Home » Eclipse Projects » GEF » NODE_ROLE
NODE_ROLE [message #98489] Fri, 10 October 2003 13:33 Go to next message
Originally posted by: ThisisFake.Fakeness.xyz
Looking at the logic example, it does not seem to use the NODE_ROLE.
Instead it uses only the GRAPHIC_NODE_ROLE. I am having trouble
differentiating between the two. What is the difference?
CL
Re: NODE_ROLE [message #98626 is a reply to message #98489] Sat, 11 October 2003 04:10 Go to previous messageGo to next message
Originally posted by: brian.fernandes.codito.com
Have a look at this thread -
Is there any replacement for NodeEditPolicy ? by Balaji - 14th May 2003.
Should give you a few pointers.
Brian.
Re: NODE_ROLE [message #98652 is a reply to message #98626] Sat, 11 October 2003 09:41 Go to previous messageGo to next message
> Brian.
I did read that, but it didn't address directly my question. It deleted
NodeEditPolicy, but that is an implementation. It did not specify that
the architecture was doing away with the associated Role, NODE_ROLE.
If it is, then that would be fine, but the architecture needs to catch up,
especially the notes/javadoc.
CL
Re: NODE_ROLE [message #99262 is a reply to message #98489] Mon, 13 October 2003 08:55 Go to previous message
Use GRAPHIC_NODE_ROLE if you need to deal with layout constraints and visual
feedback and so on. Otherwise NODE_ROLE is sufficient.
Cu, Gunnar
Previous Topic:CreationTool
Next Topic:What layout should I use ?
Current Time: Wed Nov 05 00:16:31 EST 2025
Powered by FUDForum. Page generated in 0.04397 seconds
