Home » Language IDEs » ServerTools (WTP) » WTP M4 is it working ?
WTP M4 is it working ? [message #97964] Tue, 03 May 2005 12:29 Go to next message
Originally posted by: hicham.dev.menara.ma
Hello
I've got Eclipse 3.1M6 + sun jdk 1.5_02 + wtp M4 + Tomcat 5.0.28
I've tried running the WTP tutorial showBrowser.jsp and a snoop servlet
failed to run them
Hicham.
Re: WTP M4 is it working ? [message #98085 is a reply to message #97964] Tue, 03 May 2005 16:12 Go to previous messageGo to next message
Hi Hicham,
WTP M4 has been tested with JDK 1.4.2. Give your scenerio a try with a
1.4.2 JDK and please open defects for the 1.5 specific problems.
Lawrence
>Hello
>failed to run them
>Hicham.
Re: WTP M4 is it working ? [message #98592 is a reply to message #98085] Wed, 04 May 2005 09:06 Go to previous messageGo to next message
Lawrence Mandel wrote:
> Hi Hicham,
> Lawrence
Ok, where should I look for logs and errors ?
most of the time I get a windows pops up "Half sized" which doesn't help
to see the error message
Hicham
Re: WTP M4 is it working ? [message #98729 is a reply to message #98592] Wed, 04 May 2005 11:51 Go to previous message
Hi Hicham,
You can usually see error messages in your workspace log file (which can
be found under WORKSPACE_DIR/.metadata/.log) or you can see them by
running Eclipse with a console as in
eclipse -consoleLog
If you can't see the specific error message you can also open a bug report
stating your steps to reproduce the error.
Lawrence
>Hicham
Previous Topic:HttpServletRequest
Next Topic:M4 webapp context path value
Current Time: Sun Jul 13 23:41:36 EDT 2025
Powered by FUDForum. Page generated in 0.03745 seconds
