Home » Eclipse Projects » JFace » IStructuredSelection
IStructuredSelection [message #8945] Thu, 21 May 2009 17:51 Go to next message
I constantly find myself writing this code:
if (selection instanceof IStructuredSelection) {
if (((IStructuredSelection)
selection).getFirstElement().getClass().equals(clazz)) {
return ((IStructuredSelection) selection).getFirstElement();
Is there a utility class available for ISelection and subordinates?
Thanks in advance and best regards,
Wim Jongman
http://www.remainsoftware.com
http://www.industrial-tsi.com
Re: IStructuredSelection [message #8987 is a reply to message #8945] Thu, 21 May 2009 21:39 Go to previous messageGo to next message
Hi Wim,
Not that I know of. We have quite an elegant (IMO) solution in e4, but that
probably does not count. ;-)
A good first step towards a common solution is to build one yourself, in
your code, that works for your use cases. Then, once you have enough
confidence in the API, you could contribute it back through Bugzilla.
Boris
"Wim Jongman" <wim.jongman@remainsoftware.com> wrote in message
news:gv4ick$7v0$1@build.eclipse.org...
> Wim Jongman
Re: IStructuredSelection [message #9007 is a reply to message #8987] Fri, 22 May 2009 08:17 Go to previous messageGo to next message
Hi Boris,
Thanks for your help. I already started a SelectionUtil class and if i'm
happy with it I wil do as you suggested. I'm curious about the e4 solution.
Have not seen e4 yet, but if I can find it I will give it a spin today.
Best Regards,
Wim Jongman
"Boris Bokowski" <Boris_Bokowski@ca.ibm.com> wrote in message
news:gv4vo8$juq$1@build.eclipse.org...
> Hi Wim,
> that probably does not count. ;-)
> Boris
>> Wim Jongman
Re: IStructuredSelection [message #9026 is a reply to message #9007] Fri, 22 May 2009 08:45 Go to previous message
Hi Wim,
The solution for this in e4 is maybe not that easy to find... have a look at
the class "ExifTable" which implements the view displaying Exif data for
images. The idea is that the code that unwraps a selection should be outside
of the views, all you do is implement a method setInput(DomainObject o),
which will be called when there is an "input" of that type available for the
view.
Boris
news:gv655h$elh$1@build.eclipse.org...
> Hi Boris,
> solution. Have not seen e4 yet, but if I can find it I will give it a spin
> today.
> Best Regards,
> Wim Jongman
>> Hi Wim,
>> Boris
>>> Hi,
>>> Wim Jongman
Previous Topic:Opening A View Programatically
Next Topic:Strange toolbar
Current Time: Tue Jul 22 01:49:47 EDT 2025
Powered by FUDForum. Page generated in 0.27655 seconds
