How can create right button menu like logic example? [message #98210] |
Fri, 10 October 2003 03:01  |
Originally posted by: nemo_fc.sina.com
In logic example,there will be "+1 increment" and "-1 increment" on the
right button menu when right button click the an LED model.It could change
the number on led.How can I implement such function? Or which code files
will tell me that in logic example?Could anyone tell me that? Thanks very
much!
Re: How can create right button menu like logic example? [message #99340 is a reply to message #98532] |
Mon, 13 October 2003 10:16   |
I find the hashmap of the ActionRegistry which getActionRegistry() return
is null.So I instance it myself by such way:
nemoPropertyAction npa = new nemoPropertyAction(this);
getActionRegistry().registerAction(npa);
this.getSelectionActions().add(npa.getId());
nemoPropertyAction is Action defined myself.then I gets registered for
nemoContextMenuProvider by:
ContextMenuProvider provider = new
nemoContextMenuProvider(viewer,a);
viewer.setContextMenu(provider);
getSite().registerContextMenu("nemo.HelloGefeditor.contextmenu ",
provider, viewer);
Though those code,I implement right button menu.But I want to konw in
formal way,where should I arrange my code which set getActionRegistry()
retun value's hashmap isn't null? Maybe should I place it in
CreateActions()?If it is true,when will CreateActions() be called?called
by system automatic or by myself.
Eric Bordeau wrote:
> Take a look at ContextMenuProvider and LogicContextMenuProvider. The
> context menu gets registered in LogicEditor.configureGraphicalViewer()...
> ContextMenuProvider provider = new LogicContextMenuProvider(viewer,
> getActionRegistry());
getSite().registerContextMenu("org.eclipse.gef.examples.logic.editor.contextmenu ",
> provider, viewer);
> When the user clicks the right mouse button,
> ContextMenuProvider.menuAboutToShow(IMenuManager) is called, which then
> calls buildContextMenu(IMenuManager). This is where the actions get
> added to the menu.
Re: How can create right button menu like logic example? [message #99400 is a reply to message #99340] |
Mon, 13 October 2003 10:42   |
Yes, you should create your actions and add them to the ActionRegistry
in createActions(), which will be called automatically. Make sure you
call super.createActions(), since GraphicalEditor creates some actions
itself.
> provider, viewer);
>>provider, viewer);
>>added to the menu.
FUDForum. Page generated in 0.07377 seconds
