Home » Eclipse Projects » Eclipse Platform » Run a file
Run a file [message #97772] Tue, 22 July 2003 20:08 Go to next message
Originally posted by: nospam.nospam.com
In JBuilder, I could right-click a class name in the Package Explorer and
run it if it contained a main() method. Can't seem to find a way to do that
in Eclipse without going through the hassle of setting up a run
configuration. This is a headache when there are a lot of test classes that
I want to run individually. Is there a way to do this?
Re: Run a file [message #97963 is a reply to message #97772] Wed, 23 July 2003 02:34 Go to previous message
Why not select it..
and then go to the run or debug menu
and then do : Debug As-> Java Application
Then it auto starts the one you selected.
johan
"Chris" <nospam@nospam.com> wrote in message news:bfkjk0$e6n$1@eclipse.org...
Previous Topic:[ANN] jMechanic Profiler Plugin for Eclipse Version 0.5.5
Next Topic:Setting start up parameters for eclipse on linux?
Current Time: Sun Nov 09 00:09:55 EST 2025
Powered by FUDForum. Page generated in 0.03453 seconds
