1196)
org.eclipse.jst.common.navigator.internal.ui.workingsets.pro viders.DelegateWorkingSetContentProvider$2.run(DelegateWorki ngSetContentProvider.java:197)
org.eclipse.jst.common.navigator.internal.ui.workingsets.pro viders.DelegateShowProjectContentProvider$5.run(DelegateShow ProjectContentProvider.java:327)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:118)
... 74 more
!ENTRY org.eclipse.core.resources 4 2 2005-05-04 12:32:44.446
"org.eclipse.core.resources".
!STACK 0
org.eclipse.jface.viewers.CustomHashtable.getEntry(CustomHas htable.java:230)
org.eclipse.jface.viewers.CustomHashtable.containsKey(Custom Hashtable.java:194)
org.eclipse.jface.viewers.AbstractTreeViewer.updateChildren( AbstractTreeViewer.java:1700)
!ENTRY org.eclipse.ui 4 4 2005-05-04 12:32:45.297
!ENTRY org.eclipse.ui 4 0 2005-05-04 12:32:45.507
!STACK 0
... 18 more
FUDForum. Page generated in 0.24358 seconds
