Home » Archived » Test and Performance Tools Platform (TPTP) » Exception when launching tests from ant driver
Exception when launching tests from ant driver [message #97911] Sun, 06 May 2007 10:45 Go to next message
Hello.
When I use an ant driver to launch my AGR tests, one time out of three
on average the driver falls over immediately after having added my test
suite(s) with an exception whose stack trace follows and corrupts my
workspace.
I am using Eclipse 3.2.2 and TPTP 4.3.0.
Any idea of what might be wrong?
TIA,
B.
Stack trace:
org.eclipse.core.runtime.CoreException: Plug-in
org.eclipse.hyades.test.tools.core was unable to load class
org.eclipse.hyades.test.tools.core.services.TestExecutionSer vice.
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .throwException(RegistryStrategyOSGI.java:165)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:149)
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:759)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
org.eclipse.hyades.automation.server.ServiceProxy.<init>(ServiceProxy.java:81)
org.eclipse.hyades.automation.server.AutomationServer.run(Au tomationServer.java:254)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
org.eclipse.core.runtime.CoreException[1]:
java.lang.ClassNotFoundException:
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:402)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:347)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:278)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1245)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:147)
Re: Exception when launching tests from ant driver [message #98544 is a reply to message #97911] Mon, 14 May 2007 07:32 Go to previous message
Hi Barbara,
This appears to be a defect. Can you open a defects
( https://bugs.eclipse.org/bugs/enter_bug.cgi?classification=T PTP >> TPTP
Testing >> Test.Execution) with any revelelent information including your
configuration and this stack trace?
Thanks.
Paul
"Barbara Rosi-Schwartz" <Barbara.Rosi-Schwartz@Etish.org> wrote in message
news:f1kpmb$64l$1@build.eclipse.org...
> Hello.
> When I use an ant driver to launch my AGR tests, one time out of three on
> workspace.
> TIA,
> B.
> Stack trace:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Previous Topic:AGR - Run several test suites all together
Next Topic:Assertion during testing on Linux
Current Time: Sun Aug 31 07:15:08 EDT 2025
Powered by FUDForum. Page generated in 0.04097 seconds
